Question about Stairmaster 7000PT Nautilus Stepmill
Setting MAX time limit
I've gone through the step by step process from the manual and can not set max time beyond 20 minutes, when I should be able to go up to 99 minutes. I've set the time at zero then went back in to system and tried again setting for 30 minute, it sets itself back to 20. I want 30 minutes, but it won't let me do it. I don't know how better to describe the problem. Simply put, I need to be able to program a time that is longer than 20 minutes. No matter what I do, when I follow the manual's instructions, the console allows no more than a 20 minute time limit for "quick start".
  • Stairmaster Master
  • 914 Answers
Http://www.sportsmith.net/images/product_support%5Cstairmaster%5CManuals%5C7000PT%20Stepmill%20Manual.pdf
Posted on Jul 22, 2014
Set time on wireless thermometer model 31215B
Setting the Time 1. Press and hold the "SET" button for 5 second, "12h" will appear in the TIME LCD. 2. Press and release the "MIN/MAX" button to select either 12h time (am/pm) or 24h time 3. Press and release the "SET" button 2 times, the hour will flash in the upper left corner. 4. Press and release the "MIN/MAX" button to set the hours 85. Press and release the "SET" button to move to the minute setting 6. Press and release the "MIN/MAX" button to set the minutes. 7. Press and release the "SET" button to activate the clock. Note: When in 12h mode, there is only a "PM" display, which appears under "TIME." If there is no display here it is AM. Make sure you set the time accordingly.
See manual at:
http://www.lacrossetechnology.com/7034twcit/manual.pdf
Apr 08, 2013 | Measuring Tools & Sensors
I cant overclock my system but i go to bios now whati had to do
The BIOS. Overclocking is best done in the computer's BIOS (Basic Input/Output System or Binary Integrated Operating System). There are also some motherboards that let you do a basic increase in power by setting a jumper, but this is dangerous and you have no real stability control.
There are some software programs available which allow you to overclock inside the operating system, but the best results are achieved by changing BIOS settings. Usually you can get into your BIOS by pressing DEL (some systems may use F2, F10, or Ctrl-Enter) as soon as your computer begins the POST
(Power On Self Test - when it shows the RAM size, processor speed, etc.).
Here, you can change your FSB (front side bus), memory timings, and your CPU multiplier (also referred to as CPU Clock Ratio).
Clearing your CMOS. Sometimes, an overclock can become unstable. If this happens, or your computer will not boot, you will need to reset the BIOS back to default and start over again.
This is done by clearing the CMOS (a small piece of memory on the motherboard which stores your BIOS configuration, and is powered by a small battery). Some newer motherboards will bypass user settings in the CMOS if the computer fails POST (often caused by a faulty overclock). However, most motherboards require a manual clear.
This can be done in two ways, depending on your motherboard. The first way is by changing the position of the clear CMOS jumper on your motherboard, waiting a few minutes, then repositioning the jumper to its original place.
The CMOS Jumper
The second way, if your motherboard doesn't have this jumper, consists of unplugging your computer, removing the little CMOS battery, then pressing the power button (your capacitors will discharge), and waiting a couple of minutes.
Then you have to refit the battery and plug in your computer. Once your CMOS is cleared, all BIOS settings are reset back to default and you'll have to start the overclocking process all over again. Just so you know, this step is only necessary if your overclock becomes unstable.
Locked or Unlocked. The first thing to know when you start the process of overclocking, is whether your processor is multiplier locked or unlocked.
To check whether your CPU is locked, lower your multiplier via the BIOS one step, for example from 11 to 10.5. Save and exit your BIOS and your computer will restart.
If your computer posts again and shows the new CPU speed, it means your CPU is unlocked. However, if your computer failed to post (screen remains black) or no CPU speed change is present, this means your multiplier is locked
Multiplier Unlocked Processors. Usually, your max overclock is limited by your memory, or RAM. A good starting place is to find the top memory bus speed in which your memory can handle while keeping it in sync with the FSB. To check this, lower your CPU multiplier some steps (from 11 to 9, for example) and increase your FSB a few notches (e.g.: 200 MHz to 205 MHz).
After this, save and exit your BIOS. There are a few ways to test for stability.
If you make it into Windows, that is a good start. You can try running a few CPU / RAM intensive programs to stress these components. Some good examples are SiSoft Sandra, Prime95, Orthos, 3DMark 2006 and Folding@Home.
You may also choose to run a program outside of Windows, such as Memtest. Load a copy of Memtest onto a bootable floppy, then insert the disk after you have exited the BIOS.
Continue to increase your FSB until Memtest starts reporting errors. When this happens, you can try to increase the voltage supplied to your memory.
Do note that increasing voltages may shorten the life span of your memory. Also, another option is to loosen the timings on the memory (more on this a bit later). The previous FSB setting before the error will be your max FSB. Your max FSB will fully depend on what memory you have installed. Quality, name-brand memory will work best for overclocking.
Now that you know your max FSB, you'll figure out your max multiplier. Keeping your FSB @ stock, you raise your multiplier one step at a time. Each time you restart, check for system stability. As mentioned above, one good way to do this is by running Prime95.
If it doesn't post (reread the section about clearing the CMOS), or Prime 95 fails, you can try to raise the core voltage a bit. Increasing it may or may not increase stability. On the other hand, the temperature will also be increased. If you are going to increase the core voltage, you should keep an eye on temperatures, at least for a few minutes.
Also note that increasing voltages may shorten the life span of your CPU, not to mention void your warranty. When your computer is no longer stable at a given multiplier setting, lower your multiplier one step and take that as your max multiplier.
Now that you have your max FSB speed and your max multiplier, you can play around and determine the best settings for your system. Do note that having a higher FSB overclock as opposed to a higher multiplier will have a greater impact on overall system performance.
http://www.pcadvisor.co.uk/news/index.cfm?newsid=107977
hope this helps
May 30, 2012 | Computers & Internet
Bypass the max backup time.
ther is no program to multiply battery capasity.if you conect another identical batery in paralel you might get dubble the time. but some peaple sai that this methot is dangerus for transformator .but you can conect some fans to cool it douwn.
Jan 01, 2012 | Mustek PowerMust 800 (POWERMUST800USB) UPS...
I have a CDA ci992 with no instruction manual. I cannot get it to JUST dry. I just need to know which setting to put it on. Any chance you can help? I've tried searching for an instruction manual...
Lisa set the time required on the Drying time control right hand side for high temperature up to 130 mins max and left hand side for low temperature up to 90 mins max. Now set the washer timed dial to the drying emblem (3 vertical wavy lines) next to position 8, then finally you need to push in all 4 control buttons on the left of the thermostat. It should now work according to my wife. Dave
Sep 02, 2011 | CDA CI592 Front Load All-in-One Washer /...
I have a Ford Focus C-Max Trend 2004 I cannot tune in the time and Date on Radio/CD 6000 don't have a instruction manual book for this can you please helop
The manuals can be found here, http://fordfcsd.wunderman.be/UK/Audio%20-%20Multimedia%20-%20Navigation/
Push the menu button to get to the time settings, go across to get to hours / mins. You can adjust these by turning the dial for both hours AND minute settings, otherwise when the power is turned off and on again it will reset the clock to the previous setting. After setting correct time continue to scroll to day/month/year and then press menu to set time and then go back to the main menu.
May 03, 2011 | Audio Players & Recorders
Under the settings, limits, the limits on the max HR stop @ 100. I want to increase the setting on max hr but it stops @ 100 and then returns to 18. help [polar F4]
Go into settings.
Press the center button on the right hand side of the watch 1 time you will see settings watch time & date appear in the display.
Press the bottom button on the right side of the watch1 time to get into the TRAINING SETTINGS FUNCTION.
When you see TRAINING SETTINGS in the display press the center button on the right side of the watch once.
You are in TRAINING SETTING mode.
Press the bottm button on the right hand side of the watch 3 times until you see
ZONE LIMITS displayed.
When you see ZONE LIMITS displayed press the center button on the right side of the watch 1 time to enter into the ZONE LIMITS FUNCTION.
Now, you should see the lower end heart rate limit number blinking.
To adjust this number use the top button on the right hand side of the watch to increase this limit or lower button on the right hand side to decrese it.
When you have it set where you want it press the center button 1 time to save that setting.
Now you should see the upper limit number blinking.
Follow the same steps to set the upper heart rate limit.
When you have pressed the ceter button to set the upper limit you have completed setting the heart rates limits and the display should read: LIMITS SET!
Feb 13, 2011 | Polar F4 Heart Rate Monitor Watch
Volume too low
Chances are there a limit on the volume to keep it from going to loud. If the MP3 has a screen, use it to navigate to a menu and go into it's sound settings. From there, you should be able to raise the max volume to the REAL max.
Jul 07, 2009 | Samsung YP-U3JQB MP3 Player
How to reset Netgear RangeMax NExT Wireless Router WNR834B
Do a hard reset (20sec hold reset button, unplug for 20 sec still pressing the reset button and another 20 sec to turn on the power while holding the reset button). That should reset to defaults.
Jul 04, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
How to unlock the keypad of J-Max mobile phone
my mobile phone of j max batery is not taking charge, therefore how i can solve this problem
Jan 14, 2009 | Cell Phones
Mixer speed switch is haunted
Here is where you can download the repair manual. Read the section on speed control adjustments and repair. This might not be difficult for someone who is mechanixcally and electrically knowledgible.
Mike H.
Feb 07, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Stairmaster 7000PT Nautilus Stepmill Logo
79 people viewed this question
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
zr800o1le
zr800o1le
Level 1 Expert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
