Question about LG RU-60SZ30 60" Rear Projection HDTV-Ready Television
LG Ballast board replacement works
I AM FROM CARACAS-VENEZUELA, I HAVE LG REAR PROJECTION LG RU52SZ30 THE TECHNICIAN TOLD ME THAT THE BALLAST BOARD WAS BAD I BOUGHT A NEW ONE FROM SHOPJIMMY LG 6913V00002C, THE MANUAL SAID THAT BALLAST BOARD IS LG 6913V00002A, I GUEST THAT I BOUGHT IS IT THE REPLACEMENT ITEM. THE PROBLEM IS THAT THE CONNECTOR IT DOES NOT FIX WITH THE BOARD OF THE LG TV SET. I WOULD LIKE TO KNOW, FIRST IT ALL, IF THE NEW ONE HAS THE SAME CHARACTERISTIC OF THE OLD ONE AND IT CAN MAKE THE SAME FUNCTION. AND SECOND I WOULD LIKE TO KNOW IF IT WORKS, THE TECHNICIAN CAN MAKE CONNECTOR ADAPTER TO PUT THE TV WORKS. I WOULD APPRECIATE YOUR ANSWER AS SOON IS POSSIBLE
    Top Expert:
  • LG Master
  • 75,283 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Posted on Apr 06, 2017
3 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: ballast replacement
Your set uses the Phillips UPH100W 1.3 100http://servicemanuals.vstore.ca/ 1amp bulb part number 6912V00006A which uses Ballast EUC 6913V0002A and the actual ballast isMB03CA part number 6871VSMB13F I would contact LG and give them these numbers. Is your ballast bad or is the BallastEUC bad? Let me know if I can help you further.
Posted on May 12, 2008
russ_hill007
  • 3976 Answers
SOURCE: I was told I need a new lamp ballast assembly. I
so the one first is an LG model ballast but the one in the tv is a phillips one, strange.. can you give me the bord number power side... it is always best to replace old number so the damaged numer one should be the number you use. LG, Philips etc use different part to make the same tv model. e.g one can be made in twain and the other from china. both the same case do the same things but have completely different parts in side. Looking at the parts on line they don't have the same connections or the same voltage so would be a bad idea to try and put the new one in with the wrong number.
Posted on Oct 23, 2013
LG RU60SZ30 I have a LG RU60SZ30. I had a technician come out and I was told I need a new lamp ballast assembly. I was wondering if anyone could help me with this process. I opened up the whole back of tv...
need to unscrew or unclip the board and pull out the back. it will be screwed down to the plastic case. and have the wires plugged into it. remove it all and replace.
Oct 21, 2013 | Televison & Video
Toshiba 42H82 the screen will go black after 5 minutes, sometimes it comes back on after a minute, but most of the time I have to turn it off for about 10-20 minutes. Some days it works fine, others it...
Hi.
It is probably a defective ballast board or a faulty PSU. The ballast is the high voltage power board connected to the lamp.The PSU is the board that supplies power in different voltages to the other internal parts. One of the DC lines from PSU goes straight to the ballast. The repair is done testing the voltage from PSU to ballast. The job must be done by a technician.
Dec 15, 2011 | Toshiba 42H82 42" Rear Projection...
How do you fix a lamp ballast board on 50 inch sony grand wega
The ballast board will need replacement you can get the sony Lamp ballast 146892712 used in the KDF55WF655 models, from www.tvrepairworld.com listed under the sony DLP circuit board cxategory
Oct 28, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV Model: Sony Wega KDF-55E2000 Projection lamp warning is on..and today a light red bar appeared at the top of the screen and light blue on the bottom..is this because the projection lamp needs to be...
Hello
There are two possibilities for this fault with Sony Projection tVs. The first is with the lamp itself. The second one is with the lamp ballast baord. Replace the lamp ballast board first. Because, it there is any internal winding short in the inverter transformar of the ballast board this type of fault can occur. you have to replace the ballast baord along with the new lamp anyway. Therefore, replace the ballast board first. If this help you, there is no need ot replace the lamp. Picture of the ballast included here for you to compare.
gopakumarg43_36.jpg If replacing the ballast dis not help you, change the lamp too. OK.
Aug 31, 2011 | Sony KP-57XBR10 57" Rear Projection...
I am replacing a lamp in my tv that went out.I ordered the lamp and now I cannot get it to work. Can you help me?
Tv turn on now?The tv now having alot of clicking sounds too?Yes,the board that call the Ballast board it is also dead.This Ballast board only job are to ignite the tv projection lamp.Must replace the Ballast board too.
Mar 14, 2011 | Hitachi 60V500 60" Rear Projection...
I was told that my bulb is good however the balast is bad. where can i purchase this and are there instructions on replacing it?
Turn on the tv now,hear alot of clickings?Yes,the Ballast board is dead.The only function of the Ballast board is to ignite the projection lamp.Tries websites like Ebay.com,Partstore.com to buy a ballast board for the replacement.Instructions came with the board,how to replacing it,don't know?Try You Tube.com video.Type in ur tv make,model and the problems.Might have some bodies giving u advises or there are videos tutoring u how to do it.
Oct 12, 2010 | Panasonic PT-43LC14 43" Rear Projection...
I HAVE LG REAR PROJECTION AND IT TURNS ITSELF OFF AT RANDOM IT CAN GO FOR HRS WITHOUT TURNING OFF AND OTHER TIMES IN A HR
Have you replaced the lamp all ready this sounds like you have a bad BALLAST BOARD the ballast board is not working correctly it is not sending enough energy to maintain the lamp on but but sometimes it is able to gather enough to keep on for hours sounds like a bad BALLAST
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Oct 04, 2010 | LG RU-52SZ30 52" Rear Projection...
It take about 15 to 20mins for the pic to clear up how can i fix?
U hear alot of clicking within the 15-20 mins.Yes,than,ur tv the ballast board it also dead,require a new ballast board also.The Ballast board,that board help to ignite the the projection bulb.
Jul 05, 2010 | Hitachi 50VS810 50" Rear Projection HDTV
My PT-61LCX65 all of a sudden turned itself off and the Lamp indicator LED is blinking once every 5 sec. It will not power up. Can it be the lamp?
That is most probably the lamp. In some case the lamp is fine and the problem is the lamp high voltage board (ballast board).
The most coomon is always the lamp. The lamp cannot be tested . The ballast board must be tested by a technician.
The normal operation in this case is replaceing the lamp that cannot be tested. then, if you are within that 2% of the cases with ballast problem you replace the lamp power board or call a technician.
You can find parts here.
May 03, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Ballast replacement
May 12, 2008 | LG RU-60SZ30 60" Rear Projection...
LG RU-60SZ30 60" Rear Projection HDTV-Ready Television Logo
120 people viewed this question
Computer Repairing
Computer Repairing
