Question about Visual Land - VL-879-8GB-BLK - Connect 7 Tablet
My Visaul Land Connect keeps giving my an error message of "Please make sure you have update.zip in nand or sd card
Every time I go to check on a system update, I receive this message.
Tip
Wii - How to SoftMod, Guide.
This post will explain How to SoftMod Nintendo Wii on any firmware, Region and make its Homebrew enabler for play Wii games, backup, Homebrew applications on your wii, And all without needing a wii modchip!
Requirements: A SD card, (1GB should be enough for Installer and Backup), formatted to FAT32. Some SD card is not compatible to be used to backup the wii nand, but its work for use as boot2 of bootmii, so you might be need 2 different memory, for installation and nand backup.
Download: All files can be found **Here..!
*SD Card Pack
*cIOS38_rev14-Installer
*IOS60 Patched.
*Trucha Bug Restorer
*WAD Manager v1.4
*AnyRegion_Changer_v1_1b
*AnyTitleDeleterDB
*Backup Launcher WBKL
*Firmware Updater v4.1 -299Kb. (Need Wi-Fi connections).
*preloader v0.29 -214Kb. (OPTIONAL).
Installation Procedure:Adding Files.
  1. Extract ‘SD Card Pack’ and copy all contents to the root of SD Card, and copy a second of ‘IOS38-64-v3610.wad’ to ‘wad’ folder - ‘SD:/wad/’.
  2. Extract ‘cIOS38 rev14 Installer’, ‘Trucha Bug Restorer’, ‘WAD Manager’, ‘Any Region Changer’, and ‘Any Title Deleter’, into ‘apps’ folder - ‘SD:/apps/’.
  3. Extract ‘IOS60 Patched’ and ‘Backup Launcher WBKL’ into ‘wad’ folder - ‘SD:/wad/’
  4. Preloader is also an optional install, if you don't want it just skip.. Extract ‘Preloader’ into ‘apps’ folder. ‘SD:/apps/’.
  5. Extract ‘Firmware Updater v4.1’ into ‘apps’ folder. ‘SD:/apps/’. This updater require wi-fi connection, If you want to use offline updater, you will need wad updater (*.wad) and put its into ‘wad’ folder. IMPORTANT!! Make sure you have select the right one for your region..! E=Europe, J=Japan, U=USA, if you use a firmware from a different region, it will BRICK your Wii.!
Install BootMii & Homevrew Channel.Homevrew Channel is a channel on your wii menu that will allow you to put applications (homebrew) on your sd card and put them on your wii, this may include emulators, games, and installers.
Insert the SD card into Wii. then, Go to ‘Wii Options’ > ‘Data Management’ > ‘Channels’ > ‘SD Card’, then you will get a message saying ‘Load boot.elf?’, select ‘Yes’ and the Hackmii installer will run.
Press ‘A’ to continue, Install the ‘Homebrew Channel’ (HBC), and follow the on screen instructions. When done, the HBC will appear on wii channel.. Now go back and install ‘Bootmii’ as ‘boot2’ (recommended), if you can't install it, try different SD card. When it done, reboot your wii with it SD card, and wii will load into BootMii menu..
Backup Wii NandMaking a NAND Backup with Bootmii is highly recommended, it will recover your Wii from bricks. make sure there is at least 530MB free on SD Card.
Boot Wii into BootMii menu, if bootmii is installed as an IOS, go to the Homebrew Channel, press ‘home’ on your Wiimote then select ‘Launch Bootmii’.
Readmore...
on Aug 28, 2009 | Sony PlayStation Portable (PSP) Console
How do I transfer from nand to sd
Hi
If your SD card is not recognised there are possibilities:
1. The manual - I'l give the link later in case yours is mislaid - only mentions "Micro SD" up to 32Gb. Sometimes these cards can be the SDHC category and these are not always accepted in devices designed for SD only. They look identical so make sure yours doesn't say SDHC.
2. The file format on the card can be significant. It needs to be a format compatible with the phone. If you have no other data on the card, it might be easiest to see if the phone will format it.
3. Of course it might be a faulty card - can you test it elsewhere?
The link for the manual mentioned above is here:
Proscan Media Tablets eBooks ReadersInstructions Manuals Quick Start...
Its about 15th down the list and will download direct to your computer.
With regard to downloading from nand to SD card, is this essential? If you have a micro USB to normal USB, then you should be able to use a computer to take data from the nand. The nand would show up as a drive in "My Computer".
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 04, 2015 | Proscan PLT7223G 7" 4 GB Wi-Fi Black...
Upon powering up my screen will only show the message loading os image and will go no further. How do I fix this problem
SYLVANIA SmartBook Operating System Update:
  • Format an SD card 1GB or larger to FAT32
  • Insert formated SD card into your PC
  • Download and save the SYNET_NEW_SHELL_IMAGE.zip (65MB)
  • Unzip the SYNET_NEW_SHELL_IMAGE.zip (65MB) file to the root of an SD card.
  • This should result in the creation of a folder called script in the root directory of the SD card.
  • Insert the SD card into the SmartBook (netbook) device and power on the netbook.
  • The netbook will update its software. Wait for the window ?Upgrade? completed.
  • When completed, remove the SD card and reboot the Smartbook by pressing the device hard power ON/OFF button.
http://www.digitalgadgets.com/mini-netbook.php
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 01, 2011 | Sylvania G-Netbook
Somehow my husband has deleted all of the applications. I tried to reset by pushing the button on the bottom of the computer. There was nothing in the recycling bin. This happened when he formatted an...
  • Download and save the sylvania_smartbook_OS_update.zip file
  • Unzip the sylvania_smartbook_OS_update.zip file to the root of an SD card.
  • When completed, remove the SD card and reboot the netbook.
If you have tried this, please contact customer support:
Call 888-571-0866 or email: dgsupport@digitalgadgets.com
Thanks, Joe
Jan 29, 2011 | Sylvania G-Netbook
I was trying to upgrade the software and it wiped the comp clean can you do a reset
  1. Format an SD card 1GB or larger to FAT32
  2. Insert formated SD card into your PC
  3. Download and save the sylvania_smartbook_OS_update.zip file
  4. Unzip the sylvania_smartbook_OS_update.zip file to the root of an SD card.
  5. This should result in the creation of a folder called 'script' in the root directory of the SD card.
  6. Insert the SD card into the SmartBook (netbook) device and power on the netbook.
  7. The netbook will update its software.
  8. When completed, remove the SD card and reboot the netbook.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 29, 2010 | Sylvania G-Netbook
Message "unrecognized file format"
Is the error message appearing on the caemra or the computer?
I will in both cases recommend to format the SD card and to update your firmware.
Format your SD card. NOTE this will delete all existing data on your SD card.
Do the following:
  1. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
  2. Turn on the camera.
  3. Press the Menu button, then go to the Setup Menu.
Scroll up or down to the Format option, then press the OK button
Instructions to uploading new firmware:
Connect the camera with the computer.
Turn the camera on.
Click onto the link and follow the instructions.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9637/9640&product=EKN032552
If successful please give me the feedback as a rating or recommendation. Thank You
Jan 25, 2010 | Kodak EasyShare C633 Digital Camera
Gphone Error
Maybe you can try to reset the phone back to factory settings (you'll lose all your data!!): 'Home' > 'Settings' > 'SD card & phone storage,' then select 'Factory data reset.'
Dec 01, 2008 | Google Android
Visual Land - VL-879-8GB-BLK - Connect 7 Tablet Logo
Top Visual Land Computers & Internet Experts
David Payne
David Payne
Are you a Visual Land Computer and Internet Expert? Answer questions, earn points and help others
