Watches Logo
A
Anonymous Posted on Mar 18, 2014
247143NX HOW GENIUE IS THE WATCH?
1helpful
I have a sweda watch with no battery. The only identification is that the front says "Lifeline". Can you "best guess" at a compatible battery?
I can't find much on the watch. Sweda is one company, and Lifeline is another.
https://www.google.com/search?q=Sweda+Lifeline+watch
Look inside the watch and look for an engraved number near the battery socket. If nothing there, a local jeweler will have a battery that fits the space. Voltage is 1.55 volts, silver oxide are best.
Watch Battery Size Chart - 377 Watch Battery Replacement
Ad·https://www.microbattery.com/watchbatteries
For batteries at low prices, shop Microbattery for high quality watch battery replacements. Watch batteries from the top manufacturers like Murata, Renata, Energizer, and Seizeken.
‎Changing Watch Batteries · ‎364 Watch Batteries · ‎Closeout · ‎Browse All Watch Straps
Oct 14, 2022 • The Watches
How do i change the battery of a Bulova 96L37 watch
1. Take the watch off your wrist and turn the watch so that the back of the watch is facing up.
2. Use a watch case opener or a small flathead screwdriver to remove the back of the watch.
3. Carefully take out the old battery and discard it properly.
4. Insert the new battery, making sure the plus and minus signs line up with the corresponding symbols in the watch.
5. Securely close the back of the watch.
6. Put the watch back on your wrist and you're done.
1helpful
We bought the Fossil Brown rectangle watch model FS4284, it stopped working so thought it was the battery. we replaced the battery and then 2 months later it's not working again, faulty battery or is...
  • Change the battery. If your watch stops ticking, chances are the watch is not broken and the battery simply needs to be replaced. You can purchase a watch battery at your local department store or drugstore. Use the screwdriver to pry the back off the watch and place the new battery in the same place where the old one fit.
  • Step 2 If your watch is still not working, determine the problem. If you can hear the watch ticking but the hands are not moving, there may be a gear stuck inside. If only one of the hands does not move, the hand itself could be broken. Once you determine the problem, you can see whether it makes more sense to purchase a new watch or get the old one fixed.
  • Step 3 Check your watch warranty. If your Fossil watch came with a warranty that is not yet expired, Fossil will fix your watch if you send it to the company and pay for shipping and handling. See the "Resources" section below to fill out the Watch Repair Form provided by Fossil.com. If your watch strap is broken, however, Fossil will charge you a fee as broken straps are not covered in the warranty.
  • Step 4 Check a competing local watch repair store. There are watch repair stores located all over the United States that will repair a Fossil watch if your watch is no longer under warranty or if you do not want to pay the shipping and handling to send the watch to Fossil's watch repair department. Although the watch repair store may not have the exact strap you are looking for, it may offer a replacement strap that is similar to the one that originally came with your watch.
  • Step 5 Return the watch to the store where you bought it. If you purchased a Fossil watch that was broken when you purchased it or broke recently after you brought it home, you may be able to return the watch for a refund or store credit. Check with the store's policy before purchasing the watch if you are concerned about returns.
  • 0helpful
    2answers
    My watch has stopped working
    mcdevito75 here, Unless you have a good knowledge of takeing apart, even just the back off your watch / pocket watch it"s best to look for a small watch repair shop in your area, but here is what you can do to possibly start your watch / pocket watch. If your watch / pocket watch hasn"t been wound in some time and that time varies from watch to watch, the oil in the watch can become a bit thick so as to not allow the mechanism to work smoothly, leave the watch / pocket watch in a warm place, window sill in the sunlight wrapped in a paper towel for anywhere between a few minutes to 1/2 hour, after the watch / pocket watch has been warmed up hopefully the oil in the mechanism has liquified enough to allow the movement to start working. You can also give the movement a little boost, after the watch /pocket watch is warm, pull out the stem as if to set the time of day, move the stem and hands, sometimes this action will get the watch ticking again. If this fails, BEST BET specially if this is an expebsive or keepsake watch, look for a small watch repair shop in your area for serviveing. approx. $45.00
    Top Cartier Watches Experts
    k24674
    john h
    ADMIN Andrew
    ADMIN Andrew
    Are you a Cartier Watch Expert? Answer questions, earn points and help others
