Question about Epson Stylus Pro 4800 Color Photo Printer (C593001UCM)
Mnt req 0002
How to clear
Sannce DVR-DH81NK1T i am lock out need code or password
Connect dvr to local network
boot up the dvr
connect to local network with a computer (eg Mac)
login into admin screen of your router to identify the assigned ip address of the router
start a terminal session
telnet to the ip address
default user name : root
default password : xc3511
mbaad@MBAADs-MacBook-Air:~$ telnet 192.168.0.3
Trying 192.168.0.3...
Connected to 192.168.0.3.
Escape character is '^]'.
YourCCTVDVR login: root
Password:
BusyBox v1.16.1 (2014-12-24 15:47:14 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
Welcome to Monitor Tech.
[root@YourCCTVDVR /]$ cd /
[root@YourCCTVDVR /]$ ls
bin etc linuxrc proc share usr
boot home mnt root slv var
dev lib opt sbin sys
[root@YourCCTVDVR /]$ cd mnt
[root@YourCCTVDVR /mnt]$ ls
custom dvs logo mtd usb web
[root@YourCCTVDVR /mnt]$ cd mtd
[root@YourCCTVDVR mtd]$ ls
Config Log
[root@YourCCTVDVR mtd]$ cd Config
[root@YourCCTVDVR Config]$ ls
Account1 StorageCfg network
HvrMode SysComs ppp
Json SysTime resolv.conf
RT2870STA.dat dhcp.cfg uboot_env_lang_video
There will be an Account## file for each account you have set up
Remove all of these files
[root@YourCCTVDVR Config]$ rm Account1
Reboot your dvr box and it is at the first setup screen
Here are the commands - note you can't send password as part of the telnet command
telnet 192.168.0.XX
root
xc3511
cd /mnt/mtd/Config
rm Account*
exit
CCTV Networking Technical Support
Apr 10, 2017 | Home Security
Hard drive is not acessible
On another computer download and then burn the Knoppix disk.
Boot the Knoppix disk. Key ctl>alt>f1 to get to console session. Use cfdisk as follows:
cfdisk /dev/sda
or
cfdisk /dev/hda
One of these should you a listing of the partitions on your hard disk. Mount the main partition thus:
mount /dev/sda1 /mnt
or
mount /dev/hda1 /mnt
cd /mnt
Now you can search the partition and save files as needed.
Jan 19, 2013 | HP Computers & Internet
MNT TK NEAR FULL what should I do replace mnt tk or cleaning the tank?
maintenance tank problem Epson 4880
I have my Epson pro 4880 down for four weeks. The Maintenance tank is rejected by printer. I bought brand new waste tank sensor and chips still says: "NO MNT TNK" it also would let do media setting through Epson LFP remote panel at all. I need help of what may be wrong. please???
Nov 16, 2012 | Epson 4880 Stylus Pro InkJet Printer
Error code E0000001-0002
That's a fuser temperature code that will need to be cleared in service mode. Press the additional functions key * then press 2
Mar 13, 2012 | Canon imageRUNNER 2200
I am getting a MNT REQ. 0400 message. There is a W on the line below in the 4th space to right of the paper feed symbol. Sometimes if I turn machine off and on again I get a SERVICE REQUIRED 0001001B...
Hi Kate,
This is Randy. I've received your email and I'm working on a solution for you. You should be hearing from me shortly. I'm also reachable on the chat feature.
Thank you,
Randy
Jan 05, 2012 | Epson Stylus Pro 4000 InkJet Printer
I have an iomega lphd-up external drive it was working fine now it is saying that it needs to be fomated plugged in to several laptops i get the same message. i dont wanna lose the content. what can i do?
Try getting a live cd (such as the system rescue cd). Burn the .iso file to a disk, then boot from the CD by hitting a key at your BIOS menu (usually F1 or F9) to bring up the boot menu, and select CD. Once you've booted and you have your prompt, plug in your external drive and try the following commands:
fdisk -l (that will show you all the disks attached to your computer. Typically the first disk [internal] is sda, and the USB disk is sdb.) The thing to take note of here is the last column on the list that contains /dev/sdb#, it should say NTFS, or FAT32, or something like that.
fsck /dev/sdb1 (that will check the file system on the first partition on your external drive. If it comes back with an errory, try fsck.NTFS or fsck.FAT32, whatever the file system was in the first part.)
testdsk /dev/sdb (That will initiate a harddrive test that could find/fix errors with your drive).
If none of that works, plug in another drive to make a backup of your external. Take note that it's important to have free space on the SECOND (not broken) external that is EQUAL TO or GREATER than the amount of USED space on the broken drive.
Once the backup drive is plugged in, type mount /dev/sdc1 /mnt/backup (if that doesn't work or it says something about NTFS and read only, type umount /mnt/backup; ntfs-3g /dev/sdc1 /mnt/backup).
Finally, type mkdir /mnt/backup/SDB to make a directory to store the files.
Now with the second drive, try to mount it using the advice for sdc (although change /mnt/backup to /mnt/windows)
If it mounts, then type rsync -av --progress /mnt/windows /mnt/backup/SDB/ which will start copying all the files onto the backup drive. NOTE: This will cause a lot of text to scroll, and will take a long time!
Once that's finished, you can restart into windows and format your drive, then plug in the extra drive and copy everything back over.
Hopefully that helps!
Jul 20, 2011 | Computers & Internet
Epson 4880- gives error message MNT REQ 0088 on display
This error code means that you have printed so many pages that it's time to get your printer serviced. Kind of how you get your car serviced after so many miles. I'd reccomend bringing it to the nearest printer repair shop. Most will just install a maintenance kit and reset the maintenence count. It will continue to print if you put off getting it serviced but who knows how much longer. It's better to get it done now before it craps out on you and you have to print something really urgent.
May 20, 2011 | Office Equipment & Supplies
Error problem no E000061-0002
The laser shutter is faulty. The laser unit is faulty. The potential measurement
PCB is faulty. The DC controller PCB is faulty.
Mode of
Detection
0001 As the result of potential control, the drum surface potential (VL2)
of the white background is about 200 V (generating solid black images).
0002 The primary charging output used for print output and the drum
surface potential after laser output has been made are about 200 V
Feb 13, 2011 | Canon imageRUNNER 5000 Copier
What is maintenance code 0002 for epson stylus pro 7800 printer still working, just flashing code, cant find ansure to what the code is. Thanks Jim
Maintenance Code 0002 - Carriage Motor/Ink Tube is near end of life (Clear Carriage
Motor Counter)
If you clear the carriage motor counter it should work until the part expires.
Dec 17, 2010 | Office Equipment & Supplies
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
