Question about Bosch Nexxt 300 Series WFMC2201UC
How to acsess diognostic mode
Not starting cycle
Has a code alarm that I can't deactivate
Under the steering wheel it looks like a place to plug in a computer. You can take a paper clip and jumper 2 of the pins( I don't remember which two) when you get the right two the check light will start flashing short and long spaces. the first will be one then two that means diognostic mode after that you can take those numbers and look in the book or call auto zone and they will tell you what they mean.
Mar 15, 2015 | 1985 Oldsmobile 98
I forgot my login password i can not acsess my laptop how can i?
First you will need to enable the built in Administrator account in the operating system. You will find instructions here: http://social.technet.microsoft.com/wiki/contents/articles/3040.enable-disable-the-local-hidden-built-in-administrator-account-in-windows-7.aspx You may need to start in "Safe Mode" to be able to do the steps required to enable this account. Once you enable then log into the Administrator account you can them go to Control Panel - User Accounts - manage accounts and find your account and change the password.
Nov 15, 2014 | Microsoft Windows XP Home Edition
Peugeot 306 52 plate,pulled out the garrage one morning all perfect,left for 30mins tried to start to go to work turns over but wouldn't start,tried everything even diognostic machine of mine and the
Did you check for fuel pressure with a gauge on motor
or scan tool, if that data is avail?
Did you put one of those HEI Spark Plug testers in a plug wire
or cop coil
Do the cams turn
I'm not into the Peugeot, but is expect you may have a timing
belt ?
You may not have data on the ignition switch & its contacts
Do you have battery voltage to the ignition & injectors with key on
Injector pulse when cranking ( crank sensor !!)
Jul 26, 2013 | Cars & Trucks
Cant get internet acsess or sync
use DFU mode while plugged into itunes. Easiest way to do this is by turning it off unplugged. open itunes and then plug it in while holding the home button. then hit restore on itunes when it pops up saying "iphone in recovery mode"
May 25, 2011 | Apple iPhone 4 Black Smartphone
Water keeps running after machine is full of water. it won't start the cycle no matter what load size you choose.
The water level sensor is either bad, or the air line going from the tub to the sensor has become disconnected or clogged, so that the machine never senses it is at the correct water level to start the cycle. Therefore it continues to fill. You will need to acsess this sensor by unplugging the washer and removing screws at back of control panel. Then lift the panel, remove clips to housing, and disconnect lid switch, then inspect the clear rubber air tube, if there is no noticable issuse, replace the sensor.
Nov 27, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My Whirlpool Washer (top load) will not go into the rinse cycle and then finish the rest of the cycles and any setting.
If it fills up and starts the agitation mode (you can hear the motor running), open the hood to verify it is agitating (center post turning back and forth). If it is not phisicaly agitating then you most likely have a defective coupler. (couples the motor to the transmission) They are about $20 and require you to tilt the washer on its back to gain acsess to the bottom at the motor.
Sep 22, 2010 | Whirlpool Washing Machines
Car will not accelorate, engine light comes on and every yhing works but it will not accelorate
the car has proberly gone into limp mode
the car needs to be put on a diognostic machine to read the codes
Jun 20, 2009 | 2004 Nissan Quest
I cannot acsess my down loaded content in sansa m 240
Go to my computer go to sansa and open the media folder and open each sub folder Make sure usb mode is msc
Apr 17, 2009 | SanDisk Sansa m240 MP3 Player
Check light is showing on my dash board,it comes off and on
I think when it starts flashing the car is in "limp home mode" which indicates there is a problem and limits the engine to minimise damage. Best get it to a garage and get it plugged into diognostics equipment.
Mar 04, 2009 | 2001 Audi A6
Bosch Nexxt 300 Series WFMC2201UC Logo
29 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
