Question about QSC KW153 3Way Powered Loudspeaker (1000 Watts 1x15 in)
One of my kw153 after about 10 min of play will shut down. no lights , no sound no nothing. after waiting awhile it will come back on and than do it again.
That's about it,,,, it shuts down after about 10 to 15 min of play
Have new min-etune gibson studio. charged battery, put in, nothing happens. no lights no nothing? Now What
Press down on the battery, which will allow it to pop up, as if you were going to remove it. Press the power "on" button. More than likely, your Min-Etune will now work fine.
Oct 28, 2013 | Gibson Robot SG Special LTD Ebony
Only just bought amp ,but twice now its just cut out,lost sound ,if i switch off wait a minute it ciomes back on cannot be normal surely? rgds neil
Not normal... however verify your guitar cable and guitar to avoid embarassment if the problem might be with those items. ALSO if you are driving this too hard, it probably has thermal shutdown and will shut down the power amp if the circuits get too hot... This is a smaller amp so If you are playing louder than *********** could stand it in a 15 foot square room, you are overdriving this unit and you best get a bigger one.
Aug 07, 2011 | Marshall Amplification *new* Marshall...
Hallo I have problem with my fazer/ foger after turn ON it starts warming UP normaly and after when its ready works abaut 10 min.than stop working remote control shows WORMING UP but never starts...
It MIGHT be overheating due to buildup. Read in users manual how to clean the machine of deposits. The deposits allow the temp to go too high and initiate a shutdown.
Jul 18, 2011 | Mbt Lighting Fazer Fog Machine
I bought my g-dec jr form ebay last summer and really like this little amp but this past winter I went to use it, it worked for 3 to 5 min and shut down, but the power light just blinked moderately. I...
This amp uses a TDA2050 chip that has thermal protection. It is also a small amp that is NOT capable of high sound levels. If *********** can't stand to be within 5 feet of this amp you are playing TOO LOUD for this amp and it will shut down until cooled off to protect the amplifier chip. This amp is intended for practice. It would be adequate for sensible listening level in a 10 foot by 10 foot room. If you need more sound you will have to get a bigger amp. I would suggest you get a sound meter and verify the sound level. DO NOT exceed 4 hours at 90 DB... I know a lot of deaf musicians that have lost their hearing and they are not much good anymore.
Jul 16, 2011 | Fender G-DEC Junior Modeling Guitar...
Fender Acoustisonic Jr. One day I played it at its highest volume, then turned it off. Came back to play it 20 min. later and it wouldn't make a sound. You can slightly hear the guitar buzzing when...
I would try using another speaker to see if you can get the sound back, this will help you narrow down the problem, you can also use the effect send to feed anothe amp to see if you get the sound OK.
It can be blown speaker or output stages,
Jul 08, 2011 | Fender Acoustasonic Junior Dsp Combo...
NEED SKYMATIC DIRGRAM FOR PEVEY 112 AMP TH E AMP WORKS FINE FOR A WHILE THEN IT HAS A VERY LOUD POP AND QUITS, JUST TURN IT OFF FOR 4 OR 5 MINS. AND IT WORKS GOOD A GAIN. I DO SUPECT THE OUT PUT...
USUALLY if the output transistors go, they stay gone. You may have a thermal cutout switch shutting off because of over temp. Make sure fans and heat sinks have free air flow. I have seen broken solder joints in these near the volume pots. Those can also cause a failure as unit warms. When it stops again, let it sit without playing for say 10 minutes and see if it comes back on... if it does, the over temp sensor is probably shutting it down so it doesn't fry. Is it possible you are driving it too hard? Often people try to get more sound level out than unit can deliver.
Apr 22, 2011 | Peavey Bandit 112 Guitar Amplifier With...
After playing for a while, approx 15 min, the volume dies away leaving some sound but greatly reduced. It then gradually returns to normal volume after about 3 mins. Otherwise all other functions seem to...
Such a long delay and a slow return to volume is puzzling. If the return came back in say 30 seconds, I would suspect 1/2 of the V1 tube (12AX7) might have a failure of the heater. When it has failed see if this tube has TWO points of light in it. The cooling down and warm up would give a 15 second ramp up or down in volume. This tube has a path around it that would sustain a very low volume. Try swapping one of the other 12AX7's into this spot. If the sound totally goes away replace the one that was in V1 at first place and see if problem goes away.
Mar 29, 2011 | Peavey Delta Blues 115 30w All Tube Combo...
I have a variax 700 modelling acoustic guitar, On occations it just dies ie,no power or sound. I disconnect everything plug it all back up and still nothing. If I leave disconected for an hour or so...
I don't have a Variax but it sounds like an IC (integrated circuit) inside the guitar is getting hot and until it cools down, it does not function properly. Try the Line 6 website to find the nearest repair center. Good Luck!
Apr 05, 2009 | Line 6 Variax 700 6 String Modeling Guitar...
My akai ewi 4000s kind of froze
Please try to reset the ewi. You can do this like this: Shut down ewi. Press down the four little white buttons Level, FX, Setup and Trans. Keep them pressed while starting up the ewi.
This is a factory reset.
I hope this works for you.
Apr 03, 2009 | Akai Ewi4000s Electronic Wind Instrument
QSC KW153 3Way Powered Loudspeaker (1000 Watts 1x15 in) Logo
37 people viewed this question
Top QSC Music Experts
Vito Vacirca Jr.
Are you a QSC Music Expert? Answer questions, earn points and help others
