Question about Plantronics GameCom 367 Closed Ear Gaming Headset
Speakers are broken, cut off will mic still work
Mic works , speakers do not
We have a wirless Microphone using with a xp510i itwas working OK but we think somepne has played with the knobs as I cant get the Mic to working through the speakers any ideas
Process of elimination needed. Plug a corded mic into the wireless channel. Does it also cut in and out? If not then it sounds like the wireless is the one cutting in and out...not unusual for cheap units. Your wireless is not a cheapie? Then check the wireless squelch setting located on the receiver as it may be set too high.
Apr 25, 2014 | Samson Airline 77 Aerobics Wireless...
Cb works but there is no sound
turn volume and mic gain half way up, plug in an external speaker into the PA jack, flip PA switch and key up, if it doesnt squeal your audio final is blown or it could be so simple as mic wired wrong or broken wire. try another mic.
Mar 31, 2013 | Cobra 29 LTD CB Radio
How do I get the sound to work?
sometimes a mic will cut out the speaker to cure feedback look on bottom right of screen for speaker icon and see what levels are there
May 28, 2012 | Computers & Internet
Cannot recognize working microphone
I found the answer. Rosetta Stone has a problem detecting the mics if the speaker input is not in someway connected to the mic. I'm not exactly sure how it works, but I don't care and neither should you.
Follow these steps each time you want to use it and you should be fine.
*I'm on Vista, but this should work for every one.
1. Open Control Panel
2. Open Hardware and Sound
3.Open Sound
4.Set Line 1 as your Default Speaker
5. Refresh the Mic list
*All of your mics should now show up.
6. In Rosetta Stone, apply the mic you want and finish the setup.
7.Start whatever language you're using and switch back to the Sound menu.
8.Set whatever speaker you want to use as default.
*Rosetta Stone will continue to work fine until you close it, switch Users, or remove the mic.
In short you have to set the default speaker to LINE 1 to get the mics to appear. Then when you apply the settings switch the default speaker back.
Apr 21, 2009 | Computers & Internet
The sound cuts off sometimes the wire seems to be the problem...
The wire leading into the headset is likely broken. Usually this occurs at the entrance point of the jack or at the point where the wire enters the speaker, if they are worh repairing, open the speaker and check the condition of the wire. this can be as easy as pulling gently on the wire either side of the suspected break. if the wire is firm then it is likely alright, if the wire stretches, the wire is broken inside and only the insolation is keeping it togehter.
if this doesn't work then you will need an ohm meter and ohm out the cable, remember to flex the cable at the suspected area with the meter on, if the meter drops off you found your break.
solder up the break or if in the case of the jack solder on a new jack.
Hope this is of some help.
Ed
Apr 19, 2009 | Logitech Audio Players & Recorders
Speakers work with ipod not with laptop
First thing, you have plugged in to the wrong point, plug in the speaker to the headphone slot(mostly light green in color).
MIC point is specifically for MIC not speakers.
The point which works for your headphones would work perfectly for speakers.
Mar 15, 2009 | Logitech X-240 Computer Speakers
Jabra bluetooth adapter A210
hi,
you have to connect the jabra audio jack to the audio source, to the speaker output of your receiver for example. If jabra detects the source it will work. If you cut the connection, jabra watch for a while if something happend and than stops the transmittion. Hope that helps
Oct 26, 2008 | LG Jabra A210 Bluetooth Adapter for...
Iphone 3g mic
hardware seems broken. If it was a software problem, then the bluetooth would not have worked as well
Aug 13, 2008 | Apple iPhone 3G
Headphone and mic
my presario c700 has a built in mic try just connecting headphones in and using the built i mic
Jul 23, 2008 | Compaq Presario 700 470024-192 Notebook
Mic issues
A8V-VM SE FRONT PANEL AUDIO does not work. The back panel audio speaker port works ok but not the MIC port. I have built over 100 pcs with different motherboards & procesors including several other Asus MoBo both Intel and AMD types. BIOS flas did not help. Asus tech support /knowledge base is useless to find answers.
If anyone has had this problem and solved it , please pot your answer.
Thanks
Oct 22, 2007 | ASUS A8V-VM Motherboard
Plantronics GameCom 367 Closed Ear Gaming Headset Logo
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Ed Nelson
Ed Nelson
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
