Question about Hunter 30245 Quietflo Three-Speed HEPA Air Purifier
Hunter 30400 doesn't turn on
Doesn't turn on
Hunter hepatech 40882 uvc air purifier won't turn after cleaned filters
Hello, this is Ava with Think Crucial.
Filter life counters should be reset each time the filter has change. If your air purifier has a reset button, press and hold the reset button until the lights go out. You may also unplug your unit from the power for 30 seconds before plugging it back on if your unit doesn't have a reset button.
You can purchase a wide variety of high quality Hunter replacement parts for your Hunter Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=hunter
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Oct 24, 2016 | Hunter Air Purifiers
Hunter air filter when you turn it on it keeps cycling- on/off,on/off and wont stay on. also hepa filter button not working any more, does not light up blue when pressed. TY for any help : )
If your unit has a reset button, try resetting your unit. Also, replacing the filters and resetting it after putting on the replacement filters usually works. If this fix doesn't work, I suggest you contact Hunter support for assistance and their number is 888-830-1326.
Ava B.
Oct 01, 2016 | Hunter Air Purifiers
I need a manual & user guide for #30245.
Take a look at this:
http://www.manualslib.com/manual/281057/Hunter-30245.html#manual
Apr 13, 2016 | Hunter Air Purifiers
Who would service hunter air purifier . I have a model 30377. I live in Nanticoke, Penna 18634, it will not turn on.
MFG customer service email But Owner's manual troubleshooting might help figure it out.
no manual? try manualslib.com
Apr 05, 2015 | Hunter Air Purifiers
Hunter Air Purifier making screaming noise
Most likely the problem is a bad bearing in the fan motor.
May 31, 2012 | Hunter Fan Company 30251 Air Purifier
Owner manual for hunter 30747 Air Purifier
You may refer to this online manual for your model number to help you put back the filters in your unit.
Hunter 30747 Instruction Manual
https://www.thinkcrucial.com/search?type=product&q=hunter
Ava B.
May 19, 2012 | Hunter Air Purifiers
Can I get an owners manual for Hunter 30525 air purifier?
Yes, manuals are available from Hunter Air Technical Support. Call: 888-830-1326
Be sure to have the correct Model Number handy, when calling. As some models have been discontinued, but are still supported by Hunter Air.
Hope this helped you.
Apr 21, 2011 | Hunter HEPAtech Air Purifier and Ionizer -...
It will not turn on it says it locked how do i get this off of the screen and get it to turn on quiet flow is the nameof it
Crystal, first turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12-15 minutes before plugging the unit back in. After you plug it in, turn the Master ON/OFF Switch to ON and set the controls as you wish. Hopefully, during that 12 - 15 minute timeout, the unit reset itself and should now work normally.
If that doesn't solve the problem, you can call Hunter Technical Support. In the US dial 888-830-1326.
In Canada dial 866-268-1936
Apr 15, 2011 | Hunter Air Purifiers
Home Depot Switch Doesn't Work. Does anyone know where to get a
Google search Hunter Fan Parts. Should find what you need, and have it in a few days.
Regards, --WoobieDog--
Jul 10, 2009 | Hunter 30216 3-SPEED FLOOR MODEL Air...
Hunter 30245 Quietflo Three-Speed HEPA Air Purifier Logo
Top Hunter Air Purifiers Experts
Steve
Gerry Harvey
Gerry Harvey
Are you a Hunter Air Purifier Expert? Answer questions, earn points and help others
