Question about Nordic Track Nordictrack Powertread Plus U.s. Walking Belt Nttl99061
How to replace walking belt on powertread plus
Instructions to replace belt
Tip
Tri Flex Deck Spring Bumper Kit Installation Instructions
Following are instructions on installing the tri flex deck spring bumper kit for the Quinton 3.0, Clubtrack, Clubtrack Plus, MedTrack CR60 and MedTrack SR60 treadmills.
  1. Set the treadmill to 5% grade and turn off the circuit breaker. Unplug the treadmill power cord from the outlet.
  2. Remove the front trim cover, hood, and both side rail covers.
  3. Relax the tension on the walking belt by removing the two screws in the rear end caps and the end caps.
  4. Remove the rear roller, then the front roller.
  5. Remove the walk belt and deck.
  6. Remove the compression mounts noting the position of the short and long mounts.
  7. Install the new compression mounts. DO NOT USE LOCTITE. Each side rail should have 5 long and 4 short compression mounts. The two rigid spacers will be installed in the rear holes.
  8. Install the slider bed (deck) and belt. Install the 12 6mm hex head screws using Loctite 242 on the threads. Torque to 30 inch-lbs.
  9. Replace the rollers, end caps, side rail covers, hood and front trim cover. Tension the walk belt and adjust belt tracking.
  10. Verify operation by operating the treadmill with a user at various speeds. Verify there are no unusual noises from the deck area .
http://www.sportsmith.net/page.aspx?did=01035F31-1611-489D-9B3F-E500A84EEC4F
on Mar 11, 2015 | Exercise & Fitness
Pacemaster Pro Plus treadmill popping fuse
You need to replace the walking belt. Don't use the machine until you've replaced that.
May 22, 2017 | Exercise & Fitness
HOW TO CHANGE MY TREADCLIMBER TC10 WALKING BELTS
Bowflex has a service manual for the TC10 that includes walking belt replacement instructions, If you call customer service they should be able to email the whole manual or just the belt replacement steps.
May 07, 2013 | Bowflex TC1000 Treadclimber
Squeaky sound
LUBE inmedIATELY the deck belt +rollers bearings too. If the problem persist time to replace the complete deck belt board.
God bless you
Jan 08, 2013 | Nordic Track NordicTrack Powertread 5.5...
How to fit a new walk belt
proceed according and use common sense;God bless you
Jul 25, 2012 | Sportsart 6300 Treadmill
My belt keep slipping. And I try tighten the ajustment bolts.
Make sure you adjust vthe motor belt first, it may be where the slipping is coming from. You should only be able to twist a properly tightened motor belt 45 degrees. After that, readjust the walk belt. If you have been tightening the walk belt trying to get the slipping out it may be too tight now. Use the instructions in your owners manual to adjust the walk belt. Also, lube under walk belt with the recommended lubrication . That will help the walk belt not too grab and take pressue off of both belts. Good luck
Mar 15, 2011 | Horizon Exercise & Fitness
My powertread pt5.0 does not record distance. can this be repaired?
hi, if you take the front pannel off showing the motor, you will see the motor and a belt roung a flywheel, next to that should be a wire just check if its connected
Nov 13, 2010 | Nordic Track Exercise & Fitness
Nordic Track Nordictrack Powertread Plus U.s. Walking Belt Nttl99061 Logo
18 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
