Question about Amana NTW4650YQ Top Load Washer
Wont agitate unit wont agitate
  • Amana Master
  • 5,323 Answers
No agitation?
first use a multi meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle?
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open.
Another test u can make with a multi meter is by testing the prongs individually.
# 15,16,17 (don't worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch.
(where the wire plugs into) take note of weather it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open.
If both check ok then next CHECK the motor coupler (a bad couplercan be checked by looking under the machine and taking note if there is a black residue on floor, look at coupler located between the motor and tranny, and see if it is broken up or missing any parts? Try to turn shaft by hand and notice if it does not engage tub? )
or belt if belt driven. Check for loose, broken or worn belt .
Then check the door switch with a multi meter for continuity OHMS when door closed and infinity when door is opened , and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
ALSO CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS.
Posted on Apr 11, 2015
I have a700 series top loader washer,and the agitator wont agitate,it will spin,but wont agitate why?
The agitator itself is stripped or loose is one possibility. Take agitator off to see if it is damaged.
Jun 03, 2014 | Washing Machines
Washer wont agitate or spin
Depending on the brand of washing machine, the agitator may be a single piece unit or a two piece dual action agitator. If the single piece agitator or the lower portion of a dual agitator does not oscillate back and forth during the wash cycle, or if the agitator can be turned on the transmission shaft, then the spline may be damaged and the agitator may need to be replaced. Most agitators are held in place with a bolt that threads into the top of the transmission shaft and is located below the softener dispenser or top cover. Some models use a small set screw in the barrel of the agitator just above the base to secure the agitator to the shaft, while some will use a rubber o-ring to provide a tight fit. When the retaining device is removed you should be able to lift the agitator from the shaft.
Aug 03, 2017 | KitchenAid Washing Machines
Wont spin, drain or agitate
the transmission is either burnt out or the freaky looking belt that turns the pump is off. or the switch that tells the unit that the top lid is down sometimes comes loose cause some companies used a caulk like substance to keep the foot attached to the switch as slid away from where it is and the lid is not pressing that foot down to close the circuit and tell the tranny its safe to spin etc. You can fill with the lid open but not spin. There is a motor that controls all the spinning and draining or agitation and if something in their design is opening the circuit it wont perform those functions.
another idea is the timer motor isn't making contact and you might have to replace that..... there are tons of issues that can cause that.
Feb 20, 2014 | Amana Washing Machines
Admiralwasherm#aav7000aww fills up just humswont agitate
Possible that the motor is not starting up as the starting capacitor to the motor is weak. check if the motor is warm after switching off power. if so it is confirmed. Otherwise it can be due to a belt issue, bearing failure and jamming of the agitator and shaft.
check power to the motor during the wash cycle to confirm , if not the control unit is a suspect.
Jul 05, 2012 | Maytag Admiral AAV7000A
Machine wont agitate
If the machine sounds like it is running OK. The agitator has lost its connection drive shaft because gear splines that connect it to the agitator have been damaged. You didn't really do anything wrong, this just happens occasionally. Hopefully yours has a sleeve that can be replaced rather than replacing the whole agitator.
It is tricky on some agitators, their may be a nut on the top of the agitator that holds or connects the agitator to a drive shaft. The top of the agitator probably has a plastic cap that covers this up and can usually be pried off to expose it. If there doesn't appear to be connection like this then the agitator may simply lift up. If you decide to try lifting the agitator up, let me know and I give you further guidance.
You might also call your local Appliance Supply store and with your make and model number, ask them if you unit has the sleeve or do you have to replace the agitator. I'll bet they will tell you.
Mar 02, 2011 | Hoover Washing Machines
My washer will not agitate model #wsm2700hbwww
Hi Christalee - Were you able to fix the issue. I have the same model and have the same problem...it wont agitate. Any inputs/suggestions would be great,,,,,
Jul 30, 2010 | GE Spacemaker Washer and Dryer Electric...
The top wont spin and the bottom will
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only
one way.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of
the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator
should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
May 29, 2010 | Kenmore Washing Machines
I have a kenmore top load washer, The top part of
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
The top section of a two part agitator is designed to turn only one way. If the "agitator dogs" in it are worn, it wont agitate either way.
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Also see the following on how to do it.
Oct 28, 2009 | Kenmore Washing Machines
Machine will spin; but not agitate
Really wont matter, your unit is way out dated and the parts are no longer available to the consumer..Sorry
Apr 04, 2008 | Washing Machines
Amana NTW4650YQ Top Load Washer Logo
49 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
