Question about Fujitsu Siemens Mouse
Mouse double klick
Ore more
It double nails quite a lot
Time for an oring kit and also replace the trigger valve. These nailers have some vinyl /gold colored orings that fail. If you buy a kit, , make sure that the vinyl orings in the kit are still usable. If you have a source for buna orings, use them instead. Good luck.
Oct 20, 2014 | Dewalt D51850 Heavy Duty 20 Degree Full...
My touchpad js not working
If the clicks of the touch pad is not working but pointer is moving that means there is some problem with the hardware contact the manufacturer of the computer
Oct 27, 2011 | Computers & Internet
I have a kind of "klick klick klcik klick"
Weird noise or unusual sounds from within the engine must be looked on seriously . You need to check on take a second opinion as it can prevent serious damage and expensive work.
Sep 16, 2011 | Motorcycles
How to adjust double shot for Hitachi nail gun
The condition of the driver oring is an indication of wear of all the other orings in the gun. Remove the nails and lightly tap the nose against piece of wood. If the driver drops to bottom of cylinder the oring is worn out and time for oring kit. Hitachi nailers are sensitive and will double fire if placing the foot against work then depressing trigger. Adjust the depth thumb screw several turns either direction then depress trigger and quickly bump gun against work. Good luck with your repair.
May 03, 2011 | Hitachi NR83A2 Framing Nailer Full Head...
K600
press any key on your keyboard, not the mouse.
Jan 02, 2010 | Foxconn MB KT600 600A01-6LRS Motherboard
I need a drive of instalation microsoft Life cam vx 1000 to my notebook
hi erli
you have to download from this link:
http://www.megaupload.com/?d=ul7qt26o
after you downloadin this, install it and register it also update it from tools menu.
after this going to tools/device diagnostik/ if the something does not installet in your machine you will see "?" klick on it with the right on mouse and follow update driver, if the new driver ecxisting you klick OK and after this going again in tools/driver download manager
after the file downloaded you will find him on c:/download driver, ecxtract him and install
that all you need to do!!!
Oct 18, 2009 | Microsoft LifeCam VX-1000 Webcam
Somehow I moved the startup taskbar from bottom of screen to the top and now don't know how to move it back
Right click mouse on task-bar and under properties you unchecked "lock the task-bar"
in that window you can chose were to place it ore
left click on the task-bar and hold, then move the mouse to you`r left, right, ore where you want to place it and release mouse key.
Oct 05, 2009 | Dell Latitude D610 Notebook
Dell wireless adapter for Windows XP Media Centre can not find keyboard
The first thing to do when you have a hardware problem is always to go to Device Manager :Start>My Computor{left klick on My Computor}>Properties>Hardware>Device Manager.In the drop down,find your device that is giving you problems.Double klick on the device and see what Windows says about it ,whether it needs drivers or has a physical problem.Your USB adaptor seem to be working OK since it is oscillating ,meaning that it is searching for the Keyboard transmission to lock on.This means that you have loaded the correct driver software for the usb device.I suspect that your problem is with the Keyboard power-make sure you have installed the batteries correctly{polarity check}When all is working properly,you should find the keyboard listed under Keyboards in Device Manager.Double klick on it to see if it is working properly.Your USB device should appear under USB Controllers.Regards
Jun 07, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Magic
Klicking is the gears. Klick Klick Klick is the machine skipping gear spots and trying to recover.
Needs new gears.
Could also be the main boards going bad since the board controls the brew drive and the gear system.
Its one of the two. If it is the board, saeco cannot fix it and they do not have replacements. They stopped carrying them about 6 months ago.
Mar 23, 2008 | Saeco Magic De Luxe Espresso Machine
Fujitsu Siemens  Mouse Logo
85 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
