Question about Canon PC-920 Black and White Copier
Cs-5500i copyies coming out all black
Customer has all black copies
I have a minolta ep2030 and when i hit copy all i get is black page.
- clean the scanner optics
- if this don't work check and replace drum cleaning blade
Jul 26, 2012 | Minolta EP1030/1030F CS/PRO Copier
Minolta cs Pro- Works but print black copy?
Please clean the mirror unit,the trasfer and separator coronas,and perform F5 AIDC control.
May 19, 2010 | Minolta EP4000/5000 CS/PRO Copier
I have a navman 5500i tracker ,the zoom isnt coming up far enough to show water depths and hazards by pushing the + - button .is there an easy fix? Thankyou Muzza
Just got the same one and same problem, I also have a 5505i and is only zooms in close when i put in the c-map chip and it zooms close in the chip area only?? now i have a chip for the 5500i and it zoomed in but only on the Texas part of the map, that is the chip it came with, but i live in Canada. Be carefull the c-map max chip for the 5505i is not compatible with the 5500i it needs c-map nt+ chip. 5500 chip is black 5505 is orange
Jan 19, 2010 | Navman Tracker 5500i GPS Receiver
Black lines down the paper when copying
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab31
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
CS 3035 printing problem/network issue?
Check the sleep mode settings on it. Do you know how to check on Kyocera's tech website to see if there is a firmware upgrade available?
Sep 17, 2008 | Kyocera CS-2050 Black and White Copier
Poor quality fax to fax, copy great, computor fax great.
beware of generic toner!
you may need to change out your drum unit
the drum unit may have been contaminated by the staples toner.
also clean laser window under drum cartridge.
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Canon PC-920 Black and White Copier Logo
46 people viewed this question
old marine
old marine
