Question about Mitsubishi WD-57732 Projection Television
Timer cannot get the timer light off
Where can I get a dusk till dawn timer master plug did one that I wanted a TDD-MP but cannot get them anywhere so now looking for a Paget dtd timer where can k get one
  • No Paget, but lots of others
  • DUSK TILL DAWN LAMP TIMER - Nexus Industries www.nexusinds.com/masterplug/downloads/pdf/TDD.pdf · PDF file DUSK TILL DAWN LAMP TIMER SWITCHING MODES i) Timer mode ii) Random mode iii) On mode iv) Off mode v) Dusk 'Til' Dawn mode i). Timer Mode The timer will turn ...
  • Dusk to Dawn Timer ' eBay > www.ebay.com/bhp/dusk-to-dawn-timer Find great deals on eBay for Dusk to Dawn Timer in Light Timers. Shop with confidence.
  • images of dusk till dawn timer bing.com/images b3eo0&w=105&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">551o0&w=60&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">6f9o1&w=72&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">595o0&w=99&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">773o0&w=107&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">fcfH0&w=72&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2"> See more images of dusk till dawn timer
  • Dusk to Dawn Photocell Sensor Timer Switches 10.02 www.acetek.co.uk/id66.html Acetek manufacture Dusk to till dawn photocell timer light sensitive sensor switches for energy saving lamps LED 6v 12v 24v and 240vAC
  • Dusk Till Dawn' Self-Dimming Lighting. - D-D The ... www.theaquariumsolution.com/files/Dusk Till Dawn Instructions... · PDF file 3 Step 4 - Synchronising Programme with the Plug Timer It is necessary to synchronise the Dusk till Dawn chip to the time of day during which the unit has been ...
  • Amazon.com: dusk to dawn timer www.amazon.com > Search > dusk to dawn timer Amazon.com: dusk to dawn timer. Amazon Try Prime All Go. Shop by Department. Hello. Sign in Your Account Sign in ... after 2,5 or 8 hours / Dusk to Dawn default timer
  • Items found similar to "DUSK TILL DAWN PHOTOCELL ... - eBay www.ebay.ca/sch/sis.html?_nkw=DUSK+TILL+DAWN+PHOTOCELL+SENSOR... Photocell Timer light Switch Daylight Dusk till Dawn Sensor Light switch G8. ... 5 Pcs Dusk To Dawn Photocell Light Control Auto Sensor Light socket Black.
  • Amazon.co.uk: dusk to dawn timer www.amazon.co.uk > Search > dusk to dawn timer Amazon.co.uk: dusk to dawn timer. Amazon.co.uk Try Prime All ... Battery Operated Fibre Optic Snowman, Built in dusk till dawn light sensor. Kitchen & Home: ...
  • Feb 05, 2016 | Hardware & Accessories
    Light won't turn on or off
    Where is light located?
    What is light used for?
    What voltage?
    Is this light inside home?
    Is there a timer?
    What brand and model timer?
    Add a comment and describe timer.
    Is this an old timer that stopped working, or a new timer that might be wired wrong?
    Is light bulb good?
    have you tried different light bulb?
    http://waterheatertimer.org/How-to-set-timers.html
    http://waterheatertimer.org/How-to-wire-timers.html
    Sep 27, 2012 | Hardware & Accessories
    The red indicator light for the intermatic light timer EJ351 does not even go on - what can I do?
    Hello Barb.
    EJ351 timer indicator light problem:
    Reset timer and try again.
    This timer is rated for incandescent lighting only, 500 watt max, 40 watt minimum, and timer has two wires.
    When replacing switch, either wire can connect to timer wires.
    Check circuit breaker: click breaker all the way off, and then back on.
    Use non-contact voltage tester to see if wires are live at timer.
    If the timer does not work, then it has 1 year limited warranty for defects in workmanship.
    Copy following link for EJ351 timer manual with instructions for resetting timer.
    http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
    Jul 18, 2012 | Intermatic Programmable 24 Wall Switch...
    I have installed the Utilitech timer switch # 0141224 with all of the wires connected as they are explained in the installation packet. The timer works and turns on the lights, however it only turns on 4...
    Utilitec is single-pole timer.
    Wiring sounds correct. Lights will blink if timer white white is connected with timer red wire. Lights will not turn ON if timer red and timer black are reversed. Green to ground is not necessary for timer operation.
    Check light bulbs are operational.
    Bundle of white wires are neutral wires.
    Timer white wire requires neutral connection to complete circuit to timer electronics.
    If bulbs are good, it is likely that loose white wire is problem, since each of the outdoor lights also needs neutral wire to complete circuit.
    Having 6 white wires connected together, plus stranded wire from timer, takes a large wire nut, and that many wires can have a wire fall loose without notice. You can solder wires together, or break the group apart under different wire nuts with a jumper wire between.
    Resources:
    http://waterheatertimer.org/How-to-twist-electric-wire.html
    http://waterheatertimer.org/B220C.html
    http://waterheatertimer.org/See-inside-main-breaker-box.html
    Aug 15, 2011 | Intermatic Inc. ST01C Digital In-Wall...
    I have a Westek indoor digital timer, i have a nano tank with 2 lights (moonlight, daylight). I"ve tried setting the timer for 7 days with each light on at different times, it just won't work.Though...
    http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
    http://waterheatertimer.org/Woods-timers-and-manuals.html#TE05W
    You want to control each light with different programming?
    Westek TE05 timer is single-channel timer, so different lights cannot be controlled by different programs.
    You need a two-channel timer so each light can come on at different times.
    http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
    Zilla timers are two-channel timers: yellow outlets for daytime, and blue outlets for nighttime.
    Mar 28, 2011 | RTO Amertac TEO5W Decorative Indoor Weekly...
    Outdoor lights timer: Intermatic HB851 photo timer with dial. How do I set it for dusk ON then off in 8 hrs.
    Intermatic make HB51 timer.
    If this is not your timer, then add a comment.
    To set for ON at dusk, and off 8 hours later, rotate dial to the number 8.
    Timer turns on automatically at dusk.
    Timer set to 8 hours will start countdown when timer turns ON > and 8 hours later timer will turn off.
    Make sure timer is turned away from lights so photo-eye doesn't receive feedback.
    Feedback is when the photo eye gets too much light, and then timer thinks it's dawn, so lights turn off, and a moment later photo eye thinks it's dusk again and lights turn on again.
    Feedback from lights will cause timer to reset the 8 hour countdown.
    A car pulling in the driveway can cause feedback.
    If the timer resets because of feedback, it begins the 8 hour countdown again, so the lights will not turn off until dawn.
    You can test timer by putting black tape over photo eye, and then timer will turn on.
    Set timer for 2 hours for example and then check if timer turned off 2 hours later.
    If timer is not functioning correctly, then timer is defective.
    Dec 18, 2010 | Woods Outdoor Lighting Timer
    How do I get it to start at dusk and run for 4 hours
    You posted under Intermatic make HB51 timer.
    To set for ON at dusk, and off 4 hours later, rotate dial to the number 4.
    Timer turns on automatically at dusk because timer has photo eye.
    Timer set to 4 hours will start countdown when timer turns ON > and 4 hours later timer will turn off.
    Feedback is when the photo eye gets too much light, and then timer thinks it's dawn, so lights turn off, and a moment later photo eye thinks it's dusk again and lights turn on.
    Feedback from lights will cause timer to reset the 4 hour countdown.
    A car pulling in driveway can cause feedback.
    If timer resets because of feedback, it begins 4 hour countdown again, so lights will not turn off until much later than planned, or not turn off until dusk.
    Dec 18, 2010 | Intermatic Outdoor Timer/Photo Control...
    I set the timer for 6 hours, it went on at dusk but it blinks instead of staying on.
    Two things can cause problem.
    1) defective timer
    2) feedback from nearby lights
    Feedback from lights will cause timer to reset the 6 hour countdown.
    If the timer resets because of feedback, it begins the 6 hour countdown again, so the lights will not turn off until much later, or at dawn.
    Intermatic EJ500 gets VERY HOT on metal portion around timer
    Sounds like you have too much load. The device is using its heatsinks like they were designed for. To dissipate heat.
    Dec 14, 2008 | Intermatic Inc. EJ500C Digital Wall Switch...
    Lights continue to go off
    Maybe the lights are causing photoelectric eye to sense that it's no longer dark.
    This is called feedback.
    To check this, set timer for 2 hours.
    Put black tape over photoeye.
    Check if timer turns on-and-off.
    If timer continues to blink, then timer is suspect. Return it for another one.
    If feedback is causing the problem, then turn timer away from lights or place obstruction between timer and lights.
    Dec 10, 2008 | Intermatic Outdoor Timer/Photo Control...
    Mitsubishi WD-57732 Projection Television Logo
    11 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
