In hottest part of day it starts blowing hot air. We turn it off for 2-3 hours and comes back on anabnd blows cold air again. Technician unable to determine problem. Says we should buy all new unit. Current unit 10 years old. Coolent level ok. Coils clean. This is a 2 ton small unit cools our master suite only. Our other unit is 4 tons and cools rest of house with no problem.
    President:
  • 2,187 Answers
For this case, either the AC needs cleaning or the compressor may be week.  You may want to check on the thermostat, it may send signal to the unit to stop cooling.  If it is a split type AC, you may want to check for leaks in the tubes that connect the 2 halves of the AC if it is ok but still cleaning and the AC motor may be the culprit.  Other irregularities observed may help in the diagnosis.
Posted on Jun 14, 2009
I have a Frigidaire FAM18HS2A and when I turn on the heater, sometimes it blows hot air but most of the time it blows cold air. what is wrong and can it be fixed
if your frigidaire is not a inverter,he doesn-t work at outside temperature down -5.if it is a inverter you don-t have enought freon .
Dec 18, 2013 | Frigidaire Heating & Cooling
Air conditioner starts out blowing cold air,apparently actuator sticks causing the system to blow very hot air. Hours later a/c blows very cold air again, only to blow wry hot air again after about 30...
1.)If your System is OVERCHARGED this Will Occure due to the EVAPERATOR FREEZING UP
2.) Also if your HVAC Control Modual is Malfunctioning this will Aslo Cause this Condition, It Controls the BLEND DOORS that OPEN for COLD or HOT AIR Look Into these Items and Also Look Into wethrt the A/C Compressor Cycles OFF when it GETS OFF this Will POINT at the HVAC CONTROLER if it Cycles Off When Set For A/C or COLD Air
Aug 19, 2010 | Chevrolet C1500 Cars & Trucks
RUUD AC cycles warm & cold 24/7
Hello Anna Sounds like the compressor is overheating and stoping on overload internally.Then it cools down restarts and runs into overload again.I would like to see the freon pressures when running.Could have a clog/restriction in piping.I dont like that you went thru a compressor already, the original installition is suspect.The original (1st) failure cause must be corrected.Check the TXV valve replace, filter/dryer look for a kinked pipe are ideas for overheating.Make sure condenser coil is free (ari flow)& clean also.
Jul 30, 2010 | Ruud UBHC Air Conditioner
I have a 2002 Acura RSX that has AC Problem. Blows very cold air, but not all the time. As long as RPM is running at drive speeds, I have cold air. However, at stop lights the air temp goes warm. If I...
your ac compressor is freezing up try not putting it on cold all the way. put thermostat towards the red jus a lil but still on the cold side to see if that helps
Apr 03, 2010 | 2002 Acura RSX
A/c blows cold then goes to hot air
sounds like a vaccum diaphram may be leaking try listening for hissing noises under dash near the glove box,set blower to lowest setting\off if you can and still have a\c on.
Oct 07, 2008 | 1995 Volvo 850
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
