Question about Humidifiers
Humidifier vapor won't rise
Vapor won't rise
Where do the vapor pads go
most humidifiers have an area near the vaor outlet to set the vaor pads. as the vapor comes out it creates an effect that allows the essence of the vapor to be released and rides along with the vapor. see if there is a flat spot or an area that the pads would sit. Please always keep manuals or instructions. I keep mine in a file in the drawer that is easy to find them. I just label it "MANUALS".. If I replace a unit I find the instructions and toss them
Feb 27, 2015 | Vicks Ultrasonic V5100 Humidifier
WHERE CAN I BUY VICKS WARM STEAM VAPORIZER
Problems in a Vicks Warm Steam Vaporizer comes when it is mis-handled or when we buy non-warranted products. It is the best solution to spend money on the branded and cheap vaporizers.
http://www.vaporizerchief.com
Cheap Vaporizers Herbal Vaporizers For Sale
Jan 21, 2014 | Vicks Warm Steam Vaporizer 1.5 Gallon...
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Mar 25, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Use vick's vaporizer with "fog juice"?
Hi no i would buy some smoke pellets for a smoke test they have more power to do the job save the vick for when you have a cold .............
Feb 04, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vaporizer That Works?
Have you tried adding salt to the water in the vaporizer? Sometimes the water needs to minerals for the humidifier to work...I add sea salt to mine every time I fill it.
Oct 12, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Runs, but nothing comes out
Check the filters and the fan blade it may have come loose. Do you still hear the motor running? Get me the model number on the unit. Sorry it took so long to get back to you I have been sick the past few months.
Aug 30, 2008 | Bemis 526 300 Humidifier
Air o swiss 7133 doesn't send out any vapor
Interestingly enough as soon as I posted here, I was able to find the source of the problem. It appears that during cleaning the water level sensor, a bobber which normally floats as the water level rises, became stuck the to bottom of the water base - see below for the picture. I was able to use a small wooden spoon to lightly apply pressure and release the bobber so that it could float, and instantly the vapor started flowing again.
Aug 24, 2008 | Air-O-Swiss 7133 Humidifier
Humidifiers Logo
54 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
