How do i operate etec measure mate device to measure size of a room
How do i operate this
How to figure 12x12 sq ft
12 x12 = 144 sq ft
12 x12 x12 = 1728 cubic ft
May 02, 2015 | Heating & Cooling
We installed a mr. heather IR30LPT, set the fan to auto and the control to #1, however, the unit runs continuously without shutting off. The room is less that 1000 sq. feet. Can you tell me why the unit is...
THERMOSTAT CONTROL OPERATION
FOR IR20LPT / IR30LPT: The thermostatic control used
simply turns on and off the burner.
FOR BF20LPT / BF30LPT: The thermostatic control
used modulates the flame size as the temperature gets
closer to set point, then it turns off the burner upon
reaching temperature.
The burner will cycle back on when room temperature
drops below the set temperature. The control knob can
be set to any heat level between 1 and 5. Selecting the
HI setting will cause the burner to remain on.
Note: The thermostat sensing bulb measures the
temperature of air near the heater cabinet. This
may not always agree with room temperature
(depending on housing construction, insulation
location, room size, open air temperature, etc.).
Frequent use of your heater will let you determine
your own comfort levels.
The LED temperature indicator measures approximate
room temperature around the heater.
Note: The LED temperature indicator DOES NOToperate with or control the thermostat setting of the
heater.
IF YOUR UNIT IS NOT TURNING OFF IN POSITION 1 BUT THE TEMPERATURE AROUND IT IS HIGH THAN THERMOSTAT IS STUCK AND YOU HAVE TO CHANGE IT OR VISIT SERVICE.
1-5 knob has no info what is the parameters of temperature sorry!
Nov 27, 2017 | Heating & Cooling
What size should a coffee table be?
The size of your coffee table depends on the size of your living room and the setup of your living room furniture. You can find the right coffee table by measuring exactly how much space you have in your living room and what's your table's main purpose.
Jul 31, 2012 | Furniture
How do you calculate the cfm in a swamp cooler
You will need to figure the cubic feet of space you want to cool, and then divide that number by two. The quotient will give you the CFM rating for the proper-sized swamp cooler.
Jun 14, 2011 | Heating & Cooling
A/c seems not to working cooling down room What are my options?
Could be several factors. Let me start by saying the unit you have should cool a room that totals around 450 square feet (Approx.).
If you do not know your rooms square footage just multiply the width of the room x the length of the room.
(e.g. 20' x 10' = 200 SF)
The above 450 SF is for a room with typical 8' ceilings. This is also a "Rule-Of-Thumb" measurement, as windows, doors, insulation, and air leakages (heat gain) also play a role in calculation of heat loads. But this will get you close....
If the room is larger than 450 S.F. in size then the unit is too small for this size room.
A rule of tumb for sizing is: every 600 square feet requires a ton (or 12,000 BTU) of cooling. Again, without doing a proper load calculation on the room or area being cooled, it is hard to be exact.
The other possibility is the unit is not operating as it should due to mechanical or other issues. This is hard to specify. COuld be refrigerant levels are low, coils dirty, or filter dirty.
Sep 02, 2010 | Maytag Portable Air Conditioner M6P09S2A
I need to replace some old storage heaters in my
you need to measure the height of celing size of room how many outside walls thickness of walls take this info to your local heating shop they will tell you the heat loss for each room and what size heating you need in kws you then choose the heaters you want
Apr 19, 2010 | Heating & Cooling
Tire ? what are the max height for this van it has 225/75r 16 now?
would be un able to give u a correct answer-if keeping a 16 rim than turn ur wheel all the way to left and measure the clearance from tire to frame than turn all the way to the right and measure which ever is smaller or if barely touching that is ur max size the 225 is the width in metric[mm] the 75 is the sidewall ratio and the 16 is rim size if u go up in size u have to worry about turn radius and what might the tire rub on so using the stock size which most of the time is close to max using stock rims-- u check and measure than if there is room u can add the measurement to width and or side ratio
Jan 25, 2010 | Ford Econoline Cars & Trucks
Wiper size
Just take a tape measure and measure the length. 18/19/20 inches. Thats all you need to know.
Dec 25, 2008 | 2005 Dodge Caravan
EKG supprt
Recently, the USA government approved the first pocket-sized EKG machine, so small that it promises easier, faster heart measurements in ambulances, the emergency room - even a possible heart attack victim's bedroom. This devices are already avaliable on special stores and on the internet and usually reffered to as "handheld EKG machine". The most common one is called "ReadMyHeart".
Aug 27, 2008 | Philips Heartstart FR2+ Defibrillator
Etec 2g mp3 player
I have an etec 2.0 mini mp3 player m211, and recently I have experienced the same issues with windows media not being able to recognize the device. After trying many options, I discovered I could simply connect the device to another computer, and instead on synching song tracks as you would normally do, i simply went to the start menu, my computer, and located the E drive (removable usb drive), and drag /dropped the tracks stored in "my music" directly onto the E drive. After locating the E drive, you can do this by going to "my music", right click on the song track, click send to, select E drive, and its done! At least thats what worked for me as far as downloading song tracks ( dont know if you can do this for uploading as well, havent tried it) .... However unfortunately, this may not be valid info for those using any version older than XP... Good luck!
Mar 26, 2008 | Electronics - Others
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
