Question about Cerruti 1881 Gents Watch Genova Chronograph Crb005a222g
Slow how to replace battery
Watch loosing about 15 seconds a day. just replaced battery
battery or quarzt watches work on a puls acction and cannot be adjusted ,there could be dirt in the movement that's slowing it down, or needs oiling, sounds like a job for the watch repair shop..
Aug 01, 2012 | Watches
It is very slow
The first reason can be that your battery might have died out so try and replace the battery. If it is still very slow then the hands of the watch might be lose. Or it might just have a lose spring which might need to be replaced. Its more likely to have a week battery.
Jan 09, 2011 | Watches
My Swatch Irony watch has recently been running slow. I thought it might be a low battery, but after a replacement, it still loses time (a few minutes each day). Any ideas?
Thank you for contacting Fixya,<br /> I would have the battery checked again. Sometimes batteries in stores can be past the extended life of battery. Otherwise could be a number of issues. Has it been around water? Dropped? Could need cleaning. In cases of most watches, like Swatch, the cost to have repaired may exceed the watch. <br /> You can contact Swatch at:<br /> <a href="http://www.swatch.com/zz_en/shop.html">http://www.swatch.com/zz_en/shop.html</a>
Aug 24, 2010 | Swatch Irony watch
My Ebel (9187241) is now 11 years old. Recently...
The 4 second ticking indicates the battery is in need of replacing.
A professional watchmaker can properly replace the battery for you.
Hope this helps,
Ken
Yellowstone Watch, Inc.
www.yellowstonewatch.com
May 20, 2010 | Ebel 1911 1087221 wristwatch
Time display does not stay on,I have to push light button
This can occur for many reaons. There could be a movement problem. But it can also be the battery is running slow. If the battery was replaced recently it could be that it needs to be resett. When the battery is replaced on most digital watches the battery and the AC of the watch need to be shorted.
Aug 11, 2009 | Casio G2310-1V Wrist Watch
Eddie bauer watch runs slow
This usually means the battery is dying. Usually the backs on these are very tight, and the back has to be taken off to replace the battery. You might be able to get the back off without damaging the watch, but you probably will not get it back on without breaking the crystal. Best thing to do is take it to a reputable watch repair place or jewelry shop and have them replace the battery for you. Before they begin, make sure they are willing to replace the crystal for free for you if they break it!
Aug 06, 2009 | Watches
Tropby radio controlled watch, runs slow, even with new battery
Your watch is need to clean an replaced the old oil in gear shafting that is the common problem of a watch when the old oil is sticky already thats makes the gear moves slowly and your watch is always late . If ever your watch was already clean and replaced new oil and still working slowly then the problem is in the circuit board is near to run out its needs to replaced whole circuit board so its better again. I know this because im a technician in Rolex service center before. Feel free to ask whatever the result.
Hope it may help you;
Regards;
VOTIT
Jan 30, 2009 | Bulova Watch
Cerruti 1881 Gents Watch Genova Chronograph Crb005a222g Logo
10 people viewed this question
Top Cerruti Watches Experts
Kolbrun...
Kevin Brown
Kevin Brown
Level 1 Expert
Pamela Leach
Pamela Leach
Are you a Cerruti Watch Expert? Answer questions, earn points and help others
