Question about Vehicle Parts & Accessories
Astra codes p0003 fault code
  • 1608 Answers
SOURCE: '09 GMC AcadiaEngline light on, code P0003. Half
Are you sure your code is p0003.I checked all the codes and there is no p0003.Do you mean p0300.This is a misfire code.Also how many miles on your vehicle.If it has under 36k then it is still under warranty and the dealership will repair it under warranty at no charge to you.Let me know.
Posted on Jun 30, 2010
  • 176 Answers
SOURCE: I'm getting obdII codes P0003 and P0004 What
TAKE IT TO AUTOZONE OR ADVACED AUTO PARTS THEY WILL PUT IT ON A COMPUTER FOR FREE; JUST SEE WHAT THEY SAY IT IS ;Fuel volume control circuit controls the amount of voltage to the fuel pump when the fuel rail is pressured up Regulates the Amount of fuel the fuel pump needs to push to stay up with your throttle(ie) YOUR FOOT ON THE GAS
Posted on Aug 30, 2011
ZJLimited
  • 17970 Answers
SOURCE: mk5 astra 0130 fault code
DTC P0130 - 02 Sensor Circuit Malfunction (Bank I Sensor 1)
The O2 sensor produces a voltage based on oxygen content in the exhaust. The voltage varies between .1 and .9 Volts, .1 indicating lean and .9 indicating rich.
The ECM constantly monitors this voltage while in closed loop to determine how much fuel to inject. If the ECM determines that the O2 sensor voltage was too low (less than .4 Volts) for too long (for more than 20 seconds (time varies with model)), this code is set.
Depending if the problem is intermittent or not, there may be no symptoms other than MIL (malfunction indicator lamp) illumination. If the problem is constant, then symptoms may include one or more of the following:
MIL illumination
Engine runs rough, missing or stumbling
Blows black smoke from tail pipe
Engine dies
Poor fuel economy
Usually the cause of P0130 is a bad oxygen sensor, however this isn't always the case. If your o2 sensors haven't been replaced and they are old, it's a good bet that the sensor is the problem. But, It could be caused by any of the following:
Water or corrosion in the connector
Loose terminals in the connector
Wiring burnt on exhaust components
Open or short in the wiring due to rubbing on engine components
Holes in exhaust allowing unmetered oxygen into exhaust system
Unmetered vacuum leak at the engine
Bad o2 sensor
Bad PCM
Check it and keep us updated; feel free to contact us in the code link, if you need additional details.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Posted on Oct 27, 2011
  • 6468 Answers
SOURCE: astra 2007 fault code 0597
that code is usaully from a sticking thermostat
Posted on Mar 24, 2012
alicantecoli
  • 22246 Answers
SOURCE: vauxhall astra auot code P1895 what does it mean
P1895 Engine control module (ECM), actual torque signal - circuit malfunctio
Sell this motor quick ,these are nice cars but suffer for these problems because the computer is bolted to the inlet manifold and gets too hot then cooks ,all these petrol engines from around this time suffer from this fault
Posted on Dec 17, 2013
Hi i have 2004 Holden Astra ,speedo not working,abs light and traction control light stays on , have put.computer on car will not let us in to engine area,has any body got any ideas
what the real problem
faulty diagnostic fault scanner tool
or no engine bay fault codes?
you could toss lots of new parts and not fix the faults
tow to a workshop or DIY fixes are possible if you can know the
specific fault codes
po500 seems to fit
https://www.obd-codes.com/p0500
a few things going wrong for that astra
fixable
speed sensor
wheel sensors faulty /abs module
if auto it will have strange gear changes and brakes unreliable
Oct 17, 2016 | Holden Cars & Trucks
Fault code p0003 on berlingo van and how is it
P0003 Possible Fuel flow regulation fault : Short circuit to earth check wiring
Sep 18, 2014 | Citroen Berlingo Cars & Trucks
Fix chrysler code P0003
P0003 Fuel Volume Regulator Control Circuit Low The link will give you some info about p0003 code. From what I've read, it may be that one of the injector's wiring may be faulty. It is best to have a scan done using a computer scan tool.
Apr 30, 2014 | 2007 Chrysler 300c AWD Sedan New Cars
My Astra CDTi has cut down to tickover and will not rev on throttle fault spanner comes on . It has happened before but cleared by turning ignition off and restarting. Tried this but no joy
run fault codes and check for accelerator position sensor and other related faults. Faults have to be physically fixed so turning the key off and on will do nothing to fix a problem
Dec 23, 2013 | 2005 Opel Astra 1.7
Vauxhall astra auot code P1895 what does it mean
Dec 17, 2013 | 1997 Chevrolet Lumina
Im getting error code 4136 what does it mean and how do i fix it
Are you sure this is an error code...wrong sequence of numbers to be a Moultrie error code...if it has P0003/E4136,ect.= 3 pics taken/4136 events.
Oct 20, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Jun 30, 2010 | 2009 GMC Acadia
Codes 3, 61 on a 2005 dodge magnum
P0003 is fuel circuit volume low and P0061 is 02 sensor bank 2 sensor 3 heater circuit.
Generally a heater code usually means replace the 02 sensor. The heating element popped, kinda like a litght bulb does.
The 03 code will need further diagnosing to determine the exact cause.
Feb 13, 2010 | 2005 Dodge Magnum
Vehicle Parts & Accessories Logo
12 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
