Question about Garden
On the tecumseh model vlv126 where is the oil plug to change the oil?
Push mower
  • 64 Answers
Under mower in crankcase of motor or directly under the fill/check plug!
Posted on Apr 29, 2014
jj505
  • 195 Answers
SOURCE: Wont stay started
pastorcheri,
I found this site if you can not find plug behind engine/blk wire with black cover boot/ pull off.
http://www.webcrawler.com/webcrawler301/ws/results/Web/Cub%20Cadet%20Online%20Part%20Lists/1/302349/RightNav/Relevance/iq=true/zoom=off/_iceUrlFlag=7?_IceUrl=true
Please rate. Thanks. jj505
Posted on Mar 30, 2009
  • 205 Answers
SOURCE: yard machine 21'' push mower runs 2 to 3 seconds cuts off.
Tip the mower up on it's side with the dipstick tube on the down side and collect it in a suitable container. The gas you can do the same. When I drain old fuel, I mix it with a lot of fresh fuel and a bottle of dry gas then run it in my car.
Posted on Apr 24, 2009
SOURCE: mower surging
let it surge, it will usually get better as it warms up. These 6.5 Hp engines are fine except they have an cheap badly designed carburator. Nothing can be done about this problem. They all surge eventually.
Posted on Jun 16, 2009
  • 64 Answers
SOURCE: my bolen push mower won't start, it worked two
see if it has spark. try to trickle a little gas into where the carburetor is and see if it will atleast fire.
Posted on May 01, 2010
  • 198 Answers
SOURCE: how to set timing on a push mower with a tecumseh
if it is an older machine, yes, the points are underneath the flywheel---it can be removed without a puller---just a little patience will get it off
Posted on May 12, 2010
Where is the oil drain plug?
Johnathon, some mowers you just tip on there side and drain oil from fill plug into a pan. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Changing Draining Your Walk Behind Lawn Mower Oil
How to Change Lawn Mower Oil
Lawn Gardening Tips How to Change Oil in Lawn Mower
May 22, 2016 | Tecumseh Garden
What type of spark plug and the gap size
The Tecumseh Push mowers, most or all of the Tecumseh brands uses a Champion J8c, and the gap at .020.
Jun 24, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Oil mixture for 1985f series 2 cycle lawn-boy mower
Contact your dealer ! but 32:1 sounds correct. 8 ounces of Lawnboy oil to two gallons of gasoline ....is 32:1, 8 ounces of oil to one gallon of fuel is 16:1 for the real old lawnboys,
When Toro bought out OMC,and started using Tecumseh mowers,the ratio changed in the late 80's or early nineties ! IIRC :o)
Jun 11, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Changing oil on a lawnboy silver series 6.5HP
on the bottom of the mower or some you just remove oil filler cap and turn mower on its side.
Mar 29, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
I changed oil, blade, spark plug,air filter on tecumseh lawn boy 10685 mower...now it will not start!!! gas tank was emptied, per instructions. before changes, it started right up on first pull before...
Hi
Make sure the blade and shaft can easily be moved by hand. First, remove the spark plug wire from the plug. Reach under the mower and see if the blade will turn or if something is stuck between the blade and the mower. Also remember that you have to hold the safety bar when you are starting the mower or the engine won't turn. It is possible that the cable from the safety bar to the engine brake has come loose. Follow the cable from the safety bar to the engine and make sure it is working.Also check whether the line from the gas tank to the engine is crimped?
Also check this link to troubleshoot your problem:-
http://www.ehow.com/how_7363405_troubleshooting-push-mowers.html
Aug 04, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
How do you drain the oil on a 4.5hp MTD tecumseh engine, their is no oil drain plug.
unplug the spark plug and tip the mower towards the side with the oil filler tube. Place a bowl on the ground to catch the oil. Thats it!
Jun 29, 2010 | Mtd 22" Yard Machine Push Mower
Mower surging silver serieslawn boy 6.5 h.p. tecumseh motor model lev 120 spec 362006a. I cleaned out carb bought a rebuild kit replaced o rings in center jet and another under float also little metal...
Jun 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
My mtd tradesman lawn mower does not run smooth. where is the idle mixture adj. screw? the engine is the tecumseh 5.5 hp model #VLV55 501029A(D)
The newer machines do not have a way for you to adjust the Idle, what you can do is change the spark plug or spray some carb cleaner or remove the air filter and run it for a few minutes without the air filter and see what happens
Apr 14, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
