Question about Sewing Machines
Tacsew t111 155
Needle is frozen.Wont go up & down.
  • Sewing Machines Master
  • 7,365 Answers
The machine needs to be checked to see why the needle is froze, could possibly be a broken part.
Posted on May 06, 2014
2 Suggested Answers
SOURCE: Tacsew T500 : Needle continually comes unthreaded
No this machine does not use a bobbin. I just purchased one too and called the supplier to help me keep mine threaded. He said they do not take much tension at all. So check your tension and then when threading it, make sure your thread goes under the bar in the center of the tension disk, not on top of.
Good luck, once you get it going it does a beautiful job!!!! Love it, Love it!
Posted on Jan 28, 2008
Stitch selector knob on bernina 600, not Deco, is stuck and cannot select needle position, However the width of stitch part of the knob is working.This knob has 2 parts, needle position and width control
Your machine (Bernina 600 Record) has most likely frozen (seized) due to lack of regular maintenance. Don't panic. It can be fixed with a lot of elbow grease, good quality oil and a hairdryer. The following method has resurrected several Berninas I've picked up as "nonworking."
How can fix stuck needle bar on my Bernina 730
Wheel on right side that controls the needle up and down is very tight...
It was working now it seems to be frozen the needle part wont move
Nov 01, 2016 | Bernina Sewing Machines
I have a tacsew T 622R. Wondering what size needles it takes
contact your local sewing machine repair shop as they will have the needles
there is a major needle manufacturer that has needles for all the machines and the shop will have a catalogue with the needle listed
Jun 25, 2015 | Tacsew Sewing Machines
How to adjust pressure foot pressure on husqvarn viking disginer 1 sewing maching
I'm confused by your question, which mentions two machines. The presser foot pressure on a Tacsew T111-155 is adjusted by turning the knob on the left side, top of the machine that is directly over the needle. The Designer 1 mostly sets its own presser foot pressure, but it can be increased or decreased by following the procedure on p. 13 of the manual: http://new.husqvarnaviking.com/SiteMedia/Products/Machines/Support/Designer_I_manual_EN.pdf
May 22, 2014 | Tacsew T111155 Mechanical Sewing Machine
Tacsew t111 155
the needle bar may need a adjustment at a sewing machine repair shop.
Mar 18, 2014 | Sewing Machines
Need repair manual for my tacsew model ddl8500-t industrial sewing machine
fixsewingmachines.com
sewingpartsonline.com
sewusa.com
sew4less.com
Apr 09, 2012 | Tacsew Sewing Machines
Tacsew t111-155 sewing machine skipping stitches after rethreading and changing needle
I don't have firsthand knowledge of this machine, but the machines I've used would do this when the thread tension was too high. Check the thread path for any dirt or buildup of fuzz from the thread. Also, check to make sure the thread tension adjustment isn't set too tight. Gently tugging on each thread one at a time may reveal which thread is binding and make your search more efficient. I hope this helps.
Feb 14, 2011 | Tacsew 20U43 Sewing Machine
Needle suddenly stop sewing. what should i do
change the needle
clean under the needle plate where the feed dogs are for lint
also in the bobbin area for lint & loose threads
rethread the machine & make sure the thread guides are all threaded
Nov 22, 2010 | Tacsew 20U43 Sewing Machine
Bernina 1630 needle will not move go side to side.
If you can pull the needle bar down manually and it springs back up, the basting clutch is stuck. By someone who knows how, it's a very easy fix. I would guide you here, but I don't know how to explain it. Plus, you have to be very careful not to damage the spring loaded clutch.
Jan 02, 2010 | Tacsew 950
Oct 31, 2007 | Tacsew T500
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
