Question about Cuisinart DLC-8S Pro Custom Food Processor
Motor Won't Run
When the lid is on the work bowl, the motor won't go on
I have a kitchen aid food processor kfpm775, I have had endless problems. I have a new bowl and lid,it worked once.It has been assembled properly and done the check on the motor, which seems fine.
To work properly the bowl needs to first be in the correct place, on model 770 which we have here it is handle in the middle at the front. Then the lid goes on, it's obvious which way is correct with that part and then the pusher must be in the tube to activate the safety cut off switch. It is very rarely the cutoff switch itself which is inside the motor housing. If you look at the motor unit without the bowl on you can see right in the middle up by the top of the housing a hole with white plastic inside it. That's the safety switch that all the levers in the bowl & lid activate. If you turn the unit on (no bowl) and push the run switch down then activate that safety switch be depressing it in with something plastic the motor should run. That will prove to you at least that it's not the motor. That model is close to end of life now, bowls & lids are scarce and the general purpose blade is finished.
Nov 27, 2017 | Food Processors
Tip
The cusinart pro classic food processor is not working ?
Try this procedure:-- It usually goes something like this, with minor variations depending on model number:1.Remove the work bowl completely from the base
2.Plug the food processor in and turn it on
3.Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4.Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the work bowl
5.Place the lid on the work bowl with the tab slightly left of the center of the work bowl handle – slide the lid counterclockwise until it won’t slide any more
6.Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7.Slide the lock to the right into the locked position
The food processor should now work.
This will help.Good luck.
on Mar 08, 2010 | Food Processors
KitchenAid KFPM770 motor runs 3 seconds and stops
Determine first if it really is the motor. Does it only cut out if loaded or will it happen without any load? Remove all bowls and blades, plug it in and turn the power on and press the on button. With something plastic press the small white button that is in the middle above the switch panel and normally hidden by the bowl. This is the safety cutout switch avtivated by the bowl, lid and pusher being in position. Does the motor run while the button is depressed or does it again cut out after a short time but with button still depressed. If it doesn't cut out it's likely that wear in the complicated mechanisms in the lid and bowl handle are releasing the cutout switch with small vibrations of motor running. I figure out which one to replace by swapping out one of the 2 parts for a new one as I try to carry both parts in stock for that purpose.
Jul 11, 2016 | KitchenAid Food Processors
I have a Kitchen aid food Processor no longer under warranty. I checked all the troubleshooting suggestions in the manual and all appears as it should. but when pressing the button nothing happens, w
Remove everything and have just the bare motor, plug it in and press the run/go button while at the same time depressing the safety microswitch activator at the front, just above the buttons where it would be hidden by the bowl if the bowl was on. If it runs then you have a lid or a bowl problem, if it doesn't run you have an inside the motor housing problem. Lid problems are more common than bowl problems but there is no guarantee yours will be the most common.
Feb 15, 2015 | Food Processors
Closing the lid completely the processor does not work
Take everything off and see if you can activate the motor with the safety switch. It is located at the front above the button panel normally covered by the working bowl. Mixer plugged in and turned on press that button switch in with something non metallic. If the motor goes then fault will be with the mechanisms that activate that switch in either the bowl or the lid. The lids are slightly more likely to be the problem than the bowl. Only a new part will properly solve it.
Sep 01, 2014 | KitchenAid KFP750 Food Processor
My kitchenaid food processor won't work
Does the actuator push down far enough to catch the button at the bottom? I repaired one simply by adding a vinyl screw cover to the top of the button so it was tall enough to be reached by the actuator.
Dec 20, 2011 | KitchenAid Food Processors
KitchenAid KFP740 9 Cups Food Processor: I used my processor last in September, 2010 to blend tomatoes for salsa (it was working just fine). When I tried to use it again in Dec., 2010 it simply wouldn't...
Most likely it will be to do with the bowl or the lid. The safety mechanisms in both parts are likely culprits, they operate a micro switch just above the switch panel and hidden by the base of the bowl. Have just the bare motor plugged in and turned on with the run button depressed. Now with something plastic depress that small black button, the motor will likely start running. That proves motor is fine and you need to figure out which of the bowl or lid is the faulty part. The pusher needs to be in the lid tube before the motor will run in case you have forgotten.
Apr 09, 2017 | KitchenAid KFP740 Food Processor
KitchenAid Food Processor 770 won't run
I am assuming the unit is getting power. The "power" LED should be lit up on the front of the unit.
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
If this has not resolve the issue, please ensure the outlet is receiving power.
If the unit is still not functioning, take a close look at the bottom of the work bowl where it meets to the motor base. The work bowl, when locked in, depressed a gray plastic peg. This is the safety mechanism. You may trying depressing this peg on your own with a pencil. If this activates the motor, this may indicate your work bowl is no longer seating correctly.
Also check the work bowl handle to make sure nothing is cracked. There is a plastic assembly in the handle that acts as a second safety feature.
If either of these things seems to be the culprit, I would suggest seeking a new work bowl or work bowl lid to correct the issue.
Jun 18, 2009 | KitchenAid KFP670 Ultra Power Food...
Wont run
If you try the instructions below, and the motor test fails, you can send it in to Cuisinart for a trade-in, but the trade-in will be just as expensive as getting a new food processor (unless your product has an extra-long motor warranty):
You can test the motor by plugging the food processor in, pressing the on switch and using a pen to press the dark grey or black button on top of the base of the food processor. As long as it spins, the motor is definitely good. Next, unplug the food processor. For the food processor to work, you need to have the work bowl, lid, and pusher sleeve all inserted - if one part of the work bowl is not attached, then the food processor will not spin the blade. Once all three pieces have been inserted, plug it in and turn it on. If the blade is still not spinning, then there is a problem with the element that runs from the back of the pusher sleeve down through the work bowl that triggers the motor button. In that event, you can go to Cuisinart's website and order a new bowl, lid, and/or pusher sleeve - if you see any obvious damage to one part, you can order just that one part. If it is not apparent which part is damaged, order the whole work bowl. Make sure you enter your exact model# at Cuisinart's website, because a DLC-7 is not the same as a DLC-7E or 7P, for instance. The work bowl parts are expensive, so I would just write down the part numbers from Cuisinart's website and find them cheaper elsewhere. There is also a video on the website that shows you how to use the food processors - the first part of the video describes work bowl assembly. Once you get this food processor working, it is going to last forever. Have fun!
-Tha Mp3 Doctor
Sep 16, 2006 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-8S Pro Custom Food Processor Logo
100 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
