Question about Table in a Bag Large Wood/Coal Furnace Warms Up To 3,000 Sq. Ft
King Wood Furnace model KF3010A
I need to know how many BTU's my furnace is . I can't find it marked on the furnace
What is the tonnage of a carrier furnace model number 58gp100-2
It can handle five tons, or a 60000 btu ac. Tonnage is a measurment for the ac, 1 ton-12000 btus. The ac dose the cooling. the furnace simply blows the air, so if its a good furnace, and sized right, no need to replace it. Simply add the split system to the existing furnace. If you want the tonnage of the ac size, let me know your homes squarefootage, age, condition. Do NOT include the basement in the sq. ft.
Apr 07, 2015 | Heating & Cooling
Where can I order parts for the King Model KF3010A Wood Furance. I live in Tennessee.
Johnstone supply should be able to get or tell you where to order it .
Nov 18, 2014 | Heating & Cooling
Got induction fan for Volgelzang wood furnace and no instuctions
I don't have one and cant seem to locate one online. You will need to go to a dealer or call them again.
Mar 23, 2014 | Vogelzang Norseman Warm Air Add-On...
Not enough heat coming from my Norseman furnace
I suspect the heat exchanger is caked with soot. The type of wood makes a very big difference in keeping them clean. The top cover is removable to access and clean it. No pallet or treated wood to keep it clean. Don't remove any screws you don't have to.
Dec 12, 2013 | Us Stove Company Vogelzang Norseman Add-On...
How many gallons of propane will I use per month?
Go on to google and use BTU per gallon calculator at Irving energy this will give you the price between them both
Mar 06, 2017 | Heating & Cooling
LOCATION OF 62-24164-01 IGNITOR ON WEATHER KING FURNACE
Who knows? You gotta post a video of your furnace so we can see what you got. Here is the sequence of operation of a late model furnace. they all basically work the same way. They have a draft inducer fan that causes a vacuum in a small hose leading to the pressure switch. If the board reads negative pressure it know the draft motor is working and pulling a draft it then cause the ignitor to kick in and after a minute opens the gas valve. It wait a sec to verify flame with the flame sensor and then if that flame is there it keeps burning and after 30 more seconds the fan kicks in.
Most of the time if the ignitor ain't workin it is either bad or a limit has tripped due to some sort of overheat problem like birdnest or cobwebs and such.
https://www.youtube.com/watch?feature=player_embedded&v=NjOsXv4Z-lg
Oct 05, 2012 | FACTORY AC PARTS Furnace Spark Ignitor...
I have the Model number and serial number but am unable to find the BTU's on mty furnace...Help please?
if you have the model number of the furnace, then you have the btu input of the furnace. The model number usually starts with letters, then the three numbers following the letters are usually the btu input of the furnace.
For instance if it said 075 then it would have an input rating of 75,000 btu/hr or if it said 125 then it would have an input rating of 125,000 btu/hr.
Hope this helps
Nov 16, 2010 | Heating & Cooling
I have a intertherm furnace 60000 btu inlet,
Souns like the thermocouple is gatting weak and needs replacing!
Dec 20, 2009 | Heating & Cooling
Table in a Bag Large Wood/Coal Furnace Warms Up To 3,000 Sq. Ft Logo
91 people viewed this question
Top Table in a Bag Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Table in a Bag Audio Player and Recorder Expert? Answer questions, earn points and help others
