Question about ATI RADEON X1300 Pro 256MB PCIE Graphic Card
New monitor it is not working good clarity
New monitor
Can't get my Monster Clarity HD 100 speaker to charge up. LED on front doesn't light up. Any way to troubleshoot this item?
Not charging is one of two things. The battery is bad or the charger is bad. It is easy to check the charger output with a meter to determine if that is it.
May 10, 2016 | Monster Clarity Hd Monitor Speakers -...
This monitor was working perfectly well, i bought a new dell 24inch monitor 4 weeks ago and swapped them over, i just plugged the NEC monitor back in but there is no display.
You may have set the resolution or refresh rate for the new monitor to a setting that is out of parameter for the old monitor. Try reducing both your resolution and your refresh rate to a minimal setting with the new monitor plugged in, then plug the old monitor in and see if it works.
May 17, 2015 | Dell Computers & Internet
HP 2009m LCD monitor is cracked.
I would buy a new monitor. Unless you have some prior experience with replacing screens, the labor outweighs the price of a new monitor.
Dec 26, 2012 | HP 2009M Monitor
Panel lcd broken samsung ls 26tddsuv/en
I recommend you buy a new monitor, since just fixing the panel would be more costly then buying a brand new monitor. Check out www.newegg.com or www.tigerdirect.com for some good deals on new monitors.
Jan 15, 2012 | Samsung Computers & Internet
I have a Soyo MT NI DYLM 2086 and have bought a new computer. Do I need to download anything to insure that I get full screen / maximum clarity from the new computer?
The new computer will determine whether this is needed or not. If the computer is a 32 bit Operating System such as Vista 32-bit or Windows XP 32-bit then there is probably no need for any additional drivers. With some of the newer OS systems it may be needed, but there is little chance you should need to download monitor drivers for any system.
If you find that you are not getting complete clarity with higher resolution, in searching around for drivers for your monitor I have found it to be almost a dead end. I am seeing on the net that many people are finding it impossible to find newer drivers. So the alternate could be that you use some of the windows generic drivers to produce the resolution you are looking for and see if one of them works with your Soyo monitor.
Dec 04, 2010 | Soyo Computers & Internet
No display on a brand new Samsung EX2020 monitor.
mcdevito75 here Refer to the instalation instructions that came with your new PC and monitor, Also you cantry to hit the auto switch on the monitor or check with the menu on the monitor, press menu and see instructions / options.
Jul 03, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Describe your acer monitor al1914 Problem screen not working right. The clarity and the color are dim. Tried to auto reset, but no luck so far. please help!
As far as the clarity concerned, the PC Video setting should be set to the native resolution of this monitor, which is 1280 x 1024 @60Hz for best picture.
Try it on another PC also, otherwise you may have to open it up but we need to narrow down the problem first.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Please post back what you find so we can guide you further and will also help other people as well.
Apr 10, 2010 | Acer AL1914 19" LCD Monitor
I have two Samsung Syncmaster 2253LW monitors. One is about two years old. The other one is new. The older monitor seems to be darker than the new one. How can I restore the monitor to the original...
open the monitor look there is an eht a black big part has a preset rotate it with a screwdriver in on condition of monitor then you can regain the original brightness
Mar 21, 2010 | Samsung SyncMaster 2253LW Monitor
Distorted images
try to change resolution settings.
right click on your desktop and click properties.. >> go to settings tab and change the resolution and colour quality and see if it works.
Good Luck!
Feb 26, 2010 | Dell E228WFP LCD Monitor
New computer, new lg monitor. monitor is black
Is the monitor plugged in to the computer's VGA Video Output (15 pin connector, 3 rows of pins)?
Most motherboards are able to supply very basic 640x480 video but you might want to install whatever drivers you have onto the new computer, if not already installed. This should get you off to a start, anyway. After Monitor wakes up the process will be lots easier. LCD Monitors ought to work for initial Installs.
Dec 20, 2009 | LG 22" FLATRON LCD Monitor
Computers & Internet Logo
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
