Question about West Bend 33600 Coffee Maker
Spout leaking pot seems to work fine but spout leaks, is there a way to fix this or is a new spout needed. Thanks!
2 Suggested Answers
lafalot
  • 152 Answers
SOURCE: Westbend 6 qt crock white round pot
Try the Westbend website or replacements.com. If those two fail, try eBay.
Please remember to rate my solutions! Thanks
Posted on Feb 05, 2009
How do l fix our leaky kitchen faucet
If its leaking from the base of the spout where its attached to the body, its most likely the O rings that need replacing. The spout body could also be leaking as the metal is quite thin and can develop pin holes under the bottom face of the spout. To determine it that's the problem, turn the water on, place your hand under the spout body, you should not get any water spray, if you do (its usually a fine mist so its hard to see, but you will feel it) the spout is bad, replace it.
Jul 27, 2014 | Belle Foret Kitchen Kitchen Faucet With...
WE HAVE OLDER LANDCASTER 90 CUP POT AND THE SPOUT LEAKS. CAN WE PUT NEW GUTS IN IT OR REPL;ACE THE HOLE THANG
Hi, am sure that all it needs is to be cleaned. Gently take it apart, clean the parts, use a soft brush if needed and put it back together and if it still leaks, it is advisable to replace it....
Jan 16, 2011 | Lancaster Colony Deluxe Coffee Urn 58 Cup
One spout is very slow with leaking
The spout is only a plastic with two holes, if the one is only leaking while the other is running corectly then you only need to clean it with hot water and a small brush the hole and the groove. the spoot can easily removed, or even emese it in a pot with hot water for 20 minutes then flash only water.
Jan 05, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
The plastic top of the glass pot on two coffee makers drip.
This is a design flaw and can be corrected by enlarging the lid spout. First remove the plastic lid. Then use a fine grinder or sandpaper to remove approximately 1/8 inch of plastic from the lid spout. Follow the exact same contour of the oval spout. However, do not take off so much material that you disturb the small plastic tabs that hold the lid to the pot. Finish by slightly rounding the edges where the material was removed with fine sandpaper. No leaks - no drips.
Apr 26, 2009 | Cuisinart DCC-1200 Coffee Maker
Leaking Coffeepot
I have the same leaking problem. I just called Hamilton Beach and gave them the model and serial numbers. They are sending me a new "gasket" complimentary but she said if that doesn't work, I'll have to order a whole new coffee tank.
Jan 13, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Ghroe Seabury 25502 roman tub filler leaking at liftrod control
It can be repaired.
You can see an exploded diagram here
I can post more if you need more specific instructions.
Nov 22, 2008 | Grohe 19.045.000 Seabury Thermostatic...
Water leaking from refrigerator
hi thanks for the question you can, remove the spout use a flat screw driver and pry off . now clean it pull fridge away from the wall remove the drain tube from the back clean reinstall thanks the appliance doc
Sep 28, 2008 | Refrigerators
Drips onto counter when pouring from carafe
There are other makes and models with carafes that do the same thing. One tip I saw on tv, though not for this particular brand, said one cheap fix was simply to smear the tiniest trace of vegetable oil or shortening on the pour spout. What is happening is that the liquid wants to cling to the pot. It doesn't like letting go of the surface. But water-based liquids readily let go of oiled or greasy surfaces.
I have a Stay and Go. I had the same problem. I tried this technique, and it worked immediately. Two issues I imagine folks will have with this is, it doesn't last (after a few cups, the hot water has cut the oil off the spout) and they will not like the idea of oil or shortening in their coffee. But the amount you need is so small, I never saw a trace of oil or grease in my coffee cup at all.
It does work, but... perhaps a different spout design or material would be better? Don't designers know about such problems?
Joe
Mar 02, 2008 | Hamilton Beach Stay or Go 45234 Coffee...
West Bend 33600 Coffee Maker Logo
27 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Douglas Dinnebeil
Douglas Dinnebeil
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
