Vizio vbr333 door will not open
Door will not open
Vizio tv won't power on
Could be an open internal fuse or power supply failure
Aug 03, 2016 | Vizio 42 Class 120hz - 3d Hdtv Lcd...
I just purchased a XRT503 vizio remote for my TV and I can'tfigure out how to put the batteries in, no manual came with it
Flip remote over and see if there is a small sliding door on the back that you can slide open for the batteries. Either AA or AAA batteries needed.
Dec 02, 2014 | Vizio Remote Control XRT503 With BLUETOOTH
Vizio will not power on, vizio emblem is off.
Did you check the power cord of intermittent connection.
Mar 29, 2014 | Vizio E472VL 47 LCD HDTV - 1080p, 1920 x...
Vizio E320VL has lost sound
if you have basic idea in electronic repair, you can open the back door using a screw driver to gain access the internal part of the tv. then look for the speaker first if worn out you can also check the resistance using an analog tester. by the way before you do this initial checking you can check first weather the audio is set to off or mute in the settings, also check the volume adjustment .
Nov 02, 2013 | Vizio E320VL 32 in. HD Ready LCD TV
Firmware update for vizio vbr333
Found out there isn't any update available and there never will be. My suggestion is get rid of the player and NEVER buy Vizio again. While you're at it tell all your friends and family not to buy Vizio either. I know I'll never buy another Vizio device and never recommend them to fri
Sep 30, 2012 | Vizio 3D Blu-ray player VBR333
Vizio dvd player door will not open
The fault is with its CD loader mechanism.
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts. You can get all details.
Site is listed with Google. You can locate it either at the bottom part of first search page, or at the top of second page.
Sometimes, one among the advertisements by the side and bottom of each post might help you to get details about the availability of spare parts and other components.
Jun 02, 2012 | Vizio VBR100 Blu-ray/HD DVD Player
Disc error
It means either the optical pickup trying to read the disc is dirty or bad.
If bad--it may not be cost effective to repair that unit.
Apr 03, 2012 | Vizio VBR100 Blu-ray/HD DVD Player
No power to tv after power outage
The power boards go bad alot in vizio's, Most likely 4 bad cap's need to be replaced, $10 in parts,,
Feb 12, 2010 | Vizio Televison & Video
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
