Question about Cerruti Watches
Battery replace battery
Finding and replacing the battery on my Zodiac sea dragon Z02270
  • Remove back
  • Locate battery. Note mounting arrangement for later battery replacement
  • Obtain replacement battery
  • Install battery
  • Check operation
  • Install back
  • Set time, etc.
Oct 19, 2016 | Zodiac Watches
What battery does the fossil ch2599 watch take
You are going to have to remove the battery to find out which one you need. For instructions on how to do this see: http://www.mademan.com/mm/fossil-watch-battery-replacement-guide.html. You can buy the battery at: http://shop.batterymart.com/search#w=fossil%20ch2599%20watch%20battery. Replacing a Fossil battery is delicate and tricky. Fossil recommends that you send it to a shop that specializes in Fossil watch battery replacements.
Feb 25, 2015 | Fossil Watches
Battery replacement
If you have a warrantee with your watch you may have to return thew watch to the manufacturerer for battery replacement. Othet than that, most any jeweler can replace the battery. Mike D 75
Jun 07, 2010 | Philip Stein Teslar Stainless Steel Small...
I can't find a replacement battery, I have 2 3
Go to "http://relicbrand.com/pdf/Service_Form.pdf" and you will find an order form with prices for repairs and battery replacement.
It may seem expensive for a replacement battery but if you see the number of people who can't get their watches to go after battery replacement, you wouldn't hesitate to send them off.
Mar 17, 2010 | Relic 0504648FA
How to replace battery in polar f4 watch
HOW TO REPLACE BATTERY IN MY POLAR TARGET WITH A TS1 TRANSMITTER
Nov 25, 2009 | Polar F4 Heart Rate Monitor Watch
How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
May 12, 2009 | Timex Expedition 84601 Wristwatch
Watch going in reverse
There is no difference in watch batteries as they are produced by the certain standards. That means you have replaced the right battery.
The simplest solution would be re-replacing the battery. Just take the battery out and leave the watch without battery for 5 minutes, then put the battery back. Make sure the battery is fitted the right way (the + side usually facing up).
If this doesn;t help - let me know.
Rate, please.
Mar 23, 2009 | Watches
What's the replacement battery# for the Luminox 3000 Navy watch?
I was shopping for one in Thailand and it was a GE 371. I did not replace it because they only carried the cheap china battery's.
Mar 02, 2009 | Navy Seal Luminox Dive Watch
Sekonda 3850 battery replacement
Hi, its Richard, after battery replacement before replacing watch back, there is a small hole in the movement near the edge if you look down it there is a metal plate at the bottom gently press this with a fine screwdriver, the display will then come on, it is a reset switch, regards Richard.
Aug 20, 2008 | Watches
Battery Replacement
I thought you are supposed to touch the neg side of the battery
Jun 01, 2008 | Casio DBC1501 Wrist Watch
Watches Logo
21 people viewed this question
Top Cerruti Watches Experts
Kolbrun...
Pamela Leach
Pamela Leach
Geoff
Are you a Cerruti Watch Expert? Answer questions, earn points and help others
