Question about ZTE Warp
Volume boost not supported
Is there any way to fix the volume loss when hooked up to a wired device to prevent the massive loss of volume created by the SRS system not supporting volume boost in my ZTE majesty
  • ZTE Master
  • 2,072 Answers
The boost is only to the speakers and not the headphone jack. If you were really crazy you could build your own headphone Op Amp to create your own booster. It's actually not that difficult to do. http://www.instructables.com/id/Op-amp-headphone-amplifier/
I'm sure you could also buy a professionally designed/built one if you google it.
Posted on Mar 19, 2014
What are the benefits of radish??
Some of the benefits of radish are:
1. It acts as a powerful detoxifier that helps in purifying the blood, eliminating toxins and waste.
2. It is also helpful in curing jaundice because it removes bilirubin.
3. Radish helps in digestion, water retention and fixes constipation in our body.
4. It is useful in removing ******* disorders.
5. Radish is very filling and thus it helps in weight loss.
6. Radish helps in increases the efficiency of the metabolism in our body.
Jan 27, 2016 | Miscellaneous
Bought a zte boost max from a person .took it to boost to switch my boost phone to zte and representative acidentially reset phone so now it says need old email address and passwordany way to fix
How to Hard Reset Boost Mobile ZTE MAX 9520 ... - YouTube
? 1:40
https://www.youtube.com/watch?v=SkMDrK5fWSA
May 17, 2014 - Uploaded by HARD RESET KING
Reset Hard Reset for ZTE ZMAX Locked with Google, Screen pattern or PIN - Duration: 1:59. by Klavdio ...
ZTE Boost Max - how to hard reset my phone - HardReset.info
www.hardreset.info/devices/zte/zte-boost-max/
Hard Reset ZTE Boost Max. First method: Turn off your phone. Format ZTE Boost Max; Press and hold Volume Up + Power at the same time for a few seconds.
How to: Factory Reset a BoostMobile ZTE Phone ...
https://raydatroubleshooter.wordpress.com/.../how-to-factory-reset-a-boo...
Jan 05, 2016 | ZTE Cell Phones
Is it true that honey & cinnamon is very good health wise
Some of the health benefits of Honey and cinnamon are:
1. Regularly intake of honey and cinnamon can cure chronic arthritis.
2. It destroys the germs in the bladder and reduce the risk of bladder infection.
3. It can reduces the level of cholesterol in the blood within 10 minutes.
4. Cure most chronic cough, cold, and clear the sinuses.
5. If Honey is taken with cinnamon powder the stomach is relieved of gas.
6. Relieves acidity and digests the heaviest of meals.
Mar 03, 2014 | Computers & Internet
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
So the wattage of the is 32 watts and voltage is 12.8v. is it?
This makes no sense... 32 Watts and 12.8 volts... something to do with this speaker that is rated at 500 Watts???
If you are trying to calculate something for a car amp you don't understand how they work... that is the only thing I can think given the 12.8 volt thing you stated. Most high power car amps BOOST the incoming battery voltage up with a switching power supply. For instance, they might boost to 48 volts and that applied to a 4 ohm speaker would be 12 amps PEAK maximums. BUT the RMS power is one half that or about 288 Watts in round figures before considering losses.
Many car amps are designed to run with 2 ohm speakers... JUST SO THEY CAN CLAIM massive power values in their ads so you will buy them!
Jan 21, 2011 | Peavey SP2 PA Passive Speaker
How to boost volume dell laptops
My fix on Vostro 3700 was to go to the speaker/headphone properties, under the Enhancements tab, i turned on Loudness Equalization. My volume was louder than ever before
May 04, 2010 | Dell Vostro 1014 Laptop Computer
Runs real lean and surges under throttle massive loss of power
if you have a vacuum guage handy hook it to your manifold and if your reading is under 15 hg then you have a manifold gasket leaking or you could just replace the gasket.
Apr 28, 2009 | 1995 Toyota 4Runner
LOW VOLUME TO HIGH VOLUME
Is this for a specific ringtone or all ringtones on the phones?
Certain versions of the iPhone firmware have an issue where the volume keeps decreasing. Try this to fix -
1. Press the sleep button on top of the phone
2. Now press the home or sleep button so you see the "lock screen (the screen with the wallpaper that has the unlock slider)
3. Double click the home button and the ipod controls should come up on the screen.
4. The volume is probably set at the half way mark...set the volume to full.
See this fixes your problem?
Apr 13, 2009 | Apple iPhone 3G Black Smartphone
I get a humming sound when I record a video
There a quite a few reasons why this could happen.
  1. The sound device could be malfunctioning.
  2. The cables are not plugged in all the way.
  3. The camera may be close to a noise maker such as a fan, air conditioner, or your PC fan.
  4. The sound wires could be crossed with an electrical wire which sometimes creates static or a hum.
  5. If you are using a normal Microphone, there could be static on the port or connector.
  6. The record volume levels are too high, or mic boost has been enabled and is picking up extra sound.
I hope one of these examples helps to fix your problem, if it doesn't, please get back with me and we can try something else. Good luck!
May 03, 2008 | Microsoft LifeCam VX-3000 Web Camera
Deck is powering off every 5 seconds
If radio stays on at low or no volume and cuts out when turning up you may have your battery backup voltage (yellow wire) droping below 10v under signal load. There is a circuit called backup check in radio that moniters Voltage It may seem ok when measuring without volume but under load it will fluctuate with the audio. Try hooking up Heavy guage Ground and Backup battery wires to prevent voltage loss across wires under load. Also check for any speaker that may not be producing proper sound when and if you can get radio working Disconnect wires to that speaker to see if radio will stay on. Just a couple of many possibilities.
kstahl65@att.net
Jan 12, 2008 | JVC KD-S890 CD Player
ZTE Warp Logo
50 people viewed this question
Top ZTE Cell Phones Experts
Audrey Messer
Audrey Messer
john smith
Nyte_Ryder
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
