Question about Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground
I am looking for the timer pins that you use to set the timer on an off with. Anyone know where I can get some?
Open following link for Power Pack trippers, troubleshoot checklist and warranty information and other tips to keep power pack working longer:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 27, 2011
Pin Timer JAC T35
Copy following link:
http://waterheatertimer.org/How-to-set-timers.html
Add a comment and describe timer in detail.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 22, 2013 | Hardware & Accessories
Looking to buy the red pin to set the sign timer
1) Timer is not identified.
Question posted under Intermatic T100 series which has metal trippers, and not green and red.
2) Copy following links to help identify timer:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Tork-timers-and-manuals.html
http://waterheatertimer.org/Paragon-timers-and-manuals.html
3) Add a comment Dec 2012 and describe timer in detail. Or attach a photo of the timer for possible identification.
Dec 10, 2012 | Intermatic & Indoor/Outdoor Rain Tight...
Need to know how to set timer #15075
GE 15075 is heavy-duty plug-in-type 24-hour analog timer with pins located around dial.
Each pin represents 1/2 hour. Two consecutive pins represent 1 hour.
Open following links to identify timer and to read detailed instructions:
http://waterheatertimer.org/GE-timers-and-manuals.html#15075
Aug 31, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
Hi how do i set the the 59200 timer for indoor use. does it matter if you use the nos on the white side of the dark side of the timer? im not following the instructions. how do u know how many pins to...
Each pin/segment represents 30 minutes.
To set timer for 2 hours, move 4 consecutive pins/segments up or down.
For 8 hours, move 16 consecutive pins/segments
http://waterheatertimer.org/images/Raise-segments-240.jpg
Dark background for numbers are usually 'night' or 6pm to 6am.
Timers usually have am and pm printed on timer dial.
Open following link for analog timer instructions:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
Jul 18, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
I use Omron H3CR 8pin to my CCTV in my car. I use pin 2 for ground,pin 7 for ignition, pin 4&5 for direct current from battery and pin 8 to +ve CCTV. My problem is when I off the engine the timer is...
I don't have exact schematic for your 8-pin timer.
Use multimeter read ohms and voltage from pin socket to pin socket.
Use multimeter set to ohms to read continuity of pins on timer.
Pin timer relays have NO NC pins.
Some pins are Normally Open (no current flows until timer turns on)
The other pins are Normally Closed (current flows until timer turns on, and when timer turns on, this circuit turns off)
Apr 08, 2011 | Omron Healthcare Omron H3cr-a-ac100-240v...
Can't set timer
You posted under Grasslin in-wall mechanical timer.
Instructions for this timer are nearly identical to GE
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
First, the timer has to be wired correctly, so review wiring instructions shown on link above.
Next, the pins have to be set, so read instructions and look at image of pins shown on link above.
Last, the timer switch has to me set. I believe timer switch is moved all the way right for timer program to operate.
To check operation, manually rotate dial clockwise to watch lights turn on-off.
This will tell you exactly how to set pins and switch.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial rotates as time passes, and pins trip a lever that opens and closes switch to your lights.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 08, 2011 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Installed several GE smart digital timers around the house: for lights over garage, front door, court yard. They are model 15086. The units work in timer mode as desired. I would think...
15086 timer:
Pressing door will override timer setting and manually turn switch ON-OFF.
Press door or open timer door, and press any of 4 buttons located in corners.
You know information posted so far:
However, you are moving the small switch from Timer to OFF.
And when switch is OFF, the override does not work because circuit is OFF.
You want a timer that can switch programming OFF, and not switch circuit OFF, so that device toggles between timer and ordinary switch.
Looking at timers on the market today, I cannot think of any in-wall programmable or box timer that does what you want. Each has manual override that reverses timer function, but when you set timer to OFF, the circuit is OFF.
http://waterheatertimer.org/Programmable.html#Aube
Plug-in-type timers have override button that turns programming off, and then you can operate table lamp normally with the lamp switch. But in that case, the lamp has separate switch that operates outside of timer functions.
GE 15070 24-hour mechanical timer could do what you want:
http://waterheatertimer.org/images/GE-15070-mechanical-timer.jpg
In this specific case, when you wanted to operate timer like a light switch, you would move all the pins inward, and then use the on-off switch. The problem with this idea is the pins are tiny, and you need very good eyes or a light-source and small tool to continually adjust pins.
See GE timers and manuals:
http://waterheatertimer.org/GE-timers-and-manuals.html#15086
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 07, 2011 | UPM Programmable Wall Switch Timer
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
Manual ON/TIMER switch located on inner dial.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
I need a manual for UTILITECH #0148373.. and i need it now! PLease help me..i need to know how to use this product. HELP PLZ!
Open following link to correctly identify product:
http://cgi.ebay.it/UTILITECH-2-OUTLET-TIMER-0148373-15-AMP-LOT-OF-4-/290468257053
Utilitec 0148373 timer is plug-in type timer.
Set on-off times by moving pins.
Pins are located on dial and stick up. They can be moved back and forth like stick-shift on car.
See example of pins at following link:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Instructions:
Turn ON lamp.
Light bulb is good.
Plug lamp into timer.
Plug timer into outlet.
Move some pins outward.
Then manually rotate dial clockwise to watch how lights turn on-off.
That will tell you if lights turn on or off when pins are set outward.
Dial turns as time passes.
Lever on top of timer is moved to 'Timer'
Dec 30, 2009 | Kitchen Appliances - Others
Timer won't turn off or on by itself
Pull the pin up wait and see if it comes on you will know then. Most do pull up but there are a few that have the pin that has to be shoved in. 90% however do have to be pulled up to set the timer for off and on.
Oct 02, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Logo
604 people viewed this question
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Rob Sinbad
Rob Sinbad
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
