Question about Fisher Price Deluxe Smart Response Swing
How do you open battery compartment?
I need to change the batteries & cannot open the compartment.
The battery in my home safe has died, i have a key but can't see where it goes ?
You didnt provide the type of safe but on mine the bottom of the keypad lock mechanism has a compartment for the battery. Mine doesnt need to be opened to change the battery. If your has a compartment if you push on it it will pop open then you just change the battery.
Apr 05, 2017 | The Home Security
Cannot open battery compartment to change battery's
All you need to do is slide the battery cover to the Open position, then open the battery cover to access the batteries. If it doesn't open easily you may have some corrosion on the batteries holding the cover closed.
Mar 01, 2016 | Casio Exilim Ex-fh20 20x 9.1mp Digital...
Change the batteries in my hand held can opener modelS1212
Put both thumbs in the center of the flat side (the bottom). Apply downward pressure and move your thumbs toward the "tail" of the can opener to slide the bottom off and reveal the battery compartment.
Sep 23, 2014 | Kitchen Appliances - Others
My keyless entry pad will let garage down when code is keyed in, but when code has been keyed up to let it up it will not do so.
I assume you mean that the entry keypad works when the door is open but not when the door is closed. This usually indicates that the signal strength on the entry pad is low. Try changing the battery.
Insert a small Philips screwdriver in the opening on the bottom of the battery compartment cover. Pull the cover slightly outwards then pull the cover down. The battery in the compartment is a 9V battery. Then replace the cover by inserting the lip in the top of the battery compartment and then snap it into place.
If you change the battery quickly, you shouldn't need to reprogram the opener. If a new battery doesn't solve the problem, check what may be causing signal interference when the door is down. (Consider moving the keypad to a spot closer to the door opening. I know that we have the keypads placed on the side of the door jamb on our garage doors. When the small handheld remote units start to loose their batteries, bringing the remotes to that area that often works.)
I hope this helps.
Oct 04, 2013 | Sears Craftsman LiftMaster Chamberlain...
Cannot open battery compartment on Sony Cybershot rmt-dsc1 remote
@ Frans Bedford-Visser
On the right side of the battery compartment you can see some vertical plastic lines. Pull those towards the compartment. Simultaneously open the compartment as indicated by the arrow. It will open. Took me a while to figure it out but it works.
Jan 08, 2012 | RCA DIRECTV Satellite Remote Control
Wont turn on
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to assist you. You are having problems because you calculator won't turn on. I think you should try changing the batteries. Did you know that your calculator has two batteries powering it? Not only are the 4 AAA batteries powering it, but there is also a CR 3V Lithium Back Up battery powering it as well. First, try changing the 4 AAA batteries. If that still does not power your calculator properly, you will need to replace the lithium back up battery. You can find this at a department store or store that carries electronics. To do this, open your regular battery compartment. Above the AAA batteries is a compartment that says "BACK UP BATTERY CR1616 OR CR1620" with a picture of it. Use a small crosshead screwdriver to open the compartment. Take the old battery out and replace it with the new one. Rescrew the lithium battery compartment back on and close the AAA battery compartment. Turn on your calculator and see if that works. I hope this solution solves this.
Sep 27, 2011 | Texas Instruments TI-83 Plus Calculator
How to change battery
Hi, try:
To install the battery:
Note: To open the battery door, you will need a paper clip or thin pen.
1. Take the paper clip and use the end to press down on the door latch.
2. Holding the latch down, push the battery door up.
3. The door will slide up and spring open, allowing you to access the batteries.
4. Place the battery into the compartment. Be sure to match the (-) on the
battery with the (-) inside the compartment.
5. Slide the battery cover to its original
Jun 09, 2011 | Disney Pix Micro Digital Camera
How do you change the battery on an Intermatic EJ500C timer?
Following link has photo of the battery carriage
http://waterheatertimer.org/ST01C-program.html#EJ500
Open door on EJ500.
Below button is battery compartment.
Use small tool to open compartment.
Befor pulling out batteries, notice direction that batteries sit.
Look at markings on battery.
Replace with same battery.
Jan 12, 2011 | Intermatic Inc. EJ500C Digital Wall Switch...
I want to replace the cr2 battery.Where is the battery compartment for the Intermatic model ST01 self adjusting wall switch timer?
The battery compartment is located behind the pull-down door
Pry open the door with small screwdriver of fingernail file
http://waterheatertimer.org/ST01C-program.html#battery
If the battery goes dead on the Intermatic ST01C or EJ500, the screen will not display.
When replacing battery, wipe clean all the terminal points for battery and battery carriage
If the new battery does not restore the screen, then the timers needs replacement.
http://www.aplussupply.com/intermatic/timer.htm
Nov 03, 2010 | Electrical Supplies
Sio/Scan Temperature Transmitter 433MHz for batteries
I just changed the batteries yesterday. It was hard to open the battery compartment with bare hands/finders. I used flat screw driver to poke into the notch in the center of the transmitter. Or you can try poke into any **** around the compartment. It works!
Feb 17, 2010 | SkyScan 86709 Atomic Wall Clock
Fisher Price Deluxe Smart Response Swing Logo
Top Fisher Price Baby Gear Experts
romney2012
Lyle Siemens
Lyle Siemens
Josh Whitehead
Josh Whitehead
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
