2002 BMW 330 Logo
A
Anonymous Posted on Mar 18, 2014
Fuse panel diagram 2002
Looking for the relay for the blower motor blower staying on with ignition off
James
Level 1:
Filmmaker:
Uploaded 5 video answers.
  • Contributor 46 Answers
  • Posted on Mar 21, 2014
 James
Contributor
Level 1:
Filmmaker:
Answers
46
Questions
Helped
25063
Points
92
On the passenger side footwell. On the left, one philips screw to remove carpet panel. Black plastic piece needs to be removed, some have plastic nut to turn to remove. Some just pull towards the back of the carfuse panel diagram 2002 - icon1.png and down at the same time. Tucked in there is the blower resistor "blower switch" with a 4 or 5 wire connector on it. With right hand push on tabs and remove connector. Then with right thumb and index finger grab the blower resistors connector and with your middle finger push down on the plastic tab and pull out. When installing new one make sure to line up the guide pin.
MY 1999 CHEVY EXPRESS VAN KEEPS BLOWING THE 50 AMP EGN A FUSE WHEN TRYING TOO START
Something that fuse powers is shorted to ground . Need to look at wiring diagrams , service repair manual , power distribution diagrams , disconnect everything it powers - one circuit at a time till fuse doesn't blow any more . Then find the short , videos on youtube showing how . EGN A ???? IGN A fuse . ENG 1 or 2
Underhood Fuse-Relay Center Fuse/Circuit Breaker
Rating
Description
ABS Fuse M4-N4
60A
Electronic Brake Control Module
A/C Fuse K11-L12
10A
A/C Compressor Clutch Relay
AUX A Fuse P7-R7
30A
Upfitter Provisions
AUX B Fuse P8-R8
30A
Upfitter Provisions
BATT Fuse M7-N7
50A
Instrument Panel Fuse Block
BLOWER Fuse M3-N3
60A
Blower Motor, IP Fuse Block
ECM-B Fuse F11-G12
20A
Fuel Pump Relay, VCM, PCM, Fuel Pump and Engine Oil Pressure Gauge Sensor
ECM-1 Fuse H7-J8
20A
Ignition Control Module, Ignition Coil, Camshaft Position Sensor, VCM, Fuel Injectors, Crankshaft Position Sensor
ENG-I Fuse L8-K7
20A
Heated Oxygen Sensors, Mass Air Flow Sensor, Exhaust Gas Recirculation Valve Solenoid, Evaporative Emission Cannister Purge Valve, VCM, Secondary Air Injection Relay, WATER IN FUEL Indicator Sensor, Fuel Heater, Glowplug Relay, Wastegate Solenoid, Crankshaft Position Sensor
HORN Fuse H11-J12
20A
Horn Relay, Underhood Lamp(s)
IGN Fuse F5-G6 (Diesel Only)
20A
PCM, Fuel Solenoid Driver, Engine Shutoff Solenoid
IGN-A Fuse M6-N6
40A
Starter Relay, Ignition Switch
IGN-B Fuse M5-N5
50A
Ignition Switch
IGN-E Fuse F7-G8
10A
LIGHTING Fuse M8-N8
40A
Instrument Panel Fuse Block, Headlamp Switch
LH-HDLP Fuse F1-G2 (Export Only)
10A
Left Hand Low Beam Headlamp
LH-HIBM Fuse F3-G4 (Export Only)
10A
Left Hand High Beam Headlamp
RH-HDLP Fuse H1-J2 (Export Only)
10A
Right Hand Low Beam Headlamp
RH-HIBM Fuse H3-J4
10A
Right Hand High Beam Headlamp
RR BLOWER Fuse K5-L6
30A
Auxiliary Blower Motor Relays
ABS Relay (Expot Only)
ABS Warning Indicator Lamp
A/C Relay
A/C Compressor Clutch Coil
A. I. R. Relay
Air Ijection Reaction Pump Clutch Coil
Fuel Pump Relay
Fuel Pump
Horn Relay
Horns
Starter Relay
Starter Solenoid
2002 Town/Country Van. Front, no airflow. Fuse/Wiring good. Replaced resistor. Dualsystem flows in back. How do I check if the blower motor is bad? Could it be something other than the blower motor?
Video's on youtube showing how to diagnose blower motor electrical circuit , need a DMM - digital multi-meter . Did you check the blower motor relay ? Do you know what a relay is an how it works ? Free wiring diagram's here http://www.bbbind.com/free_tsb.html Enter the vehicle info. year , make , model an engine size . Under system click on HVAC ,then under subsystem click on HVAC controls . Click the search button ,then the blue link's . Does your vehicle have manual or automatic climate control . Looking at the wiring diagram your vehicle doesn't have a resistor ,has a blower motor module .
2answers
Where is my ign fuse located on my car
Below dash instrument panel, R16 ignition relay
98 Ford Contour SE Fuse Box Map
Fuse Panel Layout Diagram Parts: passenger side air bag, heater blower, interior lighting, heater blower motor, parking lamp, interior lighting, electric mirror, clock, wiper motor, ignition, reverse voltage protection, rear window defrost, engine management system, instrument panel illumination, radio, wiper motor, power windows, ABS module, backup lamp, brake lamp, door lock, main light, cigar lighter, electric seats,
link below should be the same as yours, press the helpful button
http://www.autofuseboxdiagram.com/1342-98-ford-contour-se-fuse-box-diagram
Where is my ign fuse located on car
Where is the blower motor relay in the fuse panel in a 2002 ford explorer
The relay is located in the fuse panel (power distribution box) located in the engine comaprtment. Below is a picture of the location of that panel and a diagram of the fuses and relays. The blower motor relay is the one located in the number 55 position. This should be in your owners manual if you have one. If you don't and would like a copy, you can email me at [email protected] with your make, model and year and I will be happy to email you a copy. I hope this helps and good luck.
My 2003 saab 93 arc ac isnt working properly whenever u turn off the car the blower fan wont shutoff ive checked the fuses and and relays under the hood and nothing? i had to pull the fuse out of the...
BLOWER MOTOR RELAY BAD MORE LIKELY.RELAY STUCK CLOSED.WHEN YOU TURN OFF CAR.THE BLOWER MOTOR RELAY CIRCUIT STAY HOT AT ALL TIMES.WHILE SOME OTHER CIRCUITS HOT IN CAR IGNITION SWITCH IN RUN POSITION.
2helpful
I am trying to figure out which relay is for the front blower motor. anyone know?
Hi!!
Look ion the INSTRUMENT PANEL Fuse Box, there are two blower motor relays and two fuses, look on the inside of the relay cover for a diagram. The relay you are looking for should be labeled FRONT BLOWER MOTOR RELAY and the rear one should say AUXILIARY BLOWER MOTOR RELAY.
The TWO fuses with the same name on passenger compartment fuse box check:
  • fuse #39 30A fuse. AUXILIARY BLOWER MOTOR
  • fuse #36 30A fuse. AUXILIARY BLOWER RELAY
1helpful
My air conditioner/heater blower will not work on the 4th setting. Setting 1,2, and 3 do work. I have replaced fan speed switch and replaced the resistor. Any ideas?
You'll have to find the correct wiring diagram in order to trace down the fault in your system.. Once you obtain the wiring diagram you'll be able to see what else beside wire is between the #4 speed setting and the blower motor. My guess is you might find a high speed fan relay is triggered from the #4 fan switch setting, applying full battery voltage to the blower motor. If locating the appropriate diagram proves to be difficult you can try looking around the underhood and passenger compartment fuse panel to find a relay. Keep in mind not all relays are always in fuse boxes which makes the diagram important.
7helpful
I need a diagram of the underhood fuse block for my 2002 ford explorer. I don't have an owners manual.
Fuse/Relay Location*Fuse Amp Rating* Description
1 60A** PJB 2 30A** BSM 3 20A** Not used (Spare)
4 30A** Rear defrost 5 40A** ABS (pump)
6 60A** Delayed accessory circuit breaker
7 20A** Power point #2 8 — Not used 9 20A** Power point #1
10 30A** ABS module (valves) 11 40A** PTEC
12 50A** Ignition relay/Starter relay
13 40A** Trailer tow battery, Trailer tow turn signals
14 10A* Foglamps 15 15A* Memory (KAPWR)
16 15A* Headlamp switch 17 20A* 4x4 (v-batt 2)
18 20A* 4x4 (v-batt 1) 19 20A** High beam relay
20 30A** Electric brake 21 30A** Front wiper motor
22 20A** Autolamp; Low beam 23 30A** Ignition switch
24 20A* Rear Fog Lamps 25 – Not used
26 15A* Fuel pump 27 20A* Trailer tow lamps
28 20A* Horn relay 29 60A** PJB 30 20A** Rear wiper motor
31 — Not used 32 — Not used 33 30A** Auxiliary blower motor 34 30A** Power seats, Adjustable pedals
35 20A** Rear power point 36 40A** Blower motor
37 15A* A/C clutch relay/Transmission
7helpful
2answers
Diagram of fuse panel under dashboard
2003 Excusion, V10, 2wd, Eddie Bauer
I had a hardtimefinding this informaton, hope it helps.
fuses
Fuse link
cartridge
2A Grey Grey — — —
3A Violet Violet — — —
4A Pink Pink — — —
5A Tan Tan — — —
7.5A Brown Brown — — —
10A Red Red — — —
15A Blue Blue — — —
20A Yellow Yellow Yellow Blue Blue
25A Natural Natural — — —
30A Green Green Green Pink Pink
40A — — Orange Green Green
50A — — Red Red Red
60A — — Blue — Yellow
70A — — Tan — Brown
80A — — Natural — Black
Passenger compartment fuse panel / power distribution box
The fuse panel is located below and to the left of the steering wheel by
the brake pedal. Remove the panel cover to access the fuses.
Roadside Emergencies
To remove the fuse panel cover,
turn the panel fasteners
counterclockwise.
To remove a fuse use the fuse puller
tool provided on the fuse panel
cover.
The fuses are coded as follows.
Fuse/Relay
Location
Fuse Amp
Rating
Passenger Compartment Fuse Panel
Description
1 15A* Adjustable pedals
2 20A* Power point -floor console
3 20A* Power point – 3rd row
4 20A* Power point -instrument panel
20A* Power point -right rear quarter
6 20A* Trailer tow turn/stop relay
7 30A* High beam headlamps / Flash to pass
8 — Not used
9 20A* Heated mirrors
10A* A/C clutch
11 20A* Radio (main)
12 20A* Cigar lighter / OBD II
13 5A* Power mirrors/switches
14 15A* Daytime running lamps
10A* Driver’s seat module memory
16 15A* Rear seat controller
17 15A* Exterior lamps
18 20A* Turn lamps/Brake on-off switch (high)
19 10A* Body security module/4x4 module
— Not used
21 25A* Rear wiper motor
22 20A* Engine control
23 20A* Engine control
24 15A* Air suspension
10A* 4-Wheel Anti-Lock Brake System
(4WABS) module
26 10A* Airbags
27 15A* Ignition switch Run feed
28 10A* EATC module module/Front blower relay
coil
29 10A* Customer access
Fuse/Relay
Location
Fuse Amp
Rating
Description
30 15A* Highbeam headlamps
31 15A* Clutch interlock switch
32 5A* Radio (start)
33 15A* Front wiper
34 10A* Brake on-off switch
35 10A* Instrument cluster
36 10A* PCM Keep-Alive
37 15A* Horn
38 20A* Trailer tow park lamps and backup lamps
39 — Not used
40 20A* Fuel pump
41 10A* Instrument cluster
42 15A* Delayed accessory
43 10A* Fog lamps
44 10A* PATS module, transceiver
45 10A* Ignition switch Run/ Start feed
46 10A* Left-hand lowbeam
47 10A* Right-hand lowbeam
48 10A* Rear wiper motor
101 30A** Trailer tow electric brake
102 30A** Door locks/Body security module
103 50A** Ignition switch
104 40A** Heated backlite
105 30A** Injector driver module
106 30A** Front wiper main
107 40A** Front blower motor
108 40A** Auxiliary blower motor
109 30A** Heated seats
110 50A** Ignition switch
111 30A** 4WD/Shift on the fly
112 30A** Left-hand power seats
Fuse/Relay
Location
Fuse Amp
Rating
Description
113 30A** Starter motor
114 30A** Right-hand power seats
115 20A** Trailer tow battery charge
116 30A** Ignition switch
601 30A CB Door window motors
602 60A** 4-Wheel Anti-Lock Brake System
(4WABS) module
210 — Not used
211 — Not used
212 — Not used
301 — Front blower motor relay
302 — Powertrain (EEC) relay
303 — Injector driver module relay (Diesel
only)
304 — Heated backlite relay
305 — Trailer tow battery charge relay
306 — Delayed accessory relay
307 — Starter relay
* Mini Fuses ** Maxi Fuses
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
