Question about Kenmore 43142 Front Load Washer
Front load washer won't rotate counter clockwise in wash or spin
My Kenmore front load washer works when going clockwise, but won't wash or spin when it needs to reverse to counter clockwise. So, my clothes are still extremely wet at the end of the cycle.
  • 15,935 Answers
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Clogged draining boot?
Check the drain filter and the drain hose at the back.
Drain filter access is located in the fro lower section of the front size. You need to remove the trim at the base of the washer and to undo the cap, turning it counter clockwise. Disconnect power before starting and keep a container ready to collect the water.
Dec 08, 2011 | Kenmore HE2 Plus Front Load Washer
My Kenmore washer 20432990 will fill and agitate but won't drain or spin. When I push down on the lid switch I hear nothing but when I let it go I hear a faint click.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 15, 2011 | Kenmore Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
I have a whirpool duet ht washer that doesn't seem t want t spin on high. Trying to wash one coat by itself and it is soaking wet. Have tried drain/spin mode only but all it wants to do is rotate clockwise...
If you only have one coat in there, that is a problem. It will notice the unbalanced load and shut the spin down and try to redistribute the load. Try adding a few wet towels to offset the weight of the coat. This will likely take care of the problem.
Dec 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
It sounds as if the belt is slipped. It smells a little, like burning.
If your machine is a FAV6800AWW/FAV9800AWW take a look at this post Spin cycle locks up.
I believe this forum member’s clutch pulley is locking up in the wash cycle. Pull the 120VAC plug on the machine to remove power. You need to remove the front cover to inspect the Clutch Pulley and see if you can rotate the Clutch Pulley Counter Clockwise the spin direction then Clockwise the wash/agitate direction. The rotational resistance should be free and very light. Post back with the results and we will go from there.
Here are some links for the Service Manual.
The Service Manual for reference. Sears Parts Direct for reference.
Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point. With a 5/16 nut driver or 5/16 ¼ socket on an extension to remove front panel see page 41 of the SM
Oct 05, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Front load drive motor on Kenmore washer will only turn the drum in a counter clockwise direction an there is no fast spin
you could have choosen the gentle care mode or delicate mode where in it would only run in one direction and would spin slowly.
tnx 4 using fixya,
drcool
Jul 28, 2008 | Whirlpool Washing Machines
Kenmore elite 44832 front load washer troubleshooting F11 c01 c02
Was there ever a post back for this problem? I have the same issue, and I tried replacing the central control board, but it is still giving the F11 error. I follow the troubleshooting guidelines, but it never makes it past C01. I suppose the next logical step is to look at the motor control board and then the motor.
Sep 11, 2006 | Kenmore Elite 45986 Front Load Washer
Kenmore 43142 Front Load Washer Logo
29 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
