Question about Minolta magicolor 2400W Laser Printer
Says no toner but it's a new cartridge
Pls help - thanks
  • Minolta Master
  • 6,696 Answers
3rd party? Clean the contacts under the I/u with alcohol. Reseat may have a bad I/u
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Dec 30, 2014
Its me again,after the user changed a new toner cartridge after few copies there is a dark back ground in copy.before replacing the toner the copy was perfect pls help me in this problem
Hi, After a few copies, the toner supply unit pulls more toner, which results in dark copies. To fix this, you have to reduce the contrast (to minimum). Also, make sure that there is no excess toner within the toner supply unit.
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
Sep 27, 2011 | Panasonic Workio DP-4530 Copier
I replaced already new toner cartridge for my brother fax machine mfc-7220 but still the on screen message is appearing on the display "TONER LIFE END". Pls help me to solve this problem. Tnx and God bless...
I replaced already new toner cartridge for my brother fax machine mfc-2820 but still the on screen message is appearing on the display "TONER LIFE END".
Apr 12, 2010 | Panasonic KX-FL541 Plain Paper Laser Fax
Toner Cart chip reset for Ricoh Aficeo sp c400dn
I believe you will need to purchase and install a reset chip. You can find them for the Ricoh C410 here at www.cfriends.com (that links straight tothe ricoh page - but if you need to search, type in "c410" into the search field on their site).
Jan 03, 2009 | Ricoh Aficio SP C410DN Laser Printer
Toners c1100 epson
Yes this one is a pain.
On the LCD display choose the 'Reset Menu'
Then within that menu keep going through the (many) options till you get to
'Change Toner M' (if it is Magenta)
or 'Change Toner C' (if it is Cyan)
etcetera.
Once you select the appropriate 'Change Toner' it will rotate to offer the correct toner. Open up the lid at the front (the word Epson is on it). Reach inside and change the position of the coloured part of the toner cartridge on the right to the Unlock symbol and then ease the cartridge out. It comes out at a slight angle as the part you move to unlock it comes out slightly in front of the other side.
Then put the new toner cartridge in and turn the coloured part to the locked symbol and close up.
The same process will allow you to move any of the toners in and out.
Cheers
Jul 04, 2008 | Epson Aculaser C1100 Printer
How to rotate toners
To rotate the toners:
1 press the down arrow until reset menu appears press the right hand arrow once
2 Scroll through the menu until change toner appears.
3 Toner C appears first continue scrolling until you reach the desired toner eg K for black then.
4 Press the right hand button and the red light will appear on yhe main button.
5 Open front door and change toner.
Works for me after hours of searching. Hope it works for you.
Jul 03, 2008 | Epson Aculaser C1100 Printer
HP Laserjet 4100N saying toner is low when it isn't
yes Is there a sensor in the printer and in the toner cartridge that tells the printer when the toner is low. if u r using new cartridge it indicates perfectly.if u r using refilled cartridge the indication is not always perfect.so u do one thing use your cartridge till u think the printout is perfect do not worry about this messages this is common in many printers.if this solution helps u pls rate it as "fixya" thank u for using fixya.good luck.
Jun 11, 2008 | HP LaserJet 4100n Printer
Toner c8061x
If the line only prints with your new toner cartridge that means that the cartridge is defective. You can inspect the drum to see if there is something stuck in the center of it. If not, try to return it and get another one.
Aug 23, 2007 | HP LaserJet 4100dtn Printer
Minolta magicolor 2400W Laser Printer Logo
24 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
