Question about Bosch 500 Series DLX SHX55RL5UC Fully Integrated Dishwasher with 14-Place Settings, 4 Wash Cycles,
How do i level a bosch model shx55rl5uc/64 dishwasher
How do i level it vertically
Where is the FLOAT located on my Model SHV55R53UC/64 BOSCH DISHWASHER
I would type all your product information into "SearsPartsDirect", and you should get a picture of the machine.
That set of pictures will tell you if there is a float or not.
There is a phone number you can call, also, and ask them questions about this.
God bless your efforts.
May 22, 2017 | Bosch Dishwashers
My Bosch dishwasher had a check water sign light up then it started leaking from the front, what could be the problem
Your dishwasher may have a missing or defective float switch which controls fill level.
Sep 19, 2016 | Bosch Dishwashers
SCREW SIZE TO ATTACH TOEPLATE ON BOSCH DISHWASHER
I have install those but its been a while I think is the same as #8 Machine Thread >>>>
Nov 09, 2014 | Bosch Dishwashers
Bosch Dishwasher stopped draining
If you hear the pump running, but little water drains, then check hose, and clean out debris trap at bottom of dishwasher. That gets plugged and needs occasional cleaning.
Sep 04, 2014 | Bosch Dishwashers
Water not emptying
check if the dishwasher is level. designed to drain correctly under level conditions.
Apr 21, 2012 | Bosch Dishwashers
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
I have a bosch shu3002uc that is leaking at the bottom of the door. I have to put sponges on the floor to catch the water. What should i do?
Check the levelness of the dishwash. Is it level.
Check the seal around the contact surface of the door and the washer opening. Are there any cuts or gaps?
Apr 25, 2010 | Bosch 23 in. SHU3302UC Built-in Dishwasher
My bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
May 26, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Wont drain!!!
Check first the drain lines and the drain pump.
If the drain pump is working, and there is no problem in there, then the problem is usually because the water level switch activated by the floating sensor is stuck.
Jan 06, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosch 500 Series DLX SHX55RL5UC Fully Integrated Dishwasher with 14-Place Settings, 4 Wash Cycles, Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
