Question about Milnor 02-03426 - Washer
On the display it states "brake fault must be cleared before restart" how do I do that?
On the display it states "brake fault must be cleared before retart" what do I do?
How do I clear a service emissions message on a 2005 Mercury Mariner with a 3.0L engine. I have performed the required maintenance procedures at both 30,9000090's and 60,000miles. Still have message.
Warning Messages The warning messages can interrupt the display until cleared or reset by the driver. The warning messages are either single cycle, non-resettable, or repetitive warning messages.
The single cycle warning messages display once whenever the ignition switch is turned to the ON position or a fault occurs in a system, and can be cleared by pressing the RESET button. The single cycle warning messages are:
  • liftgate ajar
  • liftgate glass ajar
  • service emission system
  • low brake fluid
  • service brake system
  • check left headlamp
  • check right headlamp
  • check left turn lamps
  • check right turn lamps
  • check left high beam
  • check right high beam
  • check brake lamps
  • check parking lamps
  • washer fluid low
  • check fuel cap
  • change oil soon
  • change oil now
  • low fuel
  • service 4x4
  • turn signal on
Jun 15, 2016 | Mercury Cars & Trucks
My dad has a merits 4 wheel pioneer that flashes 5 times what fault code is this
This flash error code for the dynamic controller indicates a park brake fault. Try moving the brake lever back and forth in each direction to clear the fault. You may have a faulty brake or brake microswitch. You can test the brake with a voltmeter. It should read 40 to 60 ohms and not shorted or open. You can test the microswitch by pushing it and checking for switch closure using a voltmeter. You need to turn the scooter on and off to clear the last fault. Hope this helps.
Mar 08, 2016 | Electric Mobility Merits Pioneer 3 Hd ...
2007 GMC Canyon ABS Fault - Originally ABS Fault started when making a sharp right turn. (ABS Fault light only). Stopping and restarting would clear 'fault' until next hard right. Later, occasional metal...
id check your caliper to see if the piston is compressing all the way if not check your fluid it should be clean not brown or if you have been through large amounts of water if it has gotten into the brake system and check your bleeder valve to check if it has rotted or come lose or if you have a break in the lines or air, most likely your caliper is failing to compress.
Nov 05, 2013 | 2007 GMC Canyon Crew
Hello, our MGE GALAXY 3000 20kva, front panel display is frosen. UPS still operates but not able to use any buttons to see ups status. Also alarm states "internal communication fault". Would appreciate...
you need an MGE expert engineer to check on the internal components, maybe the display by itself it dead can be replaced while UPS is on no problem. if you want to switch off the UPS you go for force shutdown but I cannot guarantee will restart if you do not fix the fault.
Aug 09, 2013 | MGE Galaxy 3000 UPS System
P1748
Code 1748 states 2/4 brake solenoid open circuit, short to ground or battery. Which means that either a power wire or ground wire to the connector is not making a loop. It also may mean that the Solenoid does not have continuity and the solenoid is bad. Test for continuity before condemning the solenoid.
Code 0607 states powertrain performance issues. This Code may be married to the first fault and may clear when the first issue is fixed.
I hope my solution is useful.
Aug 11, 2012 | 2004 Land Rover Range Rover
GE error E61
E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code "E00"shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error "E00"code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine
credit to the original author of this solution rcadieux4444
Jun 30, 2012 | Computers & Internet
Volvo V-70 drivetrain & electronics faults
I suspect you have some loose connections or shorts in the wiring harness. I've had similar strange things happen with an Olds Bravada. Various transmission shifting problems, faults, etc. that all seemed to come from the engine's computer system getting incorrect voltages and readings due to wiring faults/shorts.
Dec 16, 2011 | Cars & Trucks
Truck displaying "TBC FAULT" while driving. What
It may possibly store DTCs. If not.. PINPOINT TEST H: THE INSTRUMENT CLUSTER DISPLAYS "TBC FAULT"
Test Step Result / Action to Take
H1 CHECK FOR THE PRESENCE OF A TRAILER BRAKE CONTROL (TBC) MODULE AND BRAKE PRESSURE TRANSDUCER
Verify that the vehicle is equipped with a TBC module in the instrument panel and a brake pressure transducer on the master cylinder.
Is the vehicle equipped with a TBC module and a brake pressure transducer?
Yes
GO to H2.
No
If the vehicle has a brake pressure transducer but not a TBC module, INSTALL a TBC module. CLEAR the DTCs. REPEAT the self-test.
- If the vehicle has a TBC module but does not have a brake pressure transducer, GO to H4 .
- If the vehicle has neither a TBC module nor a brake pressure transducer, GO to H3 .
H2 CHECK TBC MODULE COMMUNICATIONS
Using the scan tool, access the TBC module. Does the scan tool communicate with the TBC module?
Yes
VERIFY that the instrument cluster is configured correctly, RECONFIGURE as necessary. REFER to Programmable Parameters in this section.
No
Go To Pinpoint Test a.
H3 CHECK THE VEHICLE BUILD INFORMATION
Verify that the vehicle is supposed to be equipped with a TBC module.
Is the vehicle supposed to be equipped with a TBC module?
Yes
INSTALL a trailer brake retrofit kit. CLEAR the DTCs. REPEAT the self-test.
No
H4 CHECK THE VEHICLE BUILD INFORMATION
Yes
INSTALL a brake pressure transducer. Make sure to LUBRICATE the O-ring seal with clean, specified brake fluid before installation. RECONFIGURE the instrument cluster for trailer brakes, REFER to Programmable Parameters in this section. CLEAR the DTCs. REPEAT the self-test.
No
REMOVE the TBC module and install the storage bin.
Hope this helps; keep us updated.
Jan 17, 2011 | 2007 Ford Super Duty King Ranch
The power lite goes on and off and screen wont lite up
telepathy do not work, you need to state what computer brand, what model, what monitor, meantime follow that procedure:
1. switch off computer and monitor
2. disconnect all cables on the back of the computer and monitor
3. re-connect all cables
4. re-power your monitor (is light on? any message on the screen?)
5. re-power your computer - is there any activity on the screen?
if there is no joy:
6. change monitor for known working one and check for display,
7. connect your monitor to known working computer,
is there a display on your monitor? is there a display on borrowed monitor?
if there is display on borrowed monitor, that mean that your monitor is at fault, especially if your monitor do not work on another machine.
if neither monitor work on your machine but both work on other, this will indicate video card at fault (most probable) or motherboard, or memory all of these need to be assessed before further proceedig can be advised.
before further help is sought, state clearly what computer, motherboard type and model (all in one?), video card model, monitor model
if you find this advice helpful, vote for me
Jul 31, 2010 | Computers & Internet
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Milnor 02-03426 - Washer Logo
55 people viewed this question
Top Milnor Washing Machines Experts
Are you a Milnor Washing Machine Expert? Answer questions, earn points and help others
