Question about Whirlpool Dryers
Hello, My fairly new whirlpool gas dryer does not heat. I replaced the thermal fuse a month ago and the heating problem was resolved, now no heat again, thermal fuse was tested good. The igniter will turn bright orange which then ignites a large blue flame, the flame shuts down 5-10secs later with no heat. Help, joe
  • 97 Answers
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 24, 2009
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
Whirlpool gas dryer lg7681 heat
There are several thermal safety fuses in dryers which once blown have to be replaced. But, more importantly, they normally blow for a reason and simply replacing one without resolving the underlying problem of overheating will simply cause another failure. Lint is the normal culprit; vacuum and forced air to clean everything out. WITH THE POWER CORD UNPLUGGED and the leads temporarily disconnected, check continuity on each of the thermal fuses (they look like a stainless steel hat that might fit on a Barbie doll. Some dryers have four or five.).
Sep 11, 2013 | Whirlpool GGQ8831L Gas Dryer
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    Have a gas dryer that is not heating up what could the problem be
    Hello- The usual issue is either the ignitor or the thermal fuse. These are fairly easy to test and replace if you have experience with taking the dryer apart. If not, it's best to get a Tech out to look at it. Here is a link to the breakdown of the unit: http://www.reliableparts.com/models/99342
    Sep 24, 2010 | Whirlpool LGR5636L Gas Dryer
    Dryer is not heating
    i replace the thermal fuse kit 2 month ago and my dryer was working good but 2 days ago stop heating again so i did replaced the thermal fuse again and i did some lint cleaning but this time it only last about 20 min. and stop heating again.what could be the problem?
    Mar 01, 2010 | Whirlpool Inglis IP8200 Dryer
    Does not heat ; timer OK, natural gas dryer gas
    In most cases, a failure to heat is caused by a blown thermal fuse or high limit thermostat. Usually it is the fuse, but the fuse may be blown due to a defective thermostat. To find the location on your specific machine (and purchase the parts) try www.appliancepartspros.com To test the fuse, WITH THE MACHINE UNPLUGGED, put an ohmmeter or continuity tester across the fuse with it's wires unhooked. It should have continuity. If it is open, replace it. If the thermal fuse blows, it is fairly common to find the dryer vent partially blocked as well. Make sure it is clear. Thermal fuses are fairly cheap, but you don't want to have to replace it every other week. Good luck.
    Jan 03, 2010 | Washing Machines
    Dryer wont heat up already replaced thermal fuse
    You gas coils are probably old and weak. check this out
    Gas dryer works and quits
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Apr 11, 2009 | Whirlpool Dryers
    Gas Dryer quit heating today
    Just click below;
    If your dryer doesn't heat, check these:
    Igniter
    Gas valve coils
    Thermal fuse
    Hope it may help you;
    Regards;
    VOTIT
    Jan 28, 2009 | Whirlpool LGR8648 Gas Dryer
    Whirlpool gas dryer runs but won't heat
    hi stella. yes the problem is with the thermal fuse. when you were cleaning the vent at the left. the thermal fuse is right there, on the air duct, a small piece of plastic with 2 blue wires to it . replace the thermal fuse . thanks the appliance doc
    Oct 06, 2008 | Whirlpool LGR7646E Dryer
    Whirlpool Gold Ultimate Care II: No heat
    didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
    Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
    Dryers Logo
    77 people viewed this question
    Top Whirlpool Dryers Experts
    Tim Whalen
    Sal De
    Craig Butler
    Craig Butler
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
