Question about Mitaki japan Indoor/outdoor Weather Station
Outside temp Does not show on display
Overhead Outside Temp Display Not working
Check the wiring plug that goes into the back of the mirror. They come unplugged sometimes.
Jan 12, 2010 | 1999 Pontiac Montana
2001 VW Beetle TDI. Why does my LCD,outside temp. display,above the rearview mirror, show four dashes all the time(----)?
outdoor temp sensor probably loose connection/failed. The outside air temp sensor is on the bottom drivers side of the grill. Find it and probe it w/ a multimeter. 0.0, or infinite resistance means the sensor is shot.
Also make sure you are getting power from the harness
Dec 22, 2009 | 2001 Volkswagen Beetle
Climate control display for Outside temperature
Had the same problem, replaced the ambient air temp sensor in front of the radiator. Cost is like 10-15 bucks. Don't worry if temp doesn't change right away. Took me about 5 miles and then it worked great.
Sep 13, 2009 | 1999 Oldsmobile Intrigue
Reset Heating/ AIr cond temp display as well as EXT temp ????
the temp display can be switched between celsius and farenheit readings, since the car is from europe the default is celsius, The manual has instructions on changing back, You have to hold 2 buttons on the display per the manual.
May 07, 2009 | 2003 Land Rover Discovery
1999 VW Beetle outside temp display not working
For general awareness, the outside air temperature sensor is located above the inside mirror.
Try to reset the temperature measurement unit: 1. Switch engine on. 2. Press and hold clock minute (min) and hour (h) buttons simultaneoutly longer than 3 seconds. The display will show new temperature measurement unit.
Apr 03, 2009 | 2000 Volkswagen Beetle
Outside temp guage is wrong
clean the connections from the sensor, one of the is probably corroded just enough to add resistance.
Jan 16, 2009 | Car Audio & Video
Mitaki japan Indoor/outdoor Weather Station Logo
26 people viewed this question
Top Mitaki Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Mitaki Measuring Tool and Sensor Expert? Answer questions, earn points and help others
