Hi I have a Goodman's gdvd68, need in car power supply
Green light on charger not illuminate and unit will not receive charge
SOURCE: Mitac mio 168 non charging problem
I sent my battery back and it was replaced by the supplier. The unit is fine now so the only conclusion I can come to is that it is due to a faulty battery....
Posted on Feb 06, 2008
SOURCE: TomTom ONE XL will not power up or charge in my vehicle.
I have the same problem and it is not the fuse, as the adapter light is red in two different vehicles, it's getting power, but the light should be green. I plug it into my computer and it gets power, but I can't get past the boot up screen. Piece of work.
Posted on Oct 25, 2008
thegoshem
  • 61 Answers
SOURCE: Green light flashing on back of unit near power cord also green light flashing on motherboard near power supply plug in.
I would suggest trying to replace the power supply. If that does not fix the issue, i would need to hear more about the computer.
Posted on May 06, 2009
SOURCE: TomTom will not charge with car charger
Mine does the same, the light comes on on the charger, but not on the TomTom unit itself. There is clearly a loose connection in the cable somewhere as you can twist the flex and make it work, although this is not very reliable.
I just use a USB charger from an old phone instead.
Posted on Oct 30, 2009
SOURCE: Garmin 760 not charging or
The problem sounds very similar to what I have experinced on several occasions with my wife's 765T. It has to do with a poorly designed cradle.
I have gone through 3 so far under warranty. Now it has happened again and I am out od waarranty. Depending on the cost, I may just get another unit.
Posted on Nov 29, 2010
I have a garman Nubia 1490. Works OK but will not charge battery when plug into car charger. Have used charger from unit supplied.
Do other devices work from your cigarette lighter? If so, check to see if the red light is illuminated on the charger. If the light is not on, the fuse in it is either bad or the charger is defective. It is not economically worth while to have the charger fixed if it is bad. If your GPS does not use a traffic receiver that is embedded in the charging cable, then any cigarette lighter charger with the right plug for your GPS will work. Otherwise, buy either an OEM or after market replacement.
Mar 22, 2017 | Garmin Nuvi 1490LMT GPS Receiver
Charge led on pl70 usb charge lead won't illuminate at all
Most likely the actual charger unit has failed and is not supplying power to the cable or LED, therefore no charging will be possible. Buy a new charger unit.
Aug 11, 2014 | Samsung Pl70 Silver
The charger/traffic receiver glows green but it does not charge the unit. How can i test whether the fault is a, the charger, b the cradle or c, the unit
hi,
1st of all let me say im on my 3 cradle now for my 760 because the connection inside the cradle where it mounts to the board is pretty poor.
since you said the traffic/charger has the green light lite, that means the charging part of it is working.
you can verify if its the cradle or the connection on the bottom of the gps where the cradle mounts by using the usb cable supplied with your garmin.
plug it in for a while, then check the battery meter after you unplug it..if its charging, the meter would have risen beyond what it was before you tried to charge it. the same can be done with a regular garmin charger (the one that uses the usb connection for the car charger to charge it)
bill
Apr 12, 2010 | Garmin (010-00583-00) for nuvi 750/760/770
Tom Tom not working
hold the power on button down until it turns on, does this help, also being plugged into charger with green light coming on normally means that the unit is charged.
Jun 21, 2009 | Tomtom ONE GPS Receiver
Tom tom will not charge using 12 volt charger
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
Nov 17, 2008 | Tomtom ONE GPS Receiver
your fuse is burnt up to your cigarette lighter power supply try it in another car
Jul 12, 2008 | Tomtom One XL GPS Receiver
Will not charge in car
Pilki i have the same problem, though with the original items.
Jun 24, 2008 | Tomtom GO 910 GPS Receiver
Jan 18, 2008 | Mitac Mio 168 Pocket PC
TOMTOM GO 710
Could be a loose contact at the connection between the wire and at the gps unit.
Think the green light must be on at the charger port and also on the gps unit.
This green light can be found near the power button on the gps unit.
Nov 22, 2007 | Tomtom GO 700 GPS Receiver
20 people viewed this question
 Grubhead
Grubhead
