Question about Drills
Charging time for OSH SDO1CN-3.6V cordless screwdriver
Need charging time for this screwdrive
4 Suggested Answers
danny_murray
  • 55 Answers
SOURCE: My cordless Black & Decker
Most likely it is the switch has gone bad or just a loose connection on the switch . you can take it apart and check the switch connections and make sure they all have a good connection.If they do then you should take a volt meter and make sure that when you puch the button they get proper voltage if not then order a switch and replace it .
Posted on Dec 05, 2008
  • 5 Answers
SOURCE: My Craftsman cordless screwdriver doesn't charge
you have a short in the battery or charger,,,very dangerous ,,the batt could explode
Posted on Jul 28, 2010
SOURCE: looking for Craftsman Cordless Screwdriver Charging cord
Go to the following link:
http://commercial.searspartsdirect.com/partsdirect/parts/5102970-17/0009/900&pathTaken=partSearch&filterPart=&pop=flush
Posted on Oct 31, 2011
Question about Kawasaki cordless screwdriver. Model 200/min (Walmart, Home Depot) Battery registers as charged, but the bit will not turn. Does not appear locked.
Some cordless screwdrivers give every indication they are charged when, in fact, they are not. Either the charger or battery is defective.
May 01, 2016 | Electrical Supplies
I've got this old drill/screwdriver that won't take/hold a charge, I see you may have a solution for that; you responded that you could help . . . . what do I need to do to get it charged again?
cordless drill or screwdriver that won't charge usually has a bad set of rechargeable batteries so these need to be replaced, if replacements are available.
Mar 15, 2016 | Drills
What settings on a universal charger do I use for a Black & Decker 2.4 V cordless screwdriver
I would say that a output voltage of not more than 2.8 volt and the output amp should not exceed 60% of the Amp hour rating of the battery. Example if the battery is a 2000 mah battery the charging amp should not be more than 1400 milli amp or 1.4 amp
Jan 12, 2014 | Black & Decker 9072CTN Cordless...
New dp240 screwdriver wont charge
Take it back and get a Makita or Millwauke Tools cordless screwdriver of at least 14.4V. B&D isn't what it used to be! Neither is Ryobi!
Dec 08, 2013 | Black & Decker Pivot Plus Cordless...
Jul 27, 2010 | Craftsman 14.4 volt Cordless Drill/Driver...
Black & Decker Nickel Cadmimum replacement battery
Check the store where you purchased the screwdriver but you will find its cheaper to buy a new screwdriver with new batteries than to buy just the batteries.
Jul 12, 2010 | Black & Decker 9072CTN 2.4V Cordless...
My old black & decker power screw driver will not accept a charge. I cannot get it charged up.
Black & Decker stopped doing battery packs for the older screwdrivers, like the 9018, some time ago so you cannot get them.
However you can still buy replacement NiCad, Sub C, 1.2v, tagged batteries that will do the job on the older 2.4v models as NiCad batteries for use in power tools are exempt under the European ban on importing NiCad batteries where used in power tools (Specific Exemption).
When you open up the screwdriver look at the positioning of the batteries and the tags/connectors and solder them together the same way.
So all you need is a soldering iron to join the centre tags together and then trim the end tags, top and bottom, to the width of the live/negative connectors and you have got a new battery pack.
It doesn't have to be pretty but after a small investment and a little effort it sure beats paying out £30 to £50 for a new screwdriver. I have done this for my older Black & Decker and Bosch screwdrivers which all work like new again.
Apr 08, 2010 | Black & Decker Pivot Plus Cordless...
Looking for Craftsman Cordless Screwdriver Charging cord
Sep 12, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
Drills Logo
105 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
