Question about Home Fencing
I have a Michelin g735 floor jack that leaks the fluid out. Where is the best place to start looking for the leak? I don't use it that often but I noticed the floor of the garage was wet under the jack. I got some fluid to put in it but don't want to just put it in to watch it leak out again.
  • meris376
    meris376 Sep 15, 2012
    where can i buy parts for this jack
  • 867 Answers
Most likely place is the piston seal
Posted on Jun 14, 2009
Where I can find caster for a Michelin floor jack g735 can someone help me thanks
contact the manufacturer of the jack for a spare castor
find a wheel and castor shop in your area as they will probably have a replacement unit or if you have to replace both castors
Apr 15, 2016 | Cars & Trucks
How do I find parts for a Michelin G735 jack?
Steven,
Sorry to say but I think your going to have to old school and start matching parts. I had to do the same on my old Napa hydraulic bumper jack
Oct 10, 2014 | Cars & Trucks
I also have a Michelin 3 1/2 ton jack that will jack up. My guess is that it needs hydraulic fluid but I have no idea where to fill it with fluid. Where do I refill the fluid at on this jack?
MOST JACKS HAVE A BOLT LOOK PLUG TO REFILL THE JACK AND YOU DO IT WITH THE JACK AT THE LOWERS POINT, SOME HAVE A RUBBER PLUG. YOU CAN USE P/S FLUID OR TRANMISSION FLUID TOO TO REFILL IT.
May 24, 2014 | Cars & Trucks
Power steering fluid leaking?
Robert, Use a strong flashlight and check from top and bottom. If you need to jack vehicle to check underneath the engine, please secure it with jack stands (don't rely on the floor jack or your vehicle's tire change jack). If you don't see evidence and have not lost any fluid then there is nothing wrong. Any visible "wetness" is acceptable as long as it is not dripping or running when engine is running. Check all your fluids and make sure it is serviced per manufacture recommendations or your owners manual. Check it again after one month, if the fluid level is fine, then the car is fine. Also place a cardboard on the floor where you park overnight and see if you have any evidence. Sometimes during oil changes, depending of filter location, droplets are common as well as from the oil pan drain plug during removal. As long as it does not elak after installation, you are fine.
Feb 17, 2013 | 2008 Mercedes-Benz ML 350
Brakes dont work properly,when I brake the pedal goes all the way to the floor.Is my master cylinder the problem?
best place to start is looking for a leak in the system especially on corroded brake lines. fill master cylinder with fluid and have assistant gently push on brake pedal. check all fittings and lines for leaks. look carefully around gas tank as lines snake in front of tank above heat shield and are impossible to see without removing tank but leak will drip down at some point.
Jan 02, 2011 | 1998 Dodge Stratus
How to remove transmission filter
You will need a floor jack and two jack stands. Raise the vehicle high enough to give you plenty of working room. Place the jac sstands uner the frame rails on each side of the vehicle and lower the floor jack to let the vehicle rfest on the jack stands. Place a large drain pan ujnder the transmission and rmove the front an side mounting bolts. Loosen, but do not remove the rear mounting bolts. Pry the front of the transmission pan loose and pull it down to allow the fluid to drain into the drain pan. The drain pan should be large enough to hold at least 5 quarts of fluid. Now remove the remaining bolts, and the pan and gasket.Clean all traces of gasket and sealant from the mating surface of the transmission. Drain the remaining fluid from he trans.pan and clean with solvent. Remove any gasket material or sealant from he gssket mounting surface. Remove the old filter from the transmission. If the seal didn't come out with the filter, remove it from the transmission . The new seal can be driven into place with an appropriate size socket. Make sure it goes in square.Install the new filter.Install the new gasket on the pan and install the pan on the transmission. Tighten the bolts a little at a time to make sure the pan goes on straight. Don't over tighten the bolts or it will distort the pan and cause a leak. Lower the vehicle. Add 3 1/2 quarts of transmission fluid. See the owners manual for the correct fluid. If you put the wrong fluid in, the transmission will malfunction. Start the engine with the transmission in park and fast idle it but do not rev it up. Move the gear shift lever through the gears and back to park. Check the fluid level on the dipstick. It should reach the cold mark. Check for leaks. Your ready to drive. Keep a close eye on the fluid level for the first few trips and add a little fluid as necessary.
Dec 29, 2010 | 1999 GMC Jimmy
Home Fencing Logo
2,610 people viewed this question
Top Home Fencing Experts
crkuc
R Daniel Wolfe
 Russ Hill
Russ Hill
Are you a Home Fencing Expert? Answer questions, earn points and help others
