Question about Schwinn 140 Upright Exercise Bike
How to remove the pedal arm on the Schwinn 140 exercise bike
  • 50 Answers
SOURCE: My Schwinn 230 Recumbent bike makes a clanking
try the bearings.
Posted on Mar 03, 2009
voodoomox
  • 1689 Answers
SOURCE: I need an owners manual for the Schwinn DX900
here you go,
hope this is what you are looking for.
http://download.dfxi.com/supportdocs/OM/Schwinn/SCH_DX900_OM_web.pdf
regards,
voodoo
Posted on Jun 29, 2009
SOURCE: the resistance belt on my Schwinn 205p recumbent
http://www.fitnessrepairparts.com/equipment/SelectEquipment/100 lists all the parts for this model
Posted on Jan 03, 2010
SOURCE: I don't know how to adjust schwinn medallion
I have a Schwinn Medallion also and I might be able to help you. I have had mine a LONG time and right now it is squeaking and I can not find where to oil it. You may have gotten an answer by now.
Posted on Aug 19, 2010
Elessaelle
  • 122 Answers
SOURCE: I was given a Schwinn
You can download manual here :)
Posted on Sep 07, 2011
Testimonial: "Thank you very much. I may be back for more help when I start putting the bike together. But for now I appreciate the manual."
Tip
How to replace a chain with master link on a Schwinn Airdyne
Airdyne Chain Replacement with Master link
This video will demonstrate how to replace the chain with master link on a Schwinn Airdyne.
  • First remove the cotter pin and clevis pin from the user's right handlebar. Then lower the connecting arm and handlebar.
Caution: be sure to hold the handlebar as it will come loose after removal of the above parts.
  • Remove the connecting arm and pedal and crank arm by removing the wedge pin. To simplify this process loosen the nut and tap on it with a small hammer until the pin is loosened.
  • Remove the nut, wedge pin, crank arm and connecting arm.
  • Next remove the chain guard; there are three screws attaching it as shown in the video.
  • Remove the chain by locating the master link. Remove the lock pin and the cover, and then disconnect the chain.
  • Place the new chain on the sprockets as shown in the video.
  • Install the master link, cover and lock.
  • Re-install the chain guard and attaching screws.
  • Re-assemble the connecting arm to the handlebar and eccentric.
  • Be sure the brass bushing is installed in the front inner side of the connecting arm before installing the clevis pin and cotter pin.
  • Install the crank arm with pedal.
Be sure when completing this step that the crank arm is installed in the opposite position as the users left side crank arm.
  • Install the nut onto the wedge pin and tighten.
  • This completes the procedure.
Replacing Schwinn Airdyne Chain with Master Link
on May 23, 2016 | Schwinn Airdyne Exercise Bike
Tip
Identifying Your Schwinn Airdyne
How To Identify the Model of a Schwinn Airdyne Exercise Bike
  • We'd like to share some characteristics of the Schwinn Airdyne bikes that can be used to help you identify the model of your Airdyne bike.
What size/type fan does it have? Is it a spoke fan like a bicycle wheel or short wide blade fan?
Does your Airdyne bike have two chains or a chain and a belt?
  • AD3, AD4 bikes have two chains.
  • AD Pro/Comp and AD Evolution Pro/Comp bikes have a chain and a belt.
How do the crank arms attach to the Airdyne, by wedge pin or bolt?
  • AD3, AD4 and certain AD Pro/Comp crank arms attach by wedge pin.
  • Certain AD Pro/Comp bikes have crank arms that attach by bolt.
  • AD Evolution Pro/Comp bikes have crank arms that attach by bolt.
How To Identify the Model of Schwinn Airdyne Bike
on Mar 11, 2015 | Schwinn Original Airdyne
Petals turn freely with no resistance... is there a chain or belt?
if the pedals are direct to the wheel , there will be no chain
if the pedal arms are back from the wheel , it will be a chain which has probably broken or come off the cogs under the covers
The fix will be to remove the covers and see what has happened
Dec 31, 2015 | Schwinn 220 Recumbent Exercise Bike - 2012...
How do you remove pedal arms on schwhinn biodyne 220 so the shroud can be removed?
There should be a circular insert at the shroud that the crank arms for the pedals go through. It took me a little careful work to pop the inserts out of the shroud. This leaves a just enough space to carefully squeeze the shroud over the pedals allowing access to the interior. Its a tight fit and may require tackling it from different angles to get the shroud off. It can be done, but be careful not to apply too much pressure resulting the cracking off the shroud.
May 26, 2014 | Schwinn 220 Recumbent Exercise Bike - 2012...
What's the best exercise bike there is?
According to me, one of the best Exercise Bike is Fitness form S20 Indoor Cycle Bike. It has adjustable resistance level and adjustable horizontal or vertical seats also. It provides the pulse, distance and speed or has roller wheels to move around easily. In this bike, you can also get a warranty of 12 months.
Aug 09, 2012 | Exercise & Fitness
I want to download a Schwinn 240 recumbent exercise bike manual
Hi m sahlins...
Go to the following webpage and download your owners manual
Please take time to rate me
http://download.dfxi.com/supportdocs/OM/Schwinn/SCH.140-240.OM.pdf
Sep 19, 2011 | Cycling
Have a Schwinn xr7 exerciser bike, need new pedals or straps
I am not sure what type of bike you have (did not bother looking it up), but I myself too have a schwinn exercise bike (recumbent) and the straps recently broke, and when I sent customer service an email from their site they said they sell replacement straps.
I included the kind of bike I had when I inquired so the price given to me might be exclusive to my bike only, so you'll have to contact customer support yourself to see if they sell replacement straps for your bike and if so how much.
Mar 15, 2009 | Cycling
Schwinn 140 Upright Exercise Bike Logo
43 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
