Question about Singer 4423 Sewing Machine
My machine will not make a stitch
Will not make a stitch
How do I do a basic satin stitch ? My machine only has patterned satin stitches
A satin stitch is a combination of a wide zig-zag and a short stitch length. Set the stitch width to the maximum. Then while stitching, shorten the stitch length until the threads lay next to each other so no fabric shows between the threads but the threads do not overlap. It would help if you have a satin stitch foot so there is space under the presser foot for the extra threads.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Satin Stitch or Zig Zag Machine Applique stitch
Machine Appliqu Basics 1 Turning right angle corners with satin stitch
Mar 23, 2018 | Sewing Machines
Empisal creations and episal EXP889 sewing machines.... which is the better one and more recent model
It really depends on what You envision yourself doing with the sewing machine and then finding the machine that has the most functions that fit your needs.
Empisal 889:
  • 36 Stitch functions
  • Front load bobbin
  • On/off switch
  • Left and middle needle position
  • 18 Stitches
  • 4 Step buttonhole
  • Stitch width control
  • 4.5mm Maximum stitch width
  • Soft cover
  • 4.5mm Maximum stitch length
  • Reverse stitch
  • Twin needle
  • Free arm
  • Carrying handle
  • Uncoupling bobbin winder
  • Clip on, clip off foot
  • Drop feed
  • Sews on buttons
  • Zipper foot
Empisal Expression 889 Sewing Machine Empisal Sewing Machines
Empisal Creations
  • 4 Step buttonhole
  • 19 Built-in stitch patterns
  • Oscillating hook
  • Sews on zips
  • Adjustable stitch length: 0 - 4mm
  • Adjustable zigzag stitch width: 0 - 5mm
  • On / Off swithch
  • Free Arn
  • Accessories
  • Reverse stitching
  • Horizontal spool holder
  • Self uncoupling bobbin winder
  • Cover on accessory compartment
  • Large working surface
  • Thread cutter
  • Adjustable presserfoot pressure
  • Built-in tension
  • Darning plate
  • Fold away carry handle
  • One touch snap on foot
  • Versatile utility stitches
  • Sews through heavy fabrics
  • LED lighting
Empisal Creations Sewing Machine Empisal Sewing Machines
https://www.russells.co.za/empisal-creations-sewing-machine
Dec 11, 2017 | Sewing Machines
Can I sew a Blanket stitch with my Bernina 930 Record machine?
Once upon a time, a blanket stitch used to be a long wide zigzag stitch. If you are referring to an electronic stitch version that would look like the inverse of a blind-hem stitch, then no, this is not possible on the 930 record machine.
What is nowadays called a blanket stitch used for quilting applications requires the machine to stop feeding during the stitching cycle to allow for the single stitch to the left and then back again. An electronic step motor machine, common to all newer Bernina machines can do this and or similar functions. That being said, don't be thinking about getting rid of your 930. Better to get one of the newer units for occasional blanket stitching and keep the Swiss made 930. The Bernina 930 is a lifetime machine. Computers machines are not lifetime class machines by virtue of being computers. Electronics are short lived.
SewTechnical Home
Jun 17, 2014 | Bernina Sewing Machines
Stitch width knob
What's the model? Do you have the stitch selector set on straight stitch, or on a stitch with a width component, like a blind hem stitch?
Some machines consider straight stitch to be a zigzag stitch of width=0, while others have separate settings for a straight stitch and a zigzag (or other) stitch.
Feb 11, 2014 | Elna Sewing Machines
Why straight stitch will not work but zigzag and herringbone stitches work on my machine.
it sounds like the machine needs to be checked at a sewing
machine shop to see what's wrong with the cam's or gear
that makes the stitches
Aug 01, 2012 | Sewing Machines
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
I want a loose button-hole type of stitch to do my first applique by machine. I have put the needle to one side, put on foot #20 -- and now what stitch?
This depends entirely on your model of machine and the kinds of stitches it is designed to make. Not all machines will make the kind of stitch you describe. My machine has a buttonhole stitch, but with slanted bars, and it really doesn't give the right look.
Check your machine manual and look for a stitch that gives you the look you want--you might have a "blanket stitch" option. If your machine doesn't offer a buttonhole or blanket stitch that gives you the look you want, you may want do use a narrow zigzag satin-stitch. You can also do a straight stitch very close to the raw edge of a fused applique but it won't look as tidy.
Apr 01, 2011 | Sewing Machines
Singer 4423 Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
