Question about Arris Dsr-4402x Professional Satellite Receiver
Diagrams for satellital receiver dsr4402x
Need for diagrams
Diagrams wiring 25768139
Most GM radios are coded to only work in the car with a matching VIN number, so most of the time you cannot do it, sorry to say. Actually, the new ONYX PLUS radio has many more features than the Caddy XM, like remembering the last 30 minutes you've listened to and the ability to pause at a drive-thru, etc. Schematics are next to impossible - back in the 80's Delco would share, but not since.
Aug 18, 2014 | Sirius Satellite Radio Receiver
My blu ray and regular DVD player have sound coming through the tv, but the tv itself on a regular chanel like ESPN, there is no sound. This is a Mitsubishi 73" DLP.
You have completed the proper troubleshooting, and by process of elimination you have determined that there is nothing wrong with your television's sound. The problem lies in cable. The next troubleshooting steps depend upon how you receive your cable channels. If you have a cable box (or a satellite receiver) you may just need to unplug it for 30 seconds to reboot it (or follow the instructions from a cable/satellite company representative on how to properly reboot your particular cable box/satellite receiver model). Also commonly the cable box/satellite receiver is not set to output audio properly. If you are connecting it to the television with an hdmi cable the audio output must be set to hdmi. Also there may be a setting pcm or bitstream. The cable box audio setting normally would have to be changed to pcm.The problem may be with the cable box/satellite receiver itself needing to be replaced or the cable cord connecting it to the television may need to be replaced. It is less likely that the television has a setting the one source input the cable box/satellite receiver is connected to that would affect the sound but confirm that there is or isn't. Last there may be something wrong with the source input you have the cable box/satellite tv receiver connected to.
If you do not have a cable box/satellite tv receiver then rescan your channels, try a different cable cord, and check with the cable company to make sure there is no internal issue at the moment.
May 11, 2011 | Televison & Video
I need to know what they are refering too when they say set top box,is that the sattelite receiver or is it something else,also where can I get diagram hook up for my VO370M TV
set top box can be anything, freeview box, satellite receiver or cable tv box
manual can be found here
http://vizio.com/documents/downloads/hdtv/VO370M/182Manual.pdf
if you found this info useful please vote for me
Apr 11, 2011 | Vizio L37 Television
Need a diagram to hook to tv
Set your receiver to AUX input, go to the the back of the receiver and look for AUX input and connect one end of the 2 RCA cables red and white connect the other end of the red and white cables to the back of your cable or satellite box where it says OUT.
Good luck
N Sabre
Nov 07, 2009 | Denon AVR-681 Receiver
Looking for a diagram on how to hook up my dish network box to my STR-de597
There is a wiring diagram PDF posted on Sony's support site. However it lacks a configuration for a satellite receiver. Without knowing your particular Dish setup, I'd say use the Component video cables and a fiber optic for the audio if you can. Otherwise, the component video and coaxial cables are your next best choice to get decent video and surround capability.
In both cases, you need 2 sets of video cables One for the in and another for the out. You only need 1 fiber optic or coaxial for audio if you do not plan on running the TV speaker system. Use the video 2 inputs for either video type.
Oct 27, 2009 | Sony STR-DE597 Receiver
Cable hook-ups for TV, Satellite Box, DVD, VCR
Use SCART lead from Sat. box to VCR input( so you can record progs.) then another SCART lead from VCR output to TV set AV1 input. Connect DVD (player only I presume) direct to AV2 input of TV set using another SCART lead.
Hope all this works O.K.
Note:- If DVD is also a recorder then you don't need VCR as a recording device and leads will need to be altered accordingly, of course!!
Nov 22, 2008 | Kenwood KR-V7080 Receiver
Combining output from dish home distribution with ota antenna
You should have your system setup in the following manner below:
You also will only be able to receive the HD locals with a HD OTA antenna. It is possible that you will need to turn the satellite off in this room to view the OTA's effectively.
Also you should use a splitter as depicted in the picture by the red boxes to combine signals of this frequency. The blue box is the diplexer on the incoming satellite feed and the black box is the seperator that most dual tuners use. If yours does not utilize this device you will have another cable coming from the outside of the house to the back of the receiver. The location of the ports on the back of the receiver in my diagram may differ in position on your receiver so obviously connect them to the proper port. I hope this ressolves the issue and there is no need to seperaate the signal at the remote tv as it will only be a duplicate of the same signal you have connected already as OTA and the TV2 backfeed are of the same frequency range.
Sep 18, 2008 | DISH Network Televison & Video
Sirius radio
Cliff, If you mean a schematic then u are going to have a tough time finding that. It is manufactured by Directed Electronics, so you might try to contact them, but they might not be willing to divulge that info.
Feb 26, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Trouble with the hooking up wiring for receiver, DVD/VCR combo and satellite to new DLP TV.
Jar50, lacking model numbers for your TV and Satellite, I would suggest connecting your DTV Satellite OPTICAL out to your 65"DLP. Connect your 65"DLP OPTICAL out to your Onkyo TX-DS484 OPTICAL in. If you are using the DIGITAL COAX, just substitute the instructions above from OPTICAL to COAX.
Hope this helps.
Aug 28, 2017 | Onkyo TX-SR803 Receiver
Satellite receiver not respond
Search internet for JTagging sonicview receiver. You will need special equipment.
Sep 02, 2007 | Audio Players & Recorders
Arris Dsr-4402x Professional Satellite Receiver Logo
23 people viewed this question
Top Arris Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Arris Audio Player and Recorder Expert? Answer questions, earn points and help others
