Question about KitchenAid Microwave Ovens
Broken handle KHMC 1857 wwh
Need to replace handle so where do I find part number
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
How do I replace a broken door handle on a GE Microwave JVM1631WB004?
First determine if you can get a replacement handle will you be able to remove the broken handle on your own and install the replacement or will you need the assitance of an experienced repair person.
if you have the tools and know-how to do thihs on your own determine ifyou can get a replacement door handle. Information on contacting GE for parts in Canada can be found here:
http://www.geappliances.ca/parts/index.jsp#3
You could also try their call center: 1.888.261.3055
Make sure you have your complete model number and description of your unit. Was not able to locate information for the model number you provided.
GE Global website can be found here. You may be able to find your model if you check on the website for the country of purchase.
Jan 30, 2011 | GE Microwave Ovens
How do you take the door off? I too have a broken handle and door...
If only the door handle is broken, it can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The door handle on this model has two parts (items 3 and 8). Depending on what is broken, you may only need to order one or the other. Both parts, combined, is still only about $20. The part numbers are WB15X10119 and WB15X10120, respectively.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges.
If you have any questions, please post back and let me know. I hope this helps you.
Jul 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The lower handle retainer is broke
If the model number is correct, this is a parts illustration of your oven door:
http://pcappliancerepair.com/model-display.php
If you have any questions, please post back with your and let me know. I hope this helps you
Jun 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I need a new door for this microwave. I have been looking online for hours and can't find just the door. Can anybody give me a website that sells just the door for this micro? Thanks....
The door is available at any of the following websites:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
If the model number you listed this question under is correct, the part number for the ENTIRE door is WB56X10585.
Is there a reason for replacing the entire door? You can purchase individual replacement parts if only a single part on the door is broken. The first three sites on the list have helpful exploded view diagrams to assist you in locating and properly identifying the parts you may need.
The most common thing that fails on these doors is the door handle. If only the handle is broken, the door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The part numbers for the handle on this model are (2 pieces):
WB15X10119
WB15X10120
May 31, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
It's broken
The door handle can easily be replaced on most microwave ovens. You just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to access and/or replace the door handle:
The cost usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. However, price and configuration of your oven also depends upon the MODEL NUMBER. If the model number is correct, the part number for a replacement door handle is WB15X10023.
Jan 29, 2010 | GE JVM1631 Microwave Oven
My door handle is broken. Is it posssible to
You should be able to buy only the door handle and avoid having to replace the entire door. Appliancepartspros.com carries the handle. Just type in the model number you provided and look for item #3 under the parts listing. The part number and price varies based on the color you need. Make sure you order the correct color. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Jul 06, 2009 | GE JVM1640 Microwave Oven
Jvm1350ww 002 Handle broken
The handle part number is WB15X335 and is available from a number of sources online. You can replace the handle alone, but you need to take the inside door panel off to get at the screws. It's been too long since I've worked on a GE to remember if you need any special tools (some ovens have security screws holding things together).
Apr 01, 2009 | GE JVM1350BW/WW/AW/SY Microwave Oven
Broken door handle on GE JVM1490 900 Watts
Go to ;
http://www.appliancepartspros.com/
and enter the model number etc of your unit. Note the diagrams in the left-hand corner of the screen. They also sell parts. Tools will be simple screwdrivers and small wrenches.
Dec 26, 2008 | GE JVM1490 Convection/Microwave Oven
Another broken handle
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
32 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
