Question about Cuisinart SS-700 5-Cup Coffee Maker
Drain internal water cuisinart SS-700
Storing unit
How do I fix water leak in Cuisinart ss700 coffee maker
if Cuisinart is like my bunn they do not have parts to fix , it is throw away and buy new .
Oct 12, 2015 | Cuisinart SS700 SINGLE SERVE BREWING...
How can i empty the inner tank of a cuisinart ss 700 fr
Hi, Susan
I don't have your model but I'm going to guess that you should remove the external reservoir and run the machine as if you were making tea or coffee.
Mar 22, 2014 | Cuisinart SS-700 5-Cup Coffee Maker
What might stop electrical slow?
Hello, Vickie
Your machine does not turn on AND you have (or had) calcium deposits in the reservoir valve so, my best guess is:
First the calcium deposits blocked water from going into the heating unit.
Then, the heating unit over-heated and the thermal fuse opened to prevent a fire.
So, you may have to replace the thermal fuse.
This will require disassembly to access the water heating module, locating of the thermal fuse, reading the fuse information from the spent fuse, locating a source for a replacement fuse...etc. Thermal fuses cost about $2 at electronic supply outlets.
Ted
Dec 30, 2013 | Cuisinart SS-700 5-Cup Coffee Maker
When brewing it makes a loud noise
I have 2 Cuisinart Coffee makers. Both make loud humming noises during the pump cycle. In my units, the water reservoir vibrates when the pump is active. Test by hand pressure on the water reservoir when brewing.
I experimented with adhesive foam pads and they worked well but...they eventually fell off. I often just push the unit against the wall behind it.
Oct 14, 2013 | Cuisinart SS-700 5-Cup Coffee Maker
Need instruction book for Cuisinart Single Serve Brewing System Model # CUISS-700
Here are the instructions to de-scale your Cuisinart SS-700, taken directly from the unit's manual, available here (www.cuisinart.com/share/pdf/manuals/ss-700.pdf):
1. Empty the reservoir.
2. Disable the AUTO OFF and OFF TIME features.
3. Making sure there is no K-Cup in the brewing chamber, fill the reservoir with 60 oz. of undiluted white vinegar.
4. Place a large mug on the drip tray and run a Hot Water cycle. Select the 12 oz. brew size. Discard contents of mug.
5. Repeat the hot water process until ADD WATER is displayed on the control panel and the reservoir lights will flash.
6. Let the Brewer stand for at least four hours while still on.
7. Rinse the water reservoir thoroughly and fill with fresh water.
8. Run another Hot Water cycle. Discard contents of large mug.
9. Repeat hot water process until ADD WATER is displayed on the control panel and the reservoir lights will flash.
10. You may need to perform additional Hot Water cycles if you detect any residual vinegar taste.
Note: If DE-SCALE is still displayed on the control panel after completing the procedure, repeat the de-scaling procedure above.
If you found this solution helpful, please leave a positive rating!
Sep 17, 2012 | Cuisinart SS700 SINGLE SERVE BREWING...
Ss-700 keeps flashin Not Ready
I had the flashing not ready problem with my SS-700 Cuisinart as well. I pressed and held the rinse and Hot Water buttons at the same time for about 10 seconds while the Not Ready was flashing. After 10 sec or so the display went off completely. I then powered up with the power switch on the side and the coffee maker came and is working fine so far.
May 13, 2012 | Cuisinart SS-700 5-Cup Coffee Maker
Leaking underneath
You are not alone having the water leak in your SS-700. For better understanding what caused that leak please read the review on Cuisinart SS-700:
http://www.cuisinartfoodprocessordeals.com/cuisinart-ss-700/
Nov 22, 2011 | Cuisinart SS-700 5-Cup Coffee Maker
The water is not heating up.
If the power indicator is visible meaning the heating is absent. There is always a fusible thermal internal protection placed in the unit. it is located near the heating filament. test if it is open resistance. change it with the same rating for consistent fire protection.
Mar 12, 2011 | Cuisinart SS-700 5-Cup Coffee Maker
Cuisinart SS-700 5-Cup Coffee Maker Logo
136 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
