Question about Kohler Home
K5007t not flushing properly
Water ridge toilet manual
Thus if the tank is continuing to drain down through the bowl into the sewer line, the rubber flapper is not seating properly with the flush. These become worn and torn and are easily replaced. Or, even with a new one installed, sometimes they are not adjusted properly to create the appropriate balance between play and pull. Play being the upward connection to the flush handle and pull being the downward draw with the gravity flow of the water. Too much play it won't actually flush or lift properly. Too much pull it does not seat tightly or won't lift up long enough to allow enough water to flow through to flush the toilet...as engineered by the geniuses who designed the toilet. A simple adjustment of the chain links attaching the flapper to the flush handle and perhaps a side to side turn of the cuff so the flapper is aligned to seat properly as it drops should be sufficient. And test, test, test, test, and test again until you're absolutely sure you've got it adjusted correctly. One or two flushes is not sufficient!
Dec 08, 2013 | Plumbing
Toto neorest 500 take two flushes to work properly
Water pressure may not be strong enough or the tank is not filling up well in the back.does it have trouble on just flushing urine.
Jan 13, 2013 | Toto - Toilet - One-piece - Neorest 500 -...
Flushing problems
Tank needs more water and the flapper has to stay open longer by adjusting chain so the flapper goes up higher when you flush the unit. Practice and you will get it right.
Apr 09, 2017 | Kohler Toilet - One Piece with Ingenium...
Flushed radiator. Changed thermostat because prior to flush. engine wasn't heating up properly. During drive, the 1st step in flush procedure, engine heated properly and heater worked properly. Drained and...
Air in the system. Run the engine with the cap off, rev the engine up and this will help purge the air. Fill as needed and keep check on it for a few days.
Jan 22, 2011 | 1995 Jeep Grand Cherokee
Flush button won't work. 12 yr old Duravit Toilet
The push button siphon assembly is worn out. Just replace it entirely.
May 26, 2010 | Home
Toto toilet does not flush properly - insufficient water to make it flush properly - need to pour water down toilet for it to flush. There is not any kind of blockage.
Check water level in tank for proper height it should be about 5/8 close to top of stand pipe in tank or it should have a mark on it wher it should be.
You can adjust the flush valve to increase water height.
May 13, 2010 | Home
Crane toilets don't flush properly, ball comes down too quickly
adjust the flappers-- either adjust the length of the lift line-from flapper to handle and or the flapper itself not properly mounted on tank seat
Mar 10, 2010 | Crane Plumbing Home
It has rusty water coming through the hoses and the resovoir. I had the radiator flushed and the thermostate changed and changed the two busted hoses and the thermostate cap and changed out the fan that...
Did you have the radiator removed from the vehicle, then flushed, or was it done w/out removing it? If it was done w/out removing it, it was not flushed properly or thoroughly. Regardless of being flushed in or out of the vehicle, the engine block has a drain plug that should be removed, and it too should be flushed. If you had it flushed properly, and the correct amount and mix of coolant replaced, you should be able to drive for at least a couple of years before a coolant change would be needed again, and longer than that before you would see rust in the system. Whoever did the work did a #$(* job. They should provide another complete flush and new coolant for no additional charge, as you already paid for it, and that is not what you got. Once properly flushed to remove all rust and sediment, you should not have any overheating problem. Also note that a plugged up heater core can cause no heat in the passenger compartment.
Dec 08, 2009 | 2000 Honda Civic
My toilet does not flush properly. It seems to
You might check under the rim of the toilet, there are about 12 little holes that when you flush water comes out to start the most important part of the flush. The swrill, with out it hard to flush. Talk a piece of wire hanger ( I know "NO WIRE HANGERS") and use it to push up into the holes. Hard water deposits sometimes build up there.
Sep 27, 2009 | Home
Home Logo
41 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
