Question about DIGITECH JAM MAN Looper Phrase Sampler
When I plug my guitar in the single does not enter unit
Guitar single does not go through unit peak light will work
4 Suggested Answers
danforddan1
  • 192 Answers
SOURCE: guitar cutting out and distorting
I wish I had more info: Now if you turn off the unit for a while and then turn it back on lets say a few hours and it works good for a while like an hour or so. If this is the prognosis thus far I would say it has a over heating problem. Place the unit on something that will rase it up so air can flow all around it. Try a small fan blowing on the unit this will keep it cooler. If this is the case you don't want to over heat it many times ,if you get my meaning. There all so may be a reason internally that would cause the unit to over heat , if this is really whats going on . It wont cost you anything to give this a shot.I hope it works. Good luck DFD please rate me TK U
Posted on Apr 12, 2009
  • 5603 Answers
SOURCE: no vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
Posted on Apr 28, 2010
  • 5603 Answers
SOURCE: vocalist live 2 problem. power
NO power light or audio from Digitech Vocalist 2 live. Check that your power adapter is for 9 Volts AC (not DC like most pedals) and is rated at 1300ma or more. A DC adapter MAY light up the unit but not make it pass audio. Lights can be lit but that is NOT an indication thaat correct power is applied. They likely use the AC input to generate both positive and negative voltage within the unit. The use of a DC adapter will prevent generating one of these required voltages and prevent audio from passing.
Posted on Jan 14, 2011
Headphone output safety warnings on guitar effects
There is a small chance it "could" but more likely you would just overdrive the input stage to clipping.
You can try it- you need to keep the viltage input to the amp at 1 volt peak to peak or less, or you run the risk of clipping. You should use shielded cable, as you may also pick up other noise along that cable.
Mar 28, 2012 | Roland Boss Gt-10 Guitar Effects Processor...
Guitar hero guitar wont work for xbox
For a wireless guitar, press the Sync buttons on both the guitar and the xbox. (The lights should swirl around the xbox logo on the controller and the power button on the console. The console's button is on the front near the CD drive and the controller's should be near where the xbox logo is). You'll know the pairing was successful if each component suddenly flashes and the controller shows only a single light on.
Dec 25, 2011 | Video Game Consoles & Games
Guitar hero does not work, only flashing control panel but not continue to play
Is this a for a Nintiendo Wii? If so you may need to sync your guitar with the Wii. There is a red
button in the front panel on your Wii and the guitar should have a red sync button. Depress the
red button on the Wii first then depress the button on your guitar. after a few seconds the lights
on your guitar should stop blinking and the guitar should be assigned to controller 1 through 4
once this happns the guitar should start working.
If the guitar is wireless you may need to do the same for other consoles. The guitar may need
to sync with the wireless interface that plugs into the console. The same method applies as
above but the sync button should be on the wirless plug for the controller that plugs into the
console.
May 05, 2011 | Video Game Consoles & Games
I PLUGGED THE GUITAR INTO THE GUITAR INPUT AND PLUGGED ANOTHER JACK INTO THE SEND UNIT TO MY AMPLIFIER BUT CAN'T HEAR ANY SOUND EVEN THOUGH I GET A READING THAT SHOWS SOUND IS HAPPENING. THE OL LIGHT IS...
try this: plug a stereo headphone into send & check if you get something on one side of the headphones (should be left side) if yes check the cable you use, it's possible that a mono plug (as used for guitars) is disabling the send output, using a stereo plug & adaptors may work (especially if you get the sound in the right side of you headphones check also the manual you may find a description how to connect/insert a guitar effect when recording or live mix
Nov 12, 2010 | Tascam Dp-02cf Digital 8-track Recorder
No sound
You would NOT use a stereo cable to plug in your guitar.
The stereo cable would carry the battery voltage back to the amp and MAYBE cause the fuse to blow.
You use a MONO instrument cable for your guitar.
The ring connection is use to complete the circuit to turn on the battery in most guitars.
Replace the fuse ONCE and get the proper instrument cable (NOT consumer audio cable) for your guitar.
If fuse blows again, take amp to shop for service.
May 30, 2010 | Peavey Valveking Head
No vocal sound
Apr 26, 2010 | DIGITECH VOCALIST LIVE 2
Guitar hero world tour guitar for ps3 controller not active.
You can get in touch with the manufacturer and let them know it isn't working properly and they should send you out a replacement. I know a lot of people who have done that before and got a new guitar.
Dec 14, 2009 | Activision Guitar Hero
My Tascam CD GT1 mkii guitar trainer is doing everything except when I plug my guitar into the unit, I can not hear my guitar?
Here is the manual if you don't have one:http://www.tascam.com/details;9,21,23,19.html Make sure your guitar cord is working. Make sure your are plugged into the Guitar/Mike input jack.Do not connect a guitar amp to this jack via line out on the amp or otherwise. Set the Guitar/Mike switch to Guitar. Use the Input control to adjust the level of the input.Adjust your Headphone level using the Output control.Carefully read pages 12, 13, 14 and 15 of the manual.There are various combinations of controls that would make your guitar too quiet to be heard. Example: Mix Balance page 24. Let me know if this helps.
Nov 29, 2009 | Tascam CD Gt1mkii CD Guitar Trainer
Guitar hero 3
Is the guitar wireless, if it is check the batteries.
My friend had a problem with his guitar hero 3 game and was forced to take it back.
Before returning it though and again this only applies if the guitar is wirelss. Have you synched it with the console.
The little button just next to the memory card slots needs to be held in for a few seconds and the same needs to be done on the guitars sync button. If you get 4 gree rings of light when you try and turn the guitar on i'm almost certain its the fact that the guitar isn't synchronised with the console.
Jan 14, 2008 | Microsoft Xbox 360 Console
DIGITECH JAM MAN Looper Phrase Sampler Logo
85 people viewed this question
Top DIGITECH Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a DIGITECH Audio Player and Recorder Expert? Answer questions, earn points and help others
