Question about Samsung SPH03 DLP Projector
Sp-h03 Precharged software was erased
What does error H03 means af the Philips portable dvd PD9030?
Go to this link http://tech.rickumali.com/blog/2008/12/30/fixing-my-portable-dvds-h03-error
Aug 06, 2016 | Philips PD9030 9" LCD Portable DVD Player...
How to display Monitor image from mac book through samsung SP-H03 pico projector?
It's not that easy. The SP-H03 accept VGA input through the D-Sub connector. Mac book does not have this output directly. So you need another piece of adapter for the MAC Book to provide VGA output. It would come out from your Mac "Display Port /orThunderbolt port".
Another way is to use a USB to VGA adapter for Mac.
Jan 18, 2013 | Samsung SP-H03 LED DLP Pico Projector
Treadclimber TC20 giving error code H03 H13 H24 on starting
Dear Sir:
You must explain them, such as you did with the error, The PROM, EPROM, was corrupt, there are NOT anything we can do for fit it.
However if you wan to RUN the software calibration for diagnose, troubleshooting, do it.
sincerely. God bless you
May 08, 2012 | Bowflex TreadClimber TC20
How to change lamp on samsung sp-H03
The compact design of this type of projector may mean that you cannot replace the lamp.
Feb 27, 2011 | Samsung SPH03 DLP Projector
Panasonic DVD ls 850 H03 Code error, how to solve this problem
H03 is a mech problem if I remember you need to take the bottom cover off and remove the mechanical assy (laser chassis) then you need to clean the worm gear (this is the gear that moves the laser back and forth) even the littlest amount of dirt will jame this gear and make the unit go into H03 Mode
Jun 02, 2008 | Panasonic DVD-LS850
Pls help
H03 error means Traverse servo error. The spindle motor may be defective.
Mar 28, 2008 | Panasonic DVD-LS50 Portable DVD Player
Code h03
Hi the code HO3 relates to their being a problem with the laser you could try using a lense cleaner and see if its just dust or something like that failing that its going to be getting the laser replaced let me know if you need further assistance.
If you type in your search box this
DVD-LS90 Portable DVD Player with screen HO3
then search this will then list a load of sites that cover your dvd player and will also tell you what that error code means have a look and if you was getting it repaired then their should be a few sites that are selling the parts you need ok
Mar 19, 2008 | Panasonic DVD-LS90 Portable DVD Player
Bk sp button
If this is a recent development, I would suggest uninstalling any recently installed software that may be conflicting.
Also, more detailed information always helps us to help you.
Thanks, and Good luck.
Feb 17, 2008 | Toshiba Satellite A135-S2276 Notebook
Samsung SPH03 DLP Projector Logo
20 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
