Question about Konica Minolta Office Equipment & Supplies
Black lines trans. roll. life
  • Konica Minolta Master
  • 6,161 Answers
Replace the transfer belt, but a model number would have help
Posted on Jan 15, 2016
My trans stopped working so I put the car in neutral and the car would not move at all but it will roll forward
Hi Jim:
First thing I'd be checking would be the fluid level and looking for visible trans fluid leaks. Sometimes it can be from not re-connecting the transmission cooler lines (that go to the radiator) quite tight enough.
Aug 02, 2015 | Cars & Trucks
My canon ir 2420 is producing black lines
Generally Black line comes when Drum life is over, check your machine counter, one drum life is 35000-50000 print.
Feb 25, 2015 | Canon Office Equipment & Supplies
After printing a label it advances too far wasting the next label
This is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
Jan 03, 2014 | Seiko Instruments Smart Label 450 Thermal...
I have a Toyota sienna 2001 that has a slight shift gear problem. When I accelerate and put the pressure on the accelerator, it takes time to shift. The only solution I did to cope with this is that I
Fluid changes have nothing to do with anything
but restoring the fluids ability to remove heat
That is why all transmissions fail, because people
don't change trans & power steering fluids
Flushing verse a pan remove, can actually cause dirt
to get into the shift solenoids, even though some will
not agree, I won't chance that
Your trans if over ten years old is at the end of it's
life span
You just have to diagnose the entire powertrain to see if you
can save it
Mar 10, 2013 | Cars & Trucks
Shift solenoid valve performance
I don't know what your trucks trans problems are,
unless you tell us
The shift solenoids are all inside the trans pan
If that trans is all original,since 2003,then it hasn't
much life left, before it needs a rebuild
Has it been checked out at all by a trans shop,repair
shop,dealer ?
You can't guess,there are no common things to tell you
Everything has to be tested & again a 10 year old trans
is near the end of the line,especially if you never change
the fluid every two or three years
Jun 11, 2012 | 2003 Chevrolet Suburban 1500
My W5A51 trans in my Diamante is slow to change allowing it to Rev Quite high when it is cold and it sometimes slips out of gear when cornering around turning circles. I have checked the trans fluid level...
when you check the fluid do you allow the trans to come to operating temp and check it with the engine running and trans in neutral, don't forget to set your E-brake or block the wheels from rolling. you checked the fluid in this manner it would be my guess that the clutches inside the trans or the belts in the trans are slipping, it could also be something as simple as needing a trans service, new fluid and filter.
May 22, 2011 | Mitsubishi Diamante Cars & Trucks
How do i take the transmission out of my 2003 pontiac grand am (2.2L 4cyl)
Not by yourself,on your back, in the driveway. You will need a shop with a lift and the proper equip to support the engine etc.
Feb 16, 2010 | 2003 Pontiac Grand Am
Print alignment problem. Prints across 2 lables. not sensing the black line on back of label roll.
As it turns out, a good cleaning took care of the problem. I suspect the sensor bar was dirty so it could not detect the black line on the back of the labels for alignment.
Thanks anyway!
Mike Sunderland
Jun 02, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Red roller part number
That is most likely the upper fusing roller with the line on it. I don't know if it is possible to just replace the roller. The source that I use only offers the complete unit (2 choices) one has a white connector, the other has a grey connector.
Apr 19, 2009 | Office Equipment & Supplies
18 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
