Question about Samsung DVD-VR375 DVD Recorder/VCR
RECORD DVD WILL not play on other dvd plays
I DUBBED a dvd on the samsung, but it is not recognized on other dvd players
  • 356 Answers
There is a possibility that the DVD was not burnt to be compatible with other players. Or the player you are trying to play it on does not play burnt DVDs.
Posted on Mar 19, 2014
  • Donald Stevens
    Donald Stevens Mar 21, 2014
    what kind of dvd discs did you use and did you finalize the dvd ?
  • 31 Answers
SOURCE: doesn't read dvd's
This problem is down to failure of the laser and an only be solved by replacing it. Samsung are aware of this fault but will only offer a free replacement if the unit is still covered by it's warranty.
They do offer a replacement service but charge £94 for it.
Posted on Mar 06, 2008
  • 6 Answers
SOURCE: Recording on DVD-R with Samsung DVD-R155
Heating issue. If you remove the cover and touch the processor chip - you will not be able to keep your finger there for more than a second (that is if your really want to use this crude method to test the temp).
I have taken measurement and its around 50C. Thats a lot for no heatsink or cooling fan.
If you have the unit in a cabinet with no air flow - you will not be able to use this unit for more than 3 months and up to a year. Best to have it on top of a cabinet or in one with an open front and back to allow some airflow - or just anywhere where its in the open.
Samsung has another unit - the AR650, which I believe is discontinued - which for some strange reason has realized this concern. My guess its a whole different team of designers (or at least some folks with some brains) and added a cooling fan into the unit. Its the same exact case and motherboard as the 135, and 155. There are absolutely no issues with it rejecting disc's - even after a year of use for some users.
In Summary:
Solution 1 - Place it in the open
Solution 2 - Remove case and drill holes to the topside
Solution 3 - Remove case and add a fan
Solution 4 - Remove case and add a heatsink over proc (will still need to drill holes over heatsink..
Solution 5 - We can all complain to Samsung and have them recall the units
Posted on Aug 22, 2008
SOURCE: Playing a recorded dvd from dvd-vr375 on another dvd player
If you are using DVD-R media, you can record in either V or VR mode.  What is confusing is that if you try to format the media, you only have the choice of VR mode -- and this mode is very well understood by other dvd players, some other records do understand it.  This mode has much better editing capability, but poor compatibility.  If you want compatibility, use the V mode.  The trick is that to do that, you don't format it!   V mode is the default and does not require formatting.  The owners manual says that, but too well hidden if you ask me
Posted on Mar 02, 2009
SOURCE: SAMSUNG DVD RECORDXER 120
Do you mean rso on the payer? You should have a button on the front of the dvd maked rso, press this three times to cancel the rso,it should then play.I hope this helps. Jamie
SOURCE: samsung dvd vr-357; recorded DVD only plays on the player
You have to "Finalize" the disc before it will play on other units. Go to Disc Menu, Second choice listed(not in front of it right now) Selections to right will offer disc Finalize. Say YES.
Posted on Jul 21, 2009
Testimonial: "Thanks"
Can't view recorded DVD
if the movie you recorded ? was copy protected. then your dvd prob did not record
Nov 22, 2012 | Magnavox ZV427MG9 DVD Recorder/ VCR
Panasonic DMR-E75V Dubbing Problem
you will need to finalise the disc in your DVD recorder before it will play on any other equipment
Nov 18, 2009 | Panasonic DMR-E75V DVD Player/VCR
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can't dub from Samsung VR8606 to another device
If you have a scart socket on the back of the vcr poss marked av1.Connect a scart lead to this and if the dvd recorder has scart sockets connect to the one marked av2.Then put the vcr on play and the dvd on av2 and you should be able to record,hope this works.Jamie
Jul 07, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
VHS to DVD-R dubbs fine: but won't play on SONY DVD player.
Please finalize burned DVD to play in another dvd player.
Apr 16, 2009 | Panasonic DMR-E75V DVD Player/VCR
Can not get dubbing to work
Samsung's solution to many problems seem to be the type of dvd. Try using a dvd-r. I am able to select dubbing with a dvd+r, but the +r discs won't play in other dvd players. Apparently, -r is the only disc to use with this box to avoid issues. The +r records the soundtrack a few seconds off of the video track.
Dec 14, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
ERROR CODES E24 ~& E4 54037380 ON MY DVD RECORDER, CAN ANYONE TELL ME WHAT THESE MEAN, THANKS
If you are trying to record vhs tapes to the dvr side, first you need to get 1x up to 8x DVD-R dvds. You can find them on ebay. The machine has problems recognizing the up to 16x type. Put the blank DVD in and let it load. Then start playing (not dubbing but playing) the videotape for at least 6-8 seconds. If you have somewhat of a lead-in on the videotape you can let it go even 10 seconds. Only after the videotape has been playing for this period of time, press the dubbing button. If the error code does come up, rewind the tape and start again, but in most cases the error code will not happen if you do it like this.
Mar 31, 2008 | Sylvania SRD3900 DVD Player/VCR
VHS TO DVD DUB ERROR ON PLAYBACK
Sounds like the DVD is not finalizing or not doing so properly. Check your setup options...
Mar 30, 2008 | Sony RDR-VX555
Transfer VHS to DVD
The illustrations within the PDF is very help!
To play disc in other DVD players…
The disc needs to be finalized.
Page 37 of the manual has “Finalizing a disc”.
Recording from DVD to VCR…
Page 39 “Dubbing Mode”
http://www.funai-corp.com/support/manuals.aspx
Type in the box: MWR20V6
Nov 09, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
HDD to DVD
make sure you set dubbing speed to sp ,short play,thats the default setting,then go to start up menu and finalize disk
Oct 11, 2007 | LG RH177 DVD Recorder/HDD Recorder
Samsung DVD-VR375 DVD Recorder/VCR Logo
57 people viewed this question
Jerry Greenberg
Jerry Greenberg
